P-15
Old 09-02-2013 | 09:33 PM
Enrique-F3A's Avatar
Default P-15
Name:	P15 (I-D).JPG
ID:	1916508   Click image for larger version
Name:	P-15 (D-I).JPG
Old 09-03-2013 | 12:51 AM
rm's Avatar
rm
My Feedback: (27)
I like that sequence.
Old 09-03-2013 | 03:12 PM
Old 09-03-2013 | 05:14 PM
My Feedback: (50)
Strange, no integrated rolling stuff this cycle?
Old 09-03-2013 | 05:29 PM
They left that for F15.
Old 09-04-2013 | 08:10 AM
is it possible to have the F15 with the left wind ?
Old 09-04-2013 | 02:51 PM
apereira's Avatar
Nop,
unless someone do it, the aresti is for reference, you should be able to do it with a caller in both directions, is really not difficult.
It could also be inverted with software wich can be done easily.
Old 09-04-2013 | 03:10 PM
Originally Posted by apereira
Enrique edited his first post with the schedule in the oposite direction.
Enrique posted P-15 with both wind direction, Andre12 is asking for the F.
Old 09-04-2013 | 03:20 PM
Try this, just mirrored so wording is backwards.
Old 09-04-2013 | 05:58 PM
My Feedback: (34)
The 6-point roll stuff is strange. 60 degrees is an unusual angle to visualize both for flying and judging. Everything else looks great!
Old 09-04-2013 | 07:24 PM
Alejandro. Would you, please, do it ? no reversed letters (for F-15)
Thanks in advance
Old 09-04-2013 | 08:51 PM
Some video of P 15 being flown by Jason Shulman and Onda-san can be found here http://fai-f3aworld.blogspot.com.au/
Old 09-04-2013 | 08:55 PM
apereira's Avatar
That is the most difficult maneuver in my opinnion as the points are not ussual
Old 09-04-2013 | 09:03 PM
apereira's Avatar
Thanks in advance
Dsnow just did it, and the text is not really neccessary, but you can write them by hand if needed, I for example, printed and wrote the K factor on each maneuver on both P and F.
Old 09-05-2013 | 07:11 AM
I saw it flown a few days ago and must say it looked surprising. But just think equilateral triangle and it works, imho.
Bill
Old 09-05-2013 | 09:45 AM
My Feedback: (34)
Bill
90 degree points are easily identified, but I think a 60 degree bank is going to be incredibly hard to judge accurately.
Old 09-05-2013 | 10:06 AM
apereira's Avatar
Exactly, it is very easy to do as you can actually keep the same rudder input, is how it will have to be done to get the points, and the obvious " it has to be done right" does not always apply as most judges who do not fly will not "see" the points clearly as well as the keyboard pilots, in my opinion.
Old 09-05-2013 | 02:06 PM
The six point rolls looks amazing with a biplane, as you can really see the points and the wings hold 60 and 120 degrees
Old 09-05-2013 | 02:52 PM
I agree, 60deg points adds no technical challenge to the pilot but increases the chances that if flown smoothly and gracefully that it "has to be right" which would encourage impression judging.
Old 09-05-2013 | 06:18 PM
Andre, here it is
Name:	F-15 (I-D).JPG
ID:	1917121   Click image for larger version
Name:	F-15 (I-D)E.JPG
Old 09-08-2013 | 01:57 AM
thanks a lot Enrique.....wish you very good flights
Andre
Old 09-08-2013 | 11:26 AM
My Feedback: (28)
Been watching a fair amount of P-15 the last few weeks and found it helpful to look for the 60deg pt as 15deg past 45, and then using that same 30deg angular displacement from wings vertical as the reference for locating the 120deg point. Wow, it's easier to think about than describe it!
Old 09-12-2013 | 07:38 PM
60 degrees just does not make sense hard to see and hard to judge. Ever heard of 60 degrees knife edge flight? Of course not it would be a 2 point downgrade to start.
