servos for spektrum DX6
Old 01-24-2006, 10:19 PM
garye5007
Default servos for spektrum DX6
this may be a stupid question but are there any servos compatable with DX6? I thought i read somewhere there is but i can't find it again.
Old 01-24-2006, 11:06 PM
bentgear
Default RE: servos for spektrum DX6
Why would you think you could not use any normal servo with this system? You can.
Ed M.
Old 01-25-2006, 10:09 AM
laryboy
bentgear..........do you have a sourse for this information ?
Old 01-25-2006, 10:39 AM
bentgear
Have you looked at the servo the radio ships with? Plain old normal nothing fancy run of the mil cheap non digital servo. And anything that has been hooked up to one seems to function fine. Both the ground and air version.
Have you seen anywhere on their website, in the instructions, or in actual use that would lead you to think otherwise?
Ed M.
Old 01-25-2006, 10:58 AM
rmh
rmh's Avatar
The aircraft radio setup comes with a set of very good , very small servos.
However the signal for the servo seems to work perfectly with any of my JR servos. up to inc 8611A (just playing with it)
The common power buss may not handle a million amps -but that is of no concern here . The present system is intended for light models flown within a 1/4 mile of the TX
As such -it is a crackerjack setup
Old 01-25-2006, 12:18 PM
garye5007
thanks for your input! i guess for my 2nd aircraft i will just try sevos with a jr plug ( haven't checked but i assume you need that plug)! Thanks again!
Old 01-25-2006, 05:03 PM
pilotpete2
pilotpete2's Avatar
[8D]There currently are only 2 styles of servo plugs in production, Futaba is one, the rest of the "world" uses the JR/Hitec/Aitronics Z connector, usually referred to as "universal" so you gotta lotta great servos to choose from!
