-=OFFICIAL HPI FIRESTORM THREAD=-
#3728
RE: -=OFFICIAL HPI FIRESTORM THREAD=-
Wondering something..
Is there a gasket or something missing here?
Because when i hold the glowplug down and turn the engine, it bubbles oil around it..
#3729
NJ
There should be a copper ring between the plug and the metal thing the plug sits on. And the cooling head should be on top of that ontop of the engine. Your manual should say everything.
just make sure you tighten everything as well as possible. And do it in a X pattern for it to sit better. Ex: Screw the top right, then bottom left, then top, then bottom right.
#3730
ON, CANADA
The savage clutch has been covered about five times in the past 20 pages of the thread. Basically any savage clutch fits but you may have to remove a wire guide on the transmission to fit the flywheel.
Superb- there are no gaskets between the button and cooling head (see p. 28 in the manual) and only below the botton and block. Is is leaking below the button or on top through the glow plug? It isn't clear to me how it was described.
I am surprised how dirty it is. How many gallons have you run so far? If buildup is making it leak, soaking in brake cleaner overnight will clean it.
#3731
nitro-rob, you say you are surprised how dirty it is... mine is 2 gallon old and and way more dirty almost black
does that means something ?
thanks
thanks
#3734
ON, CANADA
ORIGINAL: impalapolicepack
thanks
thanks
#3736
ON, CANADA
If you take the glow plug out and rotate the engine you can see when it hits bottom. Then mark your flywheel with a marker under the truck so you don't have to find it anymore. You can get a feel for how far to go past the top to get it at the bottom.
#3738
IL
any 1 know where i can get the bearings for the motor ?the maual says that thay are bouth the same part # but thay are difrent sizes part #15145
I cant find them any where.
#3740
IL
thanks any ways i found them.but i have to buy the crank to and its 50 bucks,@ that price i should replace the old moter for 65 bucks.Ill go to my lhs and see if thay have any bearings that fit.I hope so, I only got 4 gallons in this moter
#3741
Problems..again.. Wondering what i can do abou this. See it's squirting oil when i try to start the engine.. It rains oil when i try to start it, as you can see on the picture I have tightend the glowplug and it sits really tight. The oil comes from underneith the cooling tower..:
I've recently changed to the 16% fuel.. My last bottle of 25% was a little brown, maybe it was that it was too much oil in the 25% 'cause it's been standing for atleast 3 months.. What do you think guys? What should i do about it?
#3742
ON, CANADA
If the leak is between the cooling head and block it there are normally three reasons.
1. the head is not tight or tightened unevenly by not using a star pattern (but you are obviously smarter than this)
2. there is crud or some kind of buildup or something between these two interfaces that are not making a good seal, or the gaskets are blown. Try cleaning both parts in brake cleaner.
3. the block or head are warped from overheating - this can only be fixed by replacing
#3743
ORIGINAL: nitro-rob
Does the overheating hae anything to do with the cylindertop being slightly burned?
#3744
Hi all. I just bought a firestorm off e-bay with a .18 CV-rx in it. Can't wait to get it . What kind of 20% fuel would you guys recomend running in it? I was looking at the duratrax red alert. Also this seems to be the best deal on a 6V hump pack I've been able to find, will it work ok or is there something better/cheaper? [link=http://www.onlybatterypacks.com/showitem.asp?ItemID=11130.17]hump pack[/link]
#3745
ON, CANADA
hey everyone!
I have a question to ask to everyone! i have a firestorm and the steering on the car is not the great any more and i was wondering if you think i would have to work on it or have to get a new steering servo for the car? it use to be able to make quick turns and now it take a longer to do so!!
thanks Mark
thanks Mark
#3746
ORIGINAL: Johndeeretimex
hey everyone!
thanks Mark
hey everyone!
thanks Mark
Get a hump pack and upgrade the servo to a futabo, its all covered alot a bit farther back in this thread.
#3747
PA
Its your servo saver.Take it apart and tighten the bolt and use locktite to secure it.Might as well get a metal gear,high torque steering servo while your at it.The Hitec 645mg is a good one,also the Futaba S3305.
#3748
ON, CANADA
This has been covered many, many times in the thread. Same thing for savage clutches. Maybe we should come up with an index to cover all the topics....
#3749
Wolfe,
I've used Duratrax Red Alert in my Storm since day one and love it, I would use nothing else.. Ironically I have a Duratrax RT-X 27 and have been using O'Donnells 20% in it since day one and am probably gonna switch to the Red, seems to have better lube and cooling properties unless you are a racer.. Good luck with your Storm, it is an awsome truck, wish HPI would make a 2 speed tranny for it, it would be the ultimate Jato Killer...
#3750
My Feedback: (20)
IL
ROB That won't work people would still ask daily even if it was a sticky.Look at the nitro engines thread it has any and I mean any info you would ever need when it comes to break in,tuning,fuel ect and you still get the break in questions along with tuning questions on a daily basis[&o].Same thing for what truck is best,if people used the search they could find answeres quickly with out all the same posts over and over again.This is why Iv'e kinda taken a break from the forums and don't reply as much.I don't mind helping people but get's old answereing the same things over and over again[]My point is use the SEARCH feature if you can't find the info then ask,alot of these posts wouldn't be here if people took time to search what there looking for instead of posting the same thing Joey did yesterday.Ok my rant is over carry on.
