factory settings
helps to know which model
best way is get the instruction manual, and read it. There should be a section (seen it in every manual I have) on the engine, in that section should be something telling you what the factory settings should be, and how to get back to them.
That is the best help I can give you with the little bit of info given.
My Feedback: (-1)
AE
What car and engine?As sycho said just check the manual.If you dont have it or cant find it,(Or are just too lazy to look and want us to do all the work) Tell us the car and one of us will either look them up or tell you where to find them.
the idle screw should usually be set so there is a 1mm(had a engine that needed a teeny bit more) gap in the carb. One of the few settings I found should be the same engine to engine
ORIGINAL: SyCo_VeNoM
My Feedback: (-1)
AE
ORIGINAL: Joshs1990
5 out on both and wat about the idle stop screw that is wat i need please
Noooo.3 out on the lsn,5 out on the hsn.Idle should be a 1mm gap.
