Excelleron 90 need info
Old 08-13-2007 | 08:18 PM
Default Excelleron 90 need info
I have an Excelleron 90 from an friend but need some info on it. The plane had been flown and is in excellent condition.
I will be using a Saito 125. I do not have any manual or other data for it.
What are the recommended control throws?
What is the recommended CG settings for the plane?
Anything else I need to know?
Old 08-13-2007 | 09:08 PM
Default RE: Excelleron 90 need info
Start reading
http://www.rcuniverse.com/forum/m_23...elleron/tm.htm
Old 08-13-2007 | 09:52 PM
MikeRuth's Avatar
That's a lot of reading, and I have read it all. LOL
7 1/2" is the CG most people like on this plane.
As for the control throws, I think about 10MM up and down are good for the ailerons and elevator and some more on the rudder.
If I get a chance I'll measure mine and let you know if you don't get it in the air first.
Great plane, what engine did you get/put in it.
Mike
