contest balsa weights?
Old 04-10-2010 | 10:23 AM
My Feedback: (12)
Default contest balsa weights?
Anyone know what 1/16thx 4 x 36 sheets should weigh or where to find out?
thanks
Old 04-10-2010 | 11:40 AM
Default RE: contest balsa weights?
9-16 GRAMS TYPICAL
GARY
Old 04-10-2010 | 11:47 AM
My Feedback: (12)
Thanks, most of these are in the 11/12 gm range
Old 04-10-2010 | 11:57 AM
RC_Pattern_Flyer's Avatar
go to don ramseys pattern page and he has a great spreadsheet on weights for many things.
Chuck
Old 04-10-2010 | 12:05 PM
My Feedback: (12)
Thanks I will, I am starting the skins for the Hindsight
and want to make sure I start off light
Old 04-10-2010 | 02:49 PM
Everytime i glue something on i try to figure out if it is what is neeed or overkill.
My first Insight with OS 160 was 10 lbs 4 oz without trying.
Chuck
Old 04-10-2010 | 03:04 PM
My Feedback: (12)
most of the wood I got is very light and strait, according to the weights on Don's sight my skins are out of 5# balsa and took very little sanding to true the edges
Old 04-10-2010 | 04:37 PM
Nice, where did you order from?
Chuck
Old 04-10-2010 | 04:49 PM
My Feedback: (12)
Lonestar
Old 04-10-2010 | 08:37 PM
My last Lone Star order was pretty good as well.
The average density on the bundle of 42 sheets of 1/16 was over 7#. But if I removed the 5 heaviest sheets, then the average was easily under 6#. Not bad overall...
If you can do wing skins from 5# sheets, AND you mind your glue weight, LE/TE weights, wing root weight, servo mount weight, linkage weight, etc...you have a real good shot at some pretty light wings. If you get under 14 oz flying weight with film covering it's very good. With care under 13 oz flying weight is possible!
Richard
Old 04-11-2010 | 07:23 AM
My Feedback: (12)
the LE/TE stock is pretty good too, if I can get the Gorilla glue on correctly they should pretty light
Old 04-11-2010 | 08:15 AM
If your wings are for a 2 meter plane use 10 to 12 grams of glue per side per core. Keep it as lite as possible. There's a gentleman I believe in Nebraska that has a step by step method of sheeting wings. This should give some ideas to help you. I don't do everything he does but it's good info.
Larry
http://mackrc.net/patternwings2/index.htm
Old 04-11-2010 | 08:48 AM
My Feedback: (12)
these are for a 2M plane, I asked Mark Hunt to round off the Insight and he did, he also liked it and changed a couple of other things and now he calls it a Hindsight, so I'm building the first one, should be a better plane than I am a pilot
as far as that sight goes I have read it a couple of times and there is some good stuff there, between my old techinique, that sight and some suggestions from Mark and Astropuppy I think I have it all figured out as to how I'm gonna do this thing
thanks
ID:	1416018   Click image for larger version
