Programing 9c question
Old 11-19-2003 | 09:32 PM
Default Programing 9c question
I am trying to set up an Ultrastick, the Futaba site says to leave channel 5 blank and use 7 & 8 for flaps. If I do this were do I plug in the battery? Does anyone know if this is what I should do?
John
Old 11-19-2003 | 09:53 PM
My Feedback: (31)
Default RE: Programing 9c question
You can use any open channel for the battery power plug, it matters NOT!
Use channel #1 & #7 for aileron/flaperon...
Old 11-20-2003 | 12:53 AM
I use 1&6 for flaperons and 2&8 for dual elevator servos. I just plug my battery wherever I have a spare channel. If you run out of channels, plug the servo into one side of a Y-harness, the battery into the other, and both into the same channel.
Old 11-20-2003 | 09:37 AM
ORIGINAL: 3DFanatic
It depends on how many servos you are using but I would be sure to use a heavy duty Y harness.
Old 11-20-2003 | 12:43 PM
It should be fine on an ultrastick... Unless it's te 120.
Old 11-23-2003 | 07:17 PM
It's fine on most installations -- just plug the Y into the lowest drain channel (ie throttle).
