What spinner adapter ??? help !!!
Hi
I would like to know what spinner adapter are you guys using with the Truturn 2-3/4 FAI spinner mounted on a OS 140 RX or Mintor 170. This spinner is very short !![
anyone know the length of the TT-0522-A truturn adapter
Best Regards
Fernando Viollier
] anyone know the length of the TT-0522-A truturn adapter
Best Regards
Fernando Viollier
The 170 comes with a spinner adapter nut/washer, but not the bushing for the backplate.
The OS is 24 MM long, and the TT-0522-A is the correct # for it...it will work on the 170 as well.
-Mike
-Mike
And by the way, it will work....but you may need to grind some off the adapter nut for it to work if you are using a prop with a large hub. I have done it before using a Bolly prop, it worked just fine.
-Mike
-Mike
Mike
thanks for the info, I'm using an APC 17 x 13 prop, the problem is the Mintor Adapter is too long to use with this spinner.
Regards
Fernando V.
Regards
Fernando V.
My Feedback: (8)
I spoke with Tru-Turn about this exact question Monday. (for the OS140RX) They said to order a part #TT-0523 "special adapter" at $8.95. They said that it "should" work depending on the particular prop. I will post my results when it arrives
My Feedback: (8)
I received the adapter today....it is about 1/32 too long still. This is with an APC 16-14 and APC 17-12. Not a problem, just need to take off maybe 1/16 to be sure the nut does not interfere with the spinner cap. It took maybe 2 min with a dremel, and all is fine now. The part number is TT-0523-A at $8.95
