Flying Intermediate - Questions
Old 08-28-2013 | 07:05 AM
My Feedback: (10)
Default Flying Intermediate - Questions
Set Up:
2M Monolog
Hi-Max 6330-210
ICE II 80HV
APC 21x14.5
Two 5s, 5,000mAh
Flying Weight - 5,040g
Getting better acquainted with the 2M Monolog and plan to attend the Huntsville, AL contest in a couple weeks Sept 14/15...
There is nobody close to help with coaching so, I have questions about Intermediate...
What is a normal flight time for the sequence?
I flew two sequences in a light cross wind (5-10mph) and both flights were very near 6 minutes each from timer on (switched with the idle down function and prop turning before takeoff) to timer off at final approach for landing.
First pair of batteries I replaced 2,850mA (+/- 50mA) each; and, the other set I put 2,890mA back in one and the other I put back in 3,085. I might need to match up the batteries with regard to IR and keep them as a pair.
This seems kind of low on energy consumption and flight time… Probably need to work on getting bigger radii in the Reverse Cuban, Double I, and the Humpty Bump (Pull/Push/Push). Seems like my maneuvers could be taller and a bit slower…
Looking forward to your thoughts... :-)
Going to the field again this after-noon for more practice... :-)
Old 08-28-2013 | 07:52 AM
smcharg's Avatar
Larry,
Actually, I think you're right on. Your power consumption appears to be average running that prop and motor if not a little high for a 6 minute flight (this can change due to throttle and speed in the air / size of maneuvers at a given distance ). In Advanced, I was burning about the same 2700-2800mah avg. and Masters is consuming 3200ish avg. for me depending on winds.
Regards,
Old 08-28-2013 | 07:54 AM
My Feedback: (45)
Larry,
You seem to be right where I would expect with that setup. I know a lot of people in Intermediate and Advanced are going with 4400 mah packs as they never use more than 3200 or so.
Arch
Old 08-28-2013 | 09:14 AM
My Feedback: (10)
Thanks for all the responses...
FWIW... Although I attended the Weak Signals contest this past June 1st/2nd, I didn't log an official flight...
Last official contest flight - September 2010 (Zen 50)
Last official contest flight with a 2M Pattern Plane - September 2007 (Focus I)
Nice to get back into Pattern...
Larry D.
Old 08-28-2013 | 10:42 AM
For what it's worth, flight times for the Master's sequence for me in calm to light wind averages 7 mins 30 secs. Running 2 TP 5,000 Mah 25C packs and putting back 3,000 - 3,250. When windy, averaging 3,400 - 3,550.
Steve
Old 08-28-2013 | 11:25 AM
As Arch and Scott have already said, your numbers are right on the money. I'm flying 4400's and usually use between 2800 and 3200, depending on wind and maneuver size. I sometimes go as low as 2300, but that means I flew too slowly.
My buddy Bill uses more like 3400 on an average flight but he's using a different setup in a heavier airplane and is still not where he needs to be with throttle management.
Scott
Old 08-28-2013 | 11:43 AM
Larry,
Like you, I'm returning to pattern and have decided on a 2M Monolog with same Motor/ESC as you. The only difference is I have a 20.5 x 14 prop.
I'm flying the Advanced sequence and am running 6 min. flights and burning out approximately 3150 each flight. I'm running 2 5S 4500 packs. Seems like the perfect combo for what I need. Good luck in Huntsville next month!
Kevin
Old 08-28-2013 | 02:11 PM
Hey Larry , Glad to hear you are going to Huntsville .I will be there on Thursday if all goes well. It is a very well run contest . There will be several great coaches around and everyone is willing to help. Look me up when you get in I will be the one flying a Monolog LOL LOL
See you there. Kirk
