Which soft mount?
Old 11-06-2007 | 11:16 PM
Default RE: Which soft mount?
Mike
In my earlier post I was actually asking about the ARAs (ally beams). They are almost an once lighter and will help with the Integral nose heavy tendancy. These are also rated at 70% current drain reduction. Can you explain how the new AR70 is better?
Colin.
Old 11-07-2007 | 12:09 AM
amram's Avatar
Yoav, you buy Radio South Mark III ProDriver. You put a simple cable switch on the ProDriver cable.
With one hand You hold the airplane while the switch is between your fingers. You start spinning the motor 1 sec and
then switch on the switch and that all. Come to the filed and see - Me and Itzik are using this techniques all the time.
Enjoy.
Amram
Old 11-07-2007 | 01:28 AM
Thanks guys, I think the picture is clear now.
Yoav
