CAPRISE CG
Old 07-11-2004 | 04:36 PM
Default CAPRISE CG
Anyone know where the centre of gravity should be on a zn line caprise.
Old 07-11-2004 | 06:31 PM
Schpankme's Avatar
Default RE: CAPRISE CG
Searching the Archives shows - if your wing chord root is 450mm - then the CG setting is 180mm from the leading edge.
ZN seems to stick their CG locations all about the same spot.....
Fashion, Caprise, Alliance, Synergy, Hydeaway all have the CG about in this location - "tnewman"
http://www.rcuniverse.com/forum/m_11...tm.htm#1139496
__________
Schpankme
Old 07-11-2004 | 07:19 PM
hello!
all velcome to to correct me!
before ...15 years ago..we always belive the CG to be 33% of the lenght off the wingcord from front at the middel off the wing .?
did i explain unclear?
