Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC On Road Nitro Cars
Reload this Page >
OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Old 03-16-2012, 10:13 AM
  #5701
FastRS4s
Default RE: OFFICIAL RS4 RTR 3 thread!!!!!!!Also type SS and others
Something like this for the Y harness
http://www.sky-holic.com/shop/step1.php?number=1183
And carboy..heres the site for it:
http://pushglo.com/
Old 03-19-2012, 07:41 PM
  #5702
rx7devil210
Hey guys i have a rs4 3 evo and it has some leaks was wondering if thats normal? My second question is does anybody elses rs4 go sideways when i brake?? thanks for reading any help is appreciated.
Old 03-22-2012, 05:47 PM
  #5703
Car-Tune
When you break, do your wheels lock?
Old 03-28-2012, 07:21 AM
  #5704
Car-Tune
Is anyone here using an O.S18 tz with slide carb?
Old 04-02-2012, 07:39 PM
  #5705
mtz57
i have the red pinons and a whole bunch of spurs coming in. can you use 39t 1st/ 37t 2nd? or do you have to use 41t/37t for top speed? i have the os 18cvr not the tz..
Old 04-02-2012, 08:40 PM
  #5706
Car-Tune
31 and 37 cannot be used. For high speed you can use 37/41 but will have a slower acceleration. Fast acceleration use 41/45 but will have low top speed.
Old 04-03-2012, 07:46 AM
  #5707
mtz57
What first gear can i use with my 39t secobd gear
Old 04-03-2012, 05:28 PM
  #5708
Car-Tune
43
Old 04-10-2012, 06:45 AM
  #5709
keinreis
Has anyone tried, or know if the front & rear RS4 drift cvd's work in the regular rs4 evo? I know HPI's site does not list it as an option for the evo, but my understanding is the drift is the same car with motor placement, and a few other things repositioned.
Old 04-17-2012, 06:36 PM
  #5710
HEMICUDA
HEMICUDA's Avatar
I recently was given an older rs4, on road nitro 4wd. It hasn't been run in like 5 years. I got it running well, cleaned it all up, the fuel tank was the worst being filled with a half inch of semi-solid green goo. I replaced the hoses and like i said got it running very well. took it out to test yesterday and it ran very well for about 5 minutes, very fast and stopped well. Problem is that it started going slower even though the throttle was working up to top rpm, the car would barely move. Is it the clutch or what? where would i get the parts. I know its in this thread somewhere but not going to read 200+ pages to find out. Doing a search doesn't narrow it down either. Please help as I don't have much exp with rc cars, i am more of a plane guy. Thanks.
Old 04-17-2012, 09:44 PM
  #5711
Car-Tune
When your car is off, can it be rolled smoothly?
Old 04-18-2012, 03:37 PM
  #5712
Limeaway510
Figured out what I was doing wrong. Sorry for this post.
I was having trouble getting the springs onto my tuned pipe, when I realized I hadn't pushed the rubber gasket all the way down onto the end of the pipe. [:@]
Give me a couple minutes and I'll have some pics of my rs4 rebuild!
Old 04-19-2012, 08:10 PM
  #5713
alexrex20
I'm trying to convert my Nitro RS4 3 Evo to a rally car. I've seen some threads where people swap shock towers, but why can't I just clearance the front uprights (to allow full suspension droop) and then put on some longer shocks? I did some crude measuring and 70mm shocks would add quite a bit of clearance (almost 1in) under the chassis.
Old 04-19-2012, 09:01 PM
  #5714
Car-Tune
Higher shock towers are needed.
Old 04-20-2012, 04:37 AM
  #5715
AutoXRacer943
AutoXRacer943's Avatar
Do you have a part number or model where we can get these shock towers?
Old 04-20-2012, 06:20 AM
  #5716
alexrex20
They say you can use the shock towers from the Super Nitro RS4 Rally, #A373. I still don't understand why taller shock towers are needed. I plan on using 70mm shocks, not 110mm shocks.
Old 04-21-2012, 06:15 PM
  #5717
rx7devil210
My rs4 3 evo + is making weird rattling noise from the engine. Anyone know what the sound is?
Old 04-21-2012, 11:33 PM
  #5718
Car-Tune
When heard that sound coming from my engine it was the bearing had fallen apart inside the motor. Remove your glow plug and look at the piston, you might be able to see dings all over it.
Old 04-22-2012, 05:34 PM
  #5719
rx7devil210
I took the glow plug out and checked ths top of the piston no dings or scratches it seems to be running good with the sound it just scares me a little.
Old 04-23-2012, 09:09 AM
  #5720
HEMICUDA
HEMICUDA's Avatar
Yes it rolls smoothly when off. so what gives?
Old 04-23-2012, 02:40 PM
  #5721
rx7devil210
I think i figured out the rattling noise my exhaust was loose soo tightened it havent ran it to check if that was the problem will later after it cools down.
Old 04-23-2012, 11:02 PM
  #5722
Limeaway510
Just a couple shots of my rs4's electronics. Servo savers came in the mail today, I needed the servo horns that were compatible with Futaba servos. I bought this car third-hand and I seemed to have misplaced the old servo saver set when I moved last year.
For those curious, I'm running a Futaba 3PL 2.4g fhss paired with the r2004gf receiver. I've been out of the rc scene for quite some time, and I'm absolutely baffled by how small thing is, lol! What I'm more concerned about is the length of the antenna wire. As you can see in the picture below, no more than about 4-6 inches of wire sticks out of the radio tray. I'm assuming the range on these things are ridiculously good though, despite how small they are? Anybody here use the same radio system?
I also put a picture of the old AM receiver just to give you perspective at how small the wire is, haha.
Thanks!
Btw, I'll be having more pics of my rs4 in the next coming days. I've been rebuilding this over the past month, just waiting on a couple more parts to come in at the lhs and I'll be good to go!
#newbiealloveragain
Old 04-24-2012, 05:22 PM
  #5723
rx7devil210
Here are some pics of the front end rebuild.
ID:	1754512   Click image for larger version
Old 04-25-2012, 03:19 AM
  #5724
fdjizm
fdjizm's Avatar
Picked up an rs4-3, mounting a big block to it with high speed gearing.
Had to grind away some of the top deck to put the brake in the front.
Now to figure out the linkage, and exhaust! ugh!
First time with shaft drive on road cars though, should be fun aiming for 90-100mph (90 is a safer bet)
Old 04-25-2012, 10:52 AM
  #5725
Limeaway510
So have the exhaust gaskets (A875) always been something annoyingly difficult to get a hold of? It's literally the last piece I need, plus two diff casing sets for the screws (nearly completely stripped), so that I can finally run my rs4. I've got them on order at the lhs, but both parts have been on back order since last week... urgh!! [:@]
I'm aware that I can make my own gaskets, but I don't really have a template to use. I don't have any old gaskets. I bought this chassis third hand YEARS ago, just never had the money to rebuild it.
LETS GO HPI! [:'(]
