RCU Forums
-   RC Nitro Stadium Trucks (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/)
-   -   Nitro mt dubble engine. (https://www.rcuniverse.com/forum/rc-nitro-stadium-trucks-243/2602000-nitro-mt-dubble-engine.html)
mittimj 01-30-2005 04:13 PM
I have a nitro mt and I thot that it would be fun to put a seccond engine on it. Once I started on it I descovered that I needed parts. and the local hobby shop dident have it. so I just spend 50 bucks on tower getting some clutch parts ext. Has any one ever put two engines on this small of a car. will it be wicked slow because of the extra weight or wicked fast. I am thinking of making a longer chassis and gettign some foam tires to make it a street car. Tell me what you think.
sledmanass 01-30-2005 05:55 PM
RE: Nitro mt dubble engine.
you wont gain much more speed, but youll have more Horse Power and more torq on your truck, if you do it, tune one engine at a time and then start them both and be ready for wheelies.
Nitro Guru 74 01-31-2005 12:09 AM
if your serious, msg me and ill give you my msn. Ive already made plans on a twin mt! Itll be such a rocket ship!!!
mittimj 01-31-2005 06:03 PM
1 Attachment(s)
I am going to try to poast some pics for you guys to see.
in the pics you can see how I sawed off some of the plastic exposing axis to the spur gear for the seccond engine to go. There is also a picture of my dads shop in there that he lets me do little projects in.
hondapride59 01-31-2005 07:10 PM
have fun? tuning will be a ***** i bet...not to mention buying aluminum gears from stripping the gears....ur dream just turned into reality and its not cheap...better buy a wheelie bar, and weigh down the front....
killer89 01-31-2005 07:40 PM
two different engines? wont that create an unequal load?
mittimj 01-31-2005 09:13 PM
well to solve the wheeling problem I was thinking of making a longer chassis or having one made. My hopes are to have this keep the front end doun and improve high speed handling.
for two separate engines making seprate loads is true but why does it matter. if I have lets say 1lb of torque of one engine and .5lb of torque off the other then I will simply have 1.5lb of torque..... I think. As for one reving higher than the other... well I guess I just wont get as much top speed as before. due to lets say the stock engine reved higher than my additional engine. then when I reach top speed the additional engin will be holding the stock engine back.... I think. My solution is to gear the car higher and take advantage of all the additional torque I have added.
Drum 01-31-2005 09:22 PM
are you planning on using one or two drive trains? because I believe you need 1 for each wheel, and with two different engines that would cause uneven power to each wheel.
mittimj 01-31-2005 09:23 PM
oh and for the stripped gears.... well, can you guys give me a link where to buy aluminum ones?
weidner01 01-31-2005 09:31 PM
wow- really nice shop mittimj, it looks like your old man is really into old snowmobiles and signs- really cool!(little messy though)
as for the car that should go like a bat out of you know where, you must really know your stuff to tackle a job like that. Do you think you could give me some pointers on tuning airplane nitro engines?
mittimj 01-31-2005 09:37 PM
weidner01... I would be glad to share my expert advice with you. send me a pm and I will show you all there is to know cold weather running and ext. Lets stick to the cars in this forum.
Has any one put two engines on a car before... who thinks I should enter this into that rcu contest thing that is being held....
Nitro Rustler Racer 01-31-2005 09:43 PM
thats a god idea, get some metal gears, and your good to go
mittimj 02-01-2005 09:07 AM
I ahve been noticing that lots of people are concerned with two separtate engines. I dont see the issue, It may not be quite as efficient. But unless someone wants to donate two like motors I am going to stick with what I have.
mittimj 02-01-2005 09:11 AM
I am going not going to add any additional drive train. I am simply putting a seccond engine on the spurgear.
mittimj 02-01-2005 09:53 AM
1 Attachment(s)
I just cobbed this up on paint.... dont think I am quite ready to build this. though not that hard to build it would end up breaking anyting and everything on the car. Maby I will attempt this after I finish my dubble engine monster.
Richs MT2 02-01-2005 10:20 AM
Slick..... you can use robinson metal spur gear for the savage along with the slipper setup from the HPI MT 2 (from tower) i would also suggest some 14 tooth clutch bells. two engines should easily pull this gear and you will need it for the smaller diameter foam tires. IMO road hawgs might be a bit friendlier
living my life 02-01-2005 03:05 PM
For the throttle I would suggest gettings two servos instead of that piece of metal. I think two servos would be more reliable. Plus if you hit any bumps that may wobble a bit and make one engine rev higher or lower.
Otherwise when you get done you better be posting vids and pics [8D]
Nitro Rustler Racer 02-01-2005 04:29 PM
that throttle set up is not good, you need to turn the carburator around on the blue engine,(w/e it is), because how are you going to have a filter on it? that metal piece is blocking it
hondapride59 02-01-2005 04:37 PM
that whole setup look slike the dang thing is not going to run liek a bat out of h e l l , it looks liek its going there....i have a feeling if and when he tries to run it...we get the thread called "double engine gone bad" or in his case and spelling" dubble engine gone bad"
anyways u are going to need metal gears, i cant stress that enough....any gear u may have, it better be metal...also the power thing between the two engines will most likely kill ur two engine dream, i dont see how two different engines with different power ranegs are going to run together
ps have fun with tuning, and getting it to work properly
Dewgel 02-01-2005 05:45 PM
That's one helluva idea! I've also had this bottled up in my mind.
Tell us how it works mate!
-Steve
mittimj 02-01-2005 08:41 PM
I was thinking of running two servos. that is a pretty good adea. I just put that pice of sheet metal on there for mock up. I was going to make somthing a little stronger. maby a linkage of some other type will work better.
Nitro Rustler Racer 02-01-2005 08:52 PM
if you use that metal link you make, but on the second engine turn the carburator around, weld like a metal sheet in the middle of the linkage so that it sticks up, then attach the linkage securly to the throttle thing on the carb, and then the throttle linkage fromm the servo will connect to that metal thing stickin out, if you dunt get it, PM me, i will draw it for you an explain, its really simple, like mentioned when you are bashing that it will like mes up, not really, if you secure it tightly but giving it enough movment everything will be ok
mittimj 02-02-2005 07:53 AM
well that is a goo idea but if you spin the carb around on one than ones cose will be the other ones open. I reciently was showed the best way to do it. I am going to keep it hush hush till I get it put all together.
mittimj 02-03-2005 04:27 PM
1 Attachment(s)
well I got sick of waiting for parts from tower. So I cobbed somthing up to try it out. I am still waiting on a clutch bearing before I can use both engines. waiting to catch a ride to the LHS. hope you guys like my exaust header. amazingly it has pretty good low end. I dident get to test the top end because I have no break yet. btw the plow is junk I think I owe some apoligies for that. I just read my last poast and i dont get it eather.
Drum 02-03-2005 04:44 PM
[:-] you're crazy man
mittimj 02-03-2005 04:58 PM
thank you
hondapride59 02-03-2005 06:45 PM
where are u going to mount the fuel tank? and have u everythougth of getting rear exhausts?
Nitro Rustler Racer 02-03-2005 09:35 PM
hmm.......how does your throttle system work? see it wont work
hondapride59 02-03-2005 09:46 PM
yea looks like to me when he puts a little gas one engine will give the gas and the otehr will do nothing
Nitro Rustler Racer 02-04-2005 06:22 PM
hondapride thats the same thing i thought off
killer89 02-04-2005 11:58 PM
the cars are facing different ways so they will open and close the same.... just looks a little hacky and messy to me... also no brakes yet and not engough room....
hitman45 02-05-2005 12:24 AM
Ohh well it doesnt really matter what it looks like...aslong as it works Right?
Keep up the good work matie. Hopefully when all tests are ok, you will post a video of some sort on a website? That would be sweet to see this truck in action.
Good Luck!
mittimj 02-06-2005 07:06 PM
well the carbs do open because one is spun around. The whole carb linkage wasent my idea, but it works good. I drove it today for about 10 secconds and it was fast. Then I had some reciever troble and once I fixed that I had pull start trobble. hope to sort moast of the problems tomarrow.
Skullbasher 02-06-2005 10:13 PM
ORIGINAL: hondapride59
Since the engines are both different ways, when he gasses it, it will push one throttle arm and pull one. It should work..
mittimj 02-07-2005 07:22 AM
exactly
killer89 02-07-2005 07:02 PM
a little late skullbasher... sniff a little too much fumes today in woodshop?:)
mittimj 02-10-2005 12:32 PM
ran it yesterday. wicked hard to get both running at once. just needs some tuning. with both engines way out of tune, off the start it will roast all 4 tires for about 10 ft before it flips over backwards. This was on wet payvment. all I need to do now is a cupple little adjustments and I will be all set. Thing is wicked fast tho. The spurr gear already has some teeth missing. Cant imagine what the diffs look like. oh and I do have the gear mesh for the clutch and the spurr correct.
krkenned 02-14-2005 10:52 AM
That's a pretty cool setup. I might try that with my backup MT.
By the way, your English teacher should be fired. :D
mittimj 03-06-2005 10:07 PM
UPDATES: I took this truck out form under the bench today. Dusted it off and ordered some parts form tower for it. I started on a longer and wider chassis for it. I plan to now use 2 separate servos for the two engines throttle. the other set up was just not working correctly. The new chassis is thicker aluminum and roughly 2 in longer and 2 in wider. Pics tommarow. And I agree my english is a little bad.
ThunderbirdJunkie 03-07-2005 01:49 AM
sweet, hope to see some more pics/updates soon:D
