DERIVATIVE, New 2X2
Old 05-11-2013, 06:53 AM
  #151
MTK
Default RE: DERIVATIVE, New 2X2
ORIGINAL: Shimano
This should be cool!
Congrats, Matt! Cant wait to see the finished beuty!
Thank you!
The wings came ot pretty light at 392 and 387 grams w/o servo and wing tube. Keeping in mind their size (525 sq inches each) and full paint, it's pretty fair weight....
Fuse with canopy and chin cowl, 1086 grams
Stab total including tube,211 grams. This is reasonably sized at 240 sq inches soslightly heavierweight per sq inch as wing panels. Needed to be strong for the 55 up front of course
Landing gear, complete with axles but w/o wheel, 4.4 ounces.
So around 2300 grams ready for equipment. That was the goal weight from the start for the completed model.
Old 05-28-2013, 06:43 AM
  #152
MTK
ORIGINAL: MTK
I've had and continue to have set-backs with health so work on Delta has crawled. But did manage to fit the equipment in it over the long holiday (except did not maiden Delta yet)...
It's a larger monoplane thanwhat we normallysee in pattern, (exceptingthe biplanes and triplanes), at 1150 square inches of wing.
A full 2 meter by 2 meter platform.
All paint, basecoat clear coat finish, over silkspanned and/or glassed wings, stabs and rudder.
DLE55 cc petrol engine on my own design soft mount. ES Composites 55G carbon pipe; hatori header plus extension. Mezjlik 20x12 3 blade carbon prop; TT 3" spinner. Thrust to weight ratio of 3:1 should be a blast to fly.
All up finished weight 4895 grams, which meets the original goal for this model..........
Photos will come as I take them.........Flight report after it happens......
Old 05-28-2013, 07:39 AM
  #153
Bpar4
MTK. Looking good!! Under 11#s is wonderful. Looking forward to your report. Bob
Old 05-28-2013, 08:25 AM
  #154
papaone
papaone's Avatar
Hello Matt
Congratulations. Under 5000 g with DLE 50 is incredible !
What is weight of the engine ?
Claude
Old 05-28-2013, 10:43 AM
  #155
MTK
ORIGINAL: papaone
Hello Matt
Claude
Thanks guys....
Claude the DLE55 is not the stock engine you buy. In earlier pages I show the reworked engine I'm using. With the help of a machinist friend we removed about 3 1/2 ounces of dead weight off the engine.My engine weight is 2 lbs 12 ounces, or 44 ounces. Compared to the OS GT33, that's 10 ounces heavier. In additionthe supporting pieces which include pipe, header, prop, prop bolts, soft rubber iso mount, longer stand offs andcouplers, add another 7 ounces over the same parts used on the 33.
HadI used the OS GT33 from the start, the plane would have been less than 10# RTF. It would have flown like a feather tho with that much wing area. Regardless, that's a great number to work towards on the next Delta, with slightly smaller wing area. Remember, I built the mold for the model in the early pages so I can make another copy anytime. But first I need to see what this one needs to fly right
The powerplant hadbeen run extensively in an Extra (about 25 hours run time). The piped set-up is well understood and of course, fully broken in.
Old 05-28-2013, 11:07 AM
  #156
flyncajun
Very good effort Matt!
Now you need to do this on a 2 meter Bipe with a 50cc
looking forward to pictures
Bryan
Old 05-28-2013, 11:26 AM
  #157
MTK
ORIGINAL: flyncajun
Bryan
We may want to work on that project together Bryan. Would have to build 2, 2meter wings at about 600-650 squares a piece, each weighing12 ounces RTF....
Some Control line Stunt guys (Bob Hunt) routinely build 700 square inch wings that weigh 7-8 ounces (all paint except open bay), so I doubt that would be a big challenge
Didn't the Argentinian guy say his friend had done that already? A bipe with a 50cc is no biggie except don't know about his weight
But heck, why stop at 2 planes? The next step is a precision aerobatictriplane. CPLR is already flirting with it, with good reason!!
Old 05-28-2013, 05:11 PM
  #158
cmoulder
ORIGINAL: MTK
That is truly an incredible accomplishment!!
Old 05-29-2013, 06:17 PM
  #159
MTK
ORIGINAL: cmoulder
ORIGINAL: MTK
Bob, you have been steadfast in your support for this project. I am grateful!! Thank you!
I am currently away from home on business but when I return I will post the last several photos on this project. Time to move on...........
Old 05-31-2013, 02:59 AM
  #160
tele1974
MTK will the new DA-35 be on your bench for testing next. Just curious if its going to be a good power plant for pattern?
Old 05-31-2013, 08:53 PM
  #161
MTK
I really like the OS GT33; I have several of them....... It has everything we need for the highest levels of pattern. No reason to go to anything else at this time except a rear exhaust configuration OS GT33.
Old 06-02-2013, 07:44 PM
  #162
MTK
No maiden yet.....Been away on business. Also the constant nagging leg problems are persistent, taking the fun out of it for me. Haven't flown in 6-7 weeks.....
Did manage to start the DLE this afternoon. I love petrol stuff for it's lack of rust and general lack of maintenance requirements. The engine had been on the shelf the better part of 2 years, yet, after a slight amount of coaxing (15 flips maybe) it came back to life. Powerwise, all I gotta say is awmygoshki....It's gonna be fun
Four pounds of powerplant
ID:	1888429   Click image for larger version
Old 06-02-2013, 07:47 PM
  #163
MTK
A few Delta snaps. I pay particular attention to fits. Here are the cowl and canopy
ID:	1888431   Click image for larger version
ID:	1888432   Click image for larger version
ID:	1888433   Click image for larger version
Old 06-02-2013, 07:49 PM
  #164
MTK
Double post
Old 06-02-2013, 07:53 PM
  #165
MTK
Snaps. Simpler paint job is lighter. I may change some gold areas for white at some point, if I can't see the model
ID:	1888435   Click image for larger version
Old 06-03-2013, 01:25 AM
  #166
Jetstream
Very nice work! Looking forward to flight report.
Old 06-03-2013, 03:02 AM
  #167
cmoulder
Just 3 words: FA BU LOUS!
Hard to conceive that it could be kept under 5kg with that powerplant and such a rich-looking paint job.
You're gonna have it at Pocono, right??
Old 06-03-2013, 04:43 AM
  #168
danamania
Very exciting Matt! Good luck with the finishing touches & first flights.
Old 06-03-2013, 08:56 AM
  #169
MTK
ORIGINAL: cmoulder
Thank you!
On the paint job, look from 5 feet away. It is very sheer and can just about see through it in spots. But it accomplishes the intended task
Poconos....don't know if I'll feel up to it, but I'll try, regardless of how the CD feels about my gas efforts
Old 06-03-2013, 08:57 AM
  #170
MTK
ORIGINAL: danamania
Thank you
Old 06-03-2013, 05:36 PM
  #171
maustin
My Feedback: (7)
maustin's Avatar
ORIGINAL: MTK
Matt, what paint did you use? Colors looks good together!!
maustin
Old 06-03-2013, 07:36 PM
  #172
MTK
ORIGINAL: maustin
ORIGINAL: MTK
maustin
Met blue and met greek gold were polyurethane, Omni. The others were Klass Kote epoxy
Old 06-07-2013, 07:11 PM
  #173
MTK
ORIGINAL: cmoulder
Bob,
I got a little ahead of myself. I forgot the CDI unit in the 4895 gram figure. Adding that module put me right at 5 Kg.
Here are some more snaps of the finished and equipped model. The tank set-up is the typical 2 line set-up that is so simple, even I can do it. The vent is simply wound around the tank's stem and the feed line is tee'd. So many folks flying gas insist on complex solutions for fuel systems........
ID:	1889771   Click image for larger version
Old 06-07-2013, 07:19 PM
  #174
MTK
Radio set-up. Neatness counts. The grommets are standard rubber types that do the job of wire protection just great.
The IBEC, VReg and RX are velcro'd in. Come to think of it, so is the tank and battery. I like the battery up top for easy access. I remove the LiPo from the airframe to charge
I've used eye screws to set-up pull pull forever. These are standard McmasterCarr issue
ID:	1889773   Click image for larger version
ID:	1889774   Click image for larger version
ID:	1889775   Click image for larger version
ID:	1889776   Click image for larger version
Old 06-07-2013, 07:33 PM
  #175
MTK
Engine treatment.....
I didn't take any snaps of the rubber iso mount and the nose ring arrangement. I have photos of those set-ups early in the thread
I've discussed the coupler arrangement before. It is molded (shaped to fit) from ceramic and Permatex Ultra Copper. The plastic tie wraps are plenty to hold them in place without melting (spun alumina is a great insulator). Should work well on YS exhaust too
The spark plug wire usually comes with a spring clip that is a total pita to work with. My solution is to toss the spring clip and add a short length of silicone rubber. It holds great but allows simple plug cap removal
ID:	1889795   Click image for larger version
ID:	1889796   Click image for larger version
ID:	1889797   Click image for larger version
ID:	1889798   Click image for larger version
ID:	1889799   Click image for larger version
ID:	1889800   Click image for larger version
