RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
glo plug prolems
Old 09-08-2009 | 06:19 PM
Default glo plug prolems
getting very annoyed, rusler starts right up, I can run the truck with the glo warmer in when but i take it out it dies. the motor is a 3.3, yes the glo plug is brand new, and the motor has alot compression left almost like its new.
please help, anything helps!
thanks;
mike
Old 09-08-2009 | 07:25 PM
MCSRacing's Avatar
Default RE: glo plug prolems
it is possible to get a bad plug out of the package ...... try running a OS LC3
Old 09-08-2009 | 07:35 PM
pulled the plug out of my jato it did the same thing, put it back into my jato and the jato ran fine....... im so confused.....
Old 09-08-2009 | 07:48 PM
ill try those plugs. bu what else could be the problem?
are these the plugs? and is this price fair?
also will they work in the 3.3?
http://cgi.ebay.com/O-S-OS-MAX-18-TM...d=p3286.c0.m14
Old 09-09-2009 | 08:00 PM
B.U.M.P
any help here?
Old 09-10-2009 | 07:35 AM
Sounds like it might be too lean. Try opening up the low speed needle 1/8th a turn and try it again. Also, is the glow plug element straight? It should look like a spring, if it's bent then it needs to be replaced.
Old 09-10-2009 | 08:04 AM
Is it shutting off while it is still idleing? Try going back to factory settings and start tuning from there again. If the plug is running fine in your Jato then it is a tuning issue with the motor.
Old 09-10-2009 | 08:56 PM
Banned
Your low speed needle may be a bit too lean. In New Hampshire and it's getting cooler as fall approaches and you're going to find you will need to run richer than you did in the warmer summer. Turn it open 1/2 turn more and see if this helps.
What is the condition of your fuel? Is it newer? Older fuel that was stored improperly can absorb moisture and may cause this problem.
Old 09-11-2009 | 01:27 AM
crispyspa's Avatar
copied and pasted from a website:
Now why does nitro engine stay running? Presuming your carburetor is tuned correctly. This is where science comes into play. There is heat generated in the combustion cycle. This heat is called "the catalytic reaction".
A catalytic reaction occurs causing platinum to glow in the presence of "methyl-alcohol," or "methanol". This catalytic reaction will occur on it's own without any outside power source. All of this only comes onto play during low rpm and when there is not enough heat being generated to burn all the fuel vapor. The catalytic reaction changes as rpms and temperature rise. This has just been a very basic explanation of how a glow plug works at low rpm or idle.
If there is no/little reaction of the platinum to the methanol, then you have to assume that you are lean as kzimmerman and dittch said.
Old 11-20-2009 | 04:37 PM
I was having a similar problem and switched the glowplug for a warmer one.  Seemed to do the trick.
Snow
Old 11-20-2009 | 05:56 PM
Chris_RC's Avatar
DO NOT get the OS plugs. Their taper is different and will ruin the head button. Say you got an engine without a glow plug, you could run an OS IF you never switch back. OS's also have a shorter body which means you won't get the right compression/performance with OS plugs.
Old 11-22-2009 | 07:21 PM
Banned
ORIGINAL: Chris_RC
Chris: Gotta say that I've never had an issue like that. Very interesting though. I interchange different brands of plugs (for no specific reason) - - but I have to say that OS is on the top of my list.
