CA MODEL ONAS BUILD
Old 05-14-2010 | 09:14 PM
Default RE: CA MODEL ONAS BUILD
Congratulations "Don" Tuny.
Aesthetic and precise work.
Federico Hinestrosa
Old 05-17-2010 | 10:23 AM
more.
tail structure done.
ID:	1437802   Click image for larger version
ID:	1437803   Click image for larger version
ID:	1437804   Click image for larger version
ID:	1437805   Click image for larger version
ID:	1437806   Click image for larger version
ID:	1437807   Click image for larger version
ID:	1437808   Click image for larger version
ID:	1437810   Click image for larger version
ID:	1437811   Click image for larger version
ID:	1437812   Click image for larger version
Old 05-17-2010 | 10:24 AM
one more....
Old 05-17-2010 | 09:29 PM
stabs.
leading edge is balsa and glued in with white glue, same for the tips.
as for the traling edge I made 1/16 balsa covers, and glued with thin CA
pics.
ID:	1438173   Click image for larger version
ID:	1438174   Click image for larger version
ID:	1438175   Click image for larger version
ID:	1438176   Click image for larger version
ID:	1438177   Click image for larger version
Old 05-20-2010 | 10:32 PM
more on the stabs...
ID:	1439603   Click image for larger version
ID:	1439604   Click image for larger version
ID:	1439605   Click image for larger version
ID:	1439606   Click image for larger version
ID:	1439607   Click image for larger version
ID:	1439608   Click image for larger version
ID:	1439609   Click image for larger version
ID:	1439611   Click image for larger version
ID:	1439612   Click image for larger version
ID:	1439613   Click image for larger version
Old 05-20-2010 | 10:35 PM
  #31
more....
ID:	1439619   Click image for larger version
ID:	1439620   Click image for larger version
ID:	1439621   Click image for larger version
ID:	1439622   Click image for larger version
ID:	1439623   Click image for larger version
ID:	1439624   Click image for larger version
ID:	1439625   Click image for larger version
Old 05-21-2010 | 08:49 AM
  #32
My Feedback: (41)
Anyone intersted in a deal on an ARC version?
http://www.rcuniverse.com/market/item.cfm?itemID=636431
Old 05-24-2010 | 09:44 PM
  #33
more...
ID:	1442016   Click image for larger version
ID:	1442017   Click image for larger version
ID:	1442018   Click image for larger version
ID:	1442019   Click image for larger version
ID:	1442020   Click image for larger version
ID:	1442021   Click image for larger version
ID:	1442022   Click image for larger version
ID:	1442024   Click image for larger version
ID:	1442025   Click image for larger version
ID:	1442026   Click image for larger version
Old 05-24-2010 | 09:45 PM
  #34
and some more...
ID:	1442028   Click image for larger version
ID:	1442029   Click image for larger version
ID:	1442030   Click image for larger version
ID:	1442031   Click image for larger version
Old 05-27-2010 | 10:14 PM
  #35
more building on the stabs done.
opened the hole in the fuse for the stab sevo wire.
then cut the elevators to clear the rudder throw.
I will use MK control horns mounted on a 3/8 hardwood dowel, the hinges are Great planes CA hinges.
ID:	1443639   Click image for larger version
ID:	1443640   Click image for larger version
ID:	1443641   Click image for larger version
ID:	1443642   Click image for larger version
ID:	1443643   Click image for larger version
ID:	1443644   Click image for larger version
ID:	1443645   Click image for larger version
ID:	1443647   Click image for larger version
ID:	1443648   Click image for larger version
Old 05-28-2010 | 09:38 PM
  #36
stabs ready to cover (only final sanding missing) I'm verry happy, they both end the exact same weigth and very ligth
dubro ball links and clevises with 2-56 rod linkage.
then the tail wheel mount and the rudder post.
PD: the plane covers are very nice!!!
pics...
ID:	1444215   Click image for larger version
ID:	1444216   Click image for larger version
ID:	1444217   Click image for larger version
ID:	1444218   Click image for larger version
ID:	1444219   Click image for larger version
ID:	1444220   Click image for larger version
ID:	1444221   Click image for larger version
ID:	1444223   Click image for larger version
ID:	1444224   Click image for larger version
Old 06-01-2010 | 10:44 AM
  #37
more..
saded the ruder post in the fuse to have double bevel, then build up the rudder.
I will use a removable rudder, to make this I used du-bro large scale hinges, and a music wire replaces the pin. then a small cut in the fuse hides and holds in place the wire below the tail wheel.
pics...
ID:	1446288   Click image for larger version
ID:	1446289   Click image for larger version
ID:	1446290   Click image for larger version
ID:	1446291   Click image for larger version
ID:	1446292   Click image for larger version
ID:	1446293   Click image for larger version
ID:	1446294   Click image for larger version
ID:	1446296   Click image for larger version
ID:	1446297   Click image for larger version
ID:	1446298   Click image for larger version
Old 06-01-2010 | 10:46 AM
  #38
more...
ID:	1446300   Click image for larger version
ID:	1446301   Click image for larger version
ID:	1446302   Click image for larger version
ID:	1446303   Click image for larger version
Old 06-01-2010 | 10:40 PM
  #39
the wings.
leading edges glued with white glue, same for the tips.
the trailing edges are from 1mm balsa glued in with CA
I made the tip blocks hollow to save some weigth, as for the SFG same thing as in my Pass-Port, I dont like them, to me they LOOK terrible, I'm not saying they dont work. So... no SFG's to me. and I belive lighter tips help better snaps.
pics....
ID:	1446616   Click image for larger version
ID:	1446617   Click image for larger version
ID:	1446618   Click image for larger version
ID:	1446619   Click image for larger version
ID:	1446620   Click image for larger version
ID:	1446621   Click image for larger version
ID:	1446622   Click image for larger version
ID:	1446624   Click image for larger version
ID:	1446625   Click image for larger version
ID:	1446626   Click image for larger version
Old 06-04-2010 | 10:52 PM
  #40
more..
sanded the wing tips.
instaled end caps on the wing tube sleeves, I made them from 1/16 balsa glued with CA
then marked how much of the sleeves should be into the wings in order to reach the reinforcement rib on the inside of the wings.
finally glued the sleeves in with 30 min epoxy and lots of microballoons to make a very ligth and thick mix.
pics..
ID:	1448031   Click image for larger version
ID:	1448032   Click image for larger version
ID:	1448033   Click image for larger version
ID:	1448034   Click image for larger version
ID:	1448035   Click image for larger version
ID:	1448036   Click image for larger version
ID:	1448037   Click image for larger version
Old 06-06-2010 | 11:17 PM
  #41
more...
wing center rib glued in place, first sanded the wings to make a good fit with the fuselage.
then started mounting the wing adjusters, I moved their location about an inch to the back, this way the adjustment is more precise and the wing remains more solid.
pics...
ID:	1449293   Click image for larger version
ID:	1449294   Click image for larger version
ID:	1449295   Click image for larger version
ID:	1449296   Click image for larger version
ID:	1449297   Click image for larger version
ID:	1449298   Click image for larger version
ID:	1449299   Click image for larger version
ID:	1449301   Click image for larger version
Old 06-06-2010 | 11:18 PM
  #42
more...
ID:	1449307   Click image for larger version
ID:	1449308   Click image for larger version
ID:	1449309   Click image for larger version
Old 06-07-2010 | 02:50 AM
  #43
guille2006's Avatar
Hey Tuny; great job!!
A silly question: did CAmodel give any kind of manual for this kit? If so; is it in any format that you can share (PDF or so)?
Keep posting
Guille
Old 06-08-2010 | 10:00 PM
  #44
Thanks Guille, but no, as with any pattern plane, there is no manual.
more...
opened the holes in the fuse for the aileron servo wires and for the wing mounting bolt.
wing adjusters in place, wing bolt mount in place. (to this mount I added a couple of pieces of sandpaper to prevent the bolt from comming loose)
then installed the small tube for the adjusters on the wings.
pics...
ID:	1450387   Click image for larger version
ID:	1450388   Click image for larger version
ID:	1450389   Click image for larger version
ID:	1450390   Click image for larger version
ID:	1450391   Click image for larger version
ID:	1450392   Click image for larger version
ID:	1450393   Click image for larger version
ID:	1450395   Click image for larger version
ID:	1450396   Click image for larger version
ID:	1450397   Click image for larger version
Old 06-08-2010 | 10:02 PM
  #45
more pics..
A small hole on the bottom of the wings, just below where the adjusters tube goes, helps to glue it better
ID:	1450411   Click image for larger version
ID:	1450412   Click image for larger version
ID:	1450413   Click image for larger version
Old 06-09-2010 | 09:17 PM
  #46
more..
wing mounting bolts in place, they are mounted on a 1/8 plywood disc inserted on the wing center rib.
then I saved some weigth on the rib.
pics...
ID:	1450933   Click image for larger version
ID:	1450934   Click image for larger version
ID:	1450935   Click image for larger version
ID:	1450936   Click image for larger version
ID:	1450937   Click image for larger version
ID:	1450938   Click image for larger version
ID:	1450939   Click image for larger version
Old 06-10-2010 | 08:14 PM
  #47
cutted the ailerons... I used a 4mm cap on the wing and a 6mm cap on the aileron, I also continued the aileron all the way to the tip, this way I have a little more aileron surface that helps in better snaps.
pics...
ID:	1451322   Click image for larger version
ID:	1451323   Click image for larger version
ID:	1451324   Click image for larger version
ID:	1451325   Click image for larger version
Old 06-12-2010 | 03:17 PM
  #48
more...
ID:	1452023   Click image for larger version
ID:	1452024   Click image for larger version
ID:	1452025   Click image for larger version
ID:	1452026   Click image for larger version
ID:	1452027   Click image for larger version
ID:	1452028   Click image for larger version
ID:	1452029   Click image for larger version
ID:	1452031   Click image for larger version
ID:	1452032   Click image for larger version
ID:	1452033   Click image for larger version
Old 06-12-2010 | 03:50 PM
  #49
Jon Wold's Avatar
I'm learning a lot from this build. Keep it coming!
Old 06-13-2010 | 03:51 PM
  #50
Thanks Jon!!! I´m glad you like it.
aileron servo boxes and aileron control horns.
I moved the aileron servos a couple of inches to the fuse, this way the weigth is closer to the center and this helps in a more stable plane and easier to stop the naps. also you save a little weigth by using less servo wire.
pics...
ID:	1452497   Click image for larger version
ID:	1452498   Click image for larger version
ID:	1452499   Click image for larger version
ID:	1452500   Click image for larger version
ID:	1452501   Click image for larger version
ID:	1452502   Click image for larger version
ID:	1452503   Click image for larger version
ID:	1452505   Click image for larger version
ID:	1452506   Click image for larger version
ID:	1452507   Click image for larger version
