Which YS 160 engine mount?
Old 12-29-2004 | 06:11 AM
Luke 3D returns's Avatar
Default Which YS 160 engine mount?
Hi Guys,
I am looking at getting one of these mounts. I am not sure which one is better for my new 160Dz.
The lin to the ZN LINE mount is here.
http://www.znline.com/produits.php?l...ata=1062018030
Here is the hyde
http://www.probuild-uk.co.uk/product..._id=12&man_id=
Any experiences with these mounts or others that are also recommended would be very much appreciated.
Thanks very much
Luke
Old 12-29-2004 | 11:36 AM
My Feedback: (48)
Default RE: Which YS 160 engine mount?
I like the ARA type Hyde mounts. They are small, have aluminum beams with only two bolts, are very light and very effective. The ones shown on probuild are not the ARA type. See http://www.centralhobbies.com/Engine...ydemounts.html , second to left.
David
Old 12-29-2004 | 02:58 PM
Thanks for the reply.
Does that one require a nose ring?
Old 12-29-2004 | 06:49 PM
I like AR or ARA type Hyde mounts.
Yes.... they are very effective.
Both types require nose ring.
Good Luck~~!
Old 11-28-2005 | 01:26 PM
papaone's Avatar
Hi
have you any experience with this mount (Yamada 140 or 160 Dingo) ?
Regards
Old 11-28-2005 | 03:44 PM
I have tried one of those with the incorporated nose ring. Unless the firewall is stiff enough, the engine flexes big time. I ended up retrofitting a regular nose ring in the front of the fuse, and problem solved.
Old 11-28-2005 | 04:51 PM
papaone's Avatar
Hi
Thanks riot3d.
I'm going to buy a standard Hyde mount with a ring which will be fixed on nose of plane.
regards.
Old 11-28-2005 | 06:07 PM
The Hyde ARA mount, with the alloy beams, is about 1oz lighter than the version with the glass/nylon beams. I have two, they are fabulous mounts and very light. I wouldn't use anything else.
James
Old 11-28-2005 | 06:09 PM
link to the central listing - http://www.centralhobbies.com/Engine...s/hydmnts.html (think there is a typo in the one given above).
James
Old 11-29-2005 | 08:09 AM
I also have that mount on the 160. Its a great and very light mount. you wont find anything better in my opinion( or more expensive!)
Old 11-29-2005 | 09:52 AM
My Feedback: (7)
Hey guys.
Does the ARA mount only use 2 mounting bolts instead of 4?? Is it already predrilled?
thanx in advance.
No one mentioned the mount from Gerry Budd. Any experience there. Had heard they were lighter and less $$.
ed
Old 11-29-2005 | 01:24 PM
Check this one out. Very nice, very expensive and very practical! Note the thrust angle adjustment... thats a real pain adjustment with any other type of mount... including Hydes.
You just loosen the three bolts holding the fire wall mount to the triangle enging bracket, slide it either way and then tighten 'em up again.
If adjusting your right thust is your thing... you'll be doing it all over yourself with this baby. Yippee.
Old 11-30-2005 | 07:37 AM
The ARA mount uses one bolt per side, as the alloy beams are so much stronger than the nylon ones. They come pre-drilled with bolts (as it should at that price!).
It doesn't seem like much to hold the engine but it does work very well indeed.
James
Old 11-30-2005 | 09:11 AM
papaone's Avatar
Hi Divesplat
I think you speak about this soft mount showed below : Cost = 60 § and weight = 3,5 oz =85 g
This mount is cheap and light
http://www.buddengineering.com/Merch...tegory_Code=MM
Old 11-30-2005 | 10:51 PM
SCJ
bla bla,
Mount looks really nice. What is that mount called, where can it be bought and how much does it cost.
Old 11-30-2005 | 11:54 PM
My Feedback: (7)
Thanx Papaone
That is the one I was thinking of.
ed
Old 12-01-2005 | 04:07 AM
SCJ.
It's available from ZN, at ZN prices. For a nice guy like you say, 240 Euros!!!!!!
I'd be looking to modify the super cheap Budd mount to function in a similar way (right thrust adjustments I mean). Shouldn't take long in the work shop.
Heres another Hyde type, from BN models in Turkey. Seemly it's made in Canada... and cheap. I have one, it's very nice.
Old 12-01-2005 | 06:48 AM
Angus Balfour's Avatar
The Budd Engineering mount is the one included in the X-Treme Astral XX kit.
Old 12-01-2005 | 09:04 AM
papaone's Avatar
Hi Bla Bla and SCJ
Pascal Nowik told me this support is not any more sold by ZNLine. It's replace by this one cheaper (125 Euro) !!!
Bla bla, what's price about BN Model soft mount and delivery times, thanks.
Old 12-01-2005 | 09:16 AM
It's made by NB engineering and is/was a lot more expensive than I thought $99. I payed nothing for mine, it's included in BN kits!
Here it is anyway: http://www.nbengineering.net/accesories.htm
Looks like the Budd option is just fantastic. It's adaptable, it's light, you could do the right thrust modifiction trick to it and it's super cheap.
Dosen't get better than that does it?.
Old 12-01-2005 | 05:17 PM
papaone's Avatar
Hi
Another kind of mount : flex mount kato on wood support
