Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Best servos for 2m pattern plane? >
Old 02-04-2009 | 11:47 PM
underdw's Avatar
Default Best servos for 2m pattern plane?
Hi guys,
I'm looking to upgrade the older analog servos in my CA Fantasy with higher quality and better centering digitals. I have 1 servo on each aileron, and 1 driving both elevator halves. (I downsized the control surfaces, because I won't be doing artistic aerobatics, only Masters/F3A) I have a Hitec 5955 on the rudder, which I'm satisfied with.
Suggestions for aileron and elevator servos?
Dan
Old 02-05-2009 | 01:24 AM
Default RE: Best servos for 2m pattern plane?
What radio are you using? JR? Hitec? Futaba? Airtronics?
Old 02-05-2009 | 01:25 AM
My Feedback: (25)
Dan,
I like the JR DS9411SA for ailerons, and the JR DS3421SA for the elevators, providing you've got dual elevator servos in your airplane. Since you're running one servo, then the JR DS8411SA will do the job nicely.
Old 02-05-2009 | 09:35 AM
I am going to have to 2nd Ryan on that post because that is the same set up I use and it works very well; JR is the way to go. I use that set up on all my pass ports, including the 3rd one I will be recieving in a couple of days.
Matt L.
Old 02-05-2009 | 10:31 AM
My Feedback: (45)
Dan,
As long as you stay with the big 3 brands, Futaba, JR, or Airtronics, you'll be fine. Kind of the Chevy v Ford arguement. For Futaba I use the BLS-451 for aileron and elevator (with one elevator servo), or 9650's for dual elevator servos. You'll be happy no matter which brand you buy.
Arch
Old 02-05-2009 | 04:40 PM
Futaba S148's [sm=punching.gif]
Old 02-05-2009 | 05:20 PM
Only if they have the ball bearing conversion.
Old 02-06-2009 | 02:39 PM
cdodom's Avatar
I use JR ds821s on the ailerons for my Black magic and 8411sa for elevator and an 8611sa for rudder. they all seem to hold up to the Vibrations of the YS DZ
Chris Odom
Old 02-06-2009 | 03:44 PM
I am electric not gas, but I believe that the JR DS 9411's, and 8411's are a prime choice for flying either glow or electric.
Matt
Old 02-07-2009 | 11:17 AM
Nathan King's Avatar
Hitec should not be overlooked. They have some nice offerings. I personally find their 7000 series coreless digital servos to have outstanding centering, resolution, speed, and torque.
Old 02-09-2009 | 02:47 PM
No...No....they really should be[sm=punching.gif][sm=lol.gif]
Old 02-09-2009 | 09:36 PM
My Feedback: (45)
When Hitec servos are compared to JR, Futaba and Airtronics there servos do not center well. Even the best of their servos.
Arch
Old 02-09-2009 | 10:12 PM
Okay, perhaps only flying intermediate I'm not precise enough to tell.
Old 02-10-2009 | 01:48 AM
patternflyer1's Avatar
I agree, you will be able to tell centering issues regardless of the brand. Hitec has many complaints of this. Still, you could get the lucky ones.
Stick with the big three, you can't go wrong that way.
Chris
Old 02-10-2009 | 08:55 AM
underdw's Avatar
Thanks to all who chimed in! It helps to have the options narrowed down. I can take the suggestions and compare speed, torque, price, and make my decision now.
Dan
Old 02-10-2009 | 01:39 PM
Yes Yes to Archie and Chris. Exactly what I would have said. Stick with the big 3. JR, Futaba, and Airtronics.
Matt
Old 02-10-2009 | 04:55 PM
Nickolas's Avatar
I have been using a mix of Futaba and JR.
On Integral 2xJR 9411SAs on Ail, 2xFutaba 9650 on El, 1 x 8411SA on Rud, 1xFutaba 9650 on Throttle
On Proline (not flown yet) 2xFutaba 9154 on Ail, 1xFutaba 9250 on El, 1 x 8411SA on Rud, 1xJR 3421SA on Throttle
There are plenty of choices, the most unique ever seen was on Seba's biplane Miss Wind, he was using the latest robot servos from JR. I guess he knows and there is some rationale behind it.
I believe most common and reliable standard in pattern is the 8411SA or 8401 (plastic). These servos are relativelly slow but powerfull enough for every surface. Stephane Carrier the designer of Integral uses them (8401) on all surfaces, after watching his practice and official flights I ended up that the best servos for pattern are in the thumbs...
Old 02-10-2009 | 08:37 PM
underdw's Avatar
ORIGINAL: Nickolas
Well said!!!!! Too bad I can't just spend money for better thumbs!
Old 02-11-2009 | 03:19 AM
Oh, but you can spend money for better thumbs.. There are several out there that will be glad to take your money for lessons...
