OS 1.60 for a 2x2
Old 01-28-2012 | 03:20 PM
RC_Pattern_Flyer's Avatar
Default RE: OS 1.60 for a 2x2
Its a winner tho. The pentathlon is contest proven.
Chuck
Old 01-29-2012 | 07:53 PM
flyintexan's Avatar
ORIGINAL: flywilly
What pipe is he running? And what pipe length (plug to first baffle)?
Thanks!
Excellent craftsmanship, by the way
Flywilly,
Hatori header (shorter than most others and has a 3/4" diameter outlet).
ES 2 stroke pipe - 20.5"long (2" OD), 3/4" diameter inlet. I believe it to be ES #ES2C140S80
1/16" gap between header and pipe.
Viton coupler.
No tuning required.
Low needle, 1/8 turn open from stock.
Best Regards,
Mark
Old 01-30-2012 | 07:40 AM
My Feedback: (121)
Thanks!
-Will
Old 01-30-2012 | 11:01 PM
KeithB's Avatar
ORIGINAL: dhal22
It isn't the prettiest plane in the world though.
Like Chuck said, it's NATSproven placing in the Masters finals multiple times. Also, given the right paint scheme it can look pretty good. Here's mine.
Keith B
ID:	1721437   Click image for larger version
ID:	1721438   Click image for larger version
Old 03-03-2012 | 08:21 AM
FWIW, I've an OS 160 that's available.... has a Boca SS rear bearing, the Perry pump and nipple installed on the backplate. Been bench run only 15 minutes max for break in purposes. It's probably not going to be used by myself as I've had to downsize my planes to 110 size max so if someone needs it, gimme a shout and we can work out a fair deal for both of us...
Mark
