post some pictures of your pattern plane!!
#901
RE: post some pictures of your pattern plane!!
Flyntexan -Power is Plettenberg Advance 30-10 with Spin 99 speed controller and Falcon 21*14 v2 prop/ spinner. Very nice combination.
MTK Thanks for suggestion will investigate
Bill
Bill
#902
Elexant, from f3alorenz.de/JM Composite.
All glass model, ARF painted in the mold
Graupner BLS HV-servos
Plettenberg Advance/O.S. 1100 ESC
Futaba HV-receiver
PT Model 20x13 prop
More pics: http://www.flickr.com/photos/aerowol...7630776640992/
Futaba HV-receiver
PT Model 20x13 prop
#903
ORIGINAL: Malydilnar
My dad and I have our own biplanes!
We call them Sting Bi and they are my dads very own, cad designed pattern ships. Everything is cut out with our own cnc router. They have elevator and top wing adhedral, and are the best flying airplanes I've ever owned. My dad owns the first version, which is powered by a ys 175. It weighs approx 4900 grams. My biplane is redesigned to be light, and is powered by an electric neu f3a motor and supports 5000mah hobbyking batteries. rtf weight is approx 4150 grams A new full composite design is in the works...
Do you have files/plans/parts, or whatever that you can share or sell?
(not that I can afford to build anything at the moment )
#904
ORIGINAL: FSFLYER
Going to try either the DLE 35R or PTE36 with an ES 40cc carbon pipe in an old Piedmont Focus II as a test bed. Both engines appear to be about equal in weight. Not sure which to go with yet...leaning toward the DLE. I was looking to do something similar with the Vanquish also....How do you plan to work the pipe into it? Did a L'Essence some years ago and had to mold a Carbon Fiber pipe tunnel ....maybe something similar would work on the Vanquish.
I have 10 flights on the PTE36R/Vanquish combination. There is more than enough power there. Not as much as an OS33GT but enough for the job at hand. I had mentioned to Claude (Papaone) to use the Mintor 38cc aluminum pipe which is what I'm using in the Vanquish. The combination is quieter then the muffler but noisier than the ESComposites pipe. The exposed pipe also contribute to the noise footprint but aluminum is ringy naturally.
In contrast, my OS/ESComposites combination is fully enclosed, turning larger propellers and is whisper quiet.
Will be testingthe DLE35RAin Vanquish next year. Good looking engine form the outside
#905
WA
We don't have plans at this point, as our next version is being built right now, but we'll see how it turns out next year with plans or selling a kit. The plane was designed on solid works by my dad, and all of the parts are cut by our cnc router, so a kit couldbe a possibility for the next year.
#908
Hello
On French Championship 2012 Illian Soustelle won National B serie (similar Master serie) and Leo Heckmann won National A serie (similar Advanced serie).
Illian is 18 years old and Léo 13 years old. They have same coach Loic Burbaud. Leo is proud to pose with French team.
Claude
Claude
#909
My Feedback: (25)
Very nice pictures, Claude!
It appears as though you are supporting several young flyers with your airplanes, that is fantastic! You are a very generous man.
#910
Hello Ryan
Thank you very much Ryan.
I forgot to write than CPLR won FAI serie (25 th time) and every champion won with plane equiped with Yamada.
Do you have building projects for this year?
Some pictures?
Claude
Some pictures?
Claude
#913
My Feedback: (25)
Hi Claude,
Did BPLR fly this year? It is very good to hear of the strong support Yamada has with F3A in France.
I don't have much for myself at the moment. My work with Horizon Hobby keeps me very busy. I built the prototype Splendor for Quique last year as well as recovered my ExtremeFlight Vanquish F3A. This year I will work to have two Partners (one from QQ, one "new") flying and go to as many contests as I can. I have made arrangements to fly in our national championships for the first time since 2007.
I do want a building project, and I have slowly been working on building a Harmonie. When I start, I will send you pictures.
Best regards,
Ryan
Best regards,
Ryan
#914
Hi Ryan
We did'nt see Benoit on selection contests and championship this year.
I built another Passion for a friend Eric who wanted same design as my Harmonie and I'm painting it.
Last picture is before painting name and varnishing.
Claude
Claude
#915
Nice work Claude...
Which engine is the one shown? Is it piped or canistered? Which prop?
Merci,
Matt
Merci,
Matt
ORIGINAL: papaone
Hi Ryan
Hi Ryan
#916
Hello Matt
Engine is RCGF32, header is Hatori GSA 30 (same as OS 33GT), exhaust tuned pipe is Webra.
Friend of mine Stéphane Bernard with same engine/header/tuned pipe uses APC 20x10,5 RPM is about 7200 t/mn and APC 20,5x10 RPM is about 7000 tr/mn.
Lenght between engine and tuned pipe is 740 mm / 750mm.
Claude
Claude
#917
Thank you....
I've seen Stephane's data and graph before. The RCGF32 is more than adequate for the job of flying pattern sized models.
The pipe looks small. I can only wonder if the RCGF was run on the ESComposites pipe what the output would be. But I'm sure you have found that the full top end is hardly ever used to fly 2m Pattern
#918
CA
My fleet of World Models' 40 size e pattern plane, good for winter flying before the weather is warm enough for the 2 meters again.
Adrian
Adrian
#919
#920
CA
ORIGINAL: Rune
Winter flying??? where is the snow??? hehe
10 degrees C is cold for us ...
Adrian
#922
CA
ORIGINAL: apereira
Adrian,
Which one feels more like a 2M for F3A?
Regards
Alejandro
Adrian,
Regards
Alejandro
Adrian
#923
[quote10 degrees C is cold for us ...
Adrian
][/quote]
10 C ....ok ok..... coldets so far this winter is -29 c...but not flying then
Adrian
][/quote]
#924
ORIGINAL: Jon Wold
Futaba HV-receiver
PT Model 20x13 prop
Futaba HV-receiver
PT Model 20x13 prop
Thanks, Volkert
