SENSATION +, Build Thread by ISAAC NAJARY
#56
I have used micro glass (18 gram/meter) with epoxy many times, but after using the silk with sanding siller (10 gram/meter) I will never go back to the micro glass!!!
The weaving of the silk is much denser so you do not have to use so much material to fill the holes in the fabric.
Sanding the sanding siller is easier than sanding the epoxy, and if you sand too much and go through the fabric; with the micro glass and the epoxy it is very difficult to fix that, but with the silk you even don't fill it, maybe because the balsa and the silk are both organic materials.
Here is a link to a shop in Japan, just send them an email, they deliver worldwide [email protected]
ƒtƒ‰ƒCƒgƒzƒr[»ƒVƒ‹ƒN
Best regards,
Isaac Najary
#63
It is some thing like this:
https://plascon.com/products/product...sanding-sealer
Best regards
ISAAC najary
Best regards
ISAAC najary
#68
Hi mr Najary
Have one question re. You did change the incidence angle on both wings. What was the original incidence and why do you change it to aparently cero incidence?(Asume that the datum line is motor center and stab cord centerline)
Thanks and regards!
Thanks and regards!
#69
Hi,
I didn't change the the incidence angle on the wings that is the way it come from the kit manufacturer, it is a ARC kit.
Best regards,
Isaac Najary
Best regards,
Isaac Najary
