Half pull-pull / Half push rod?
Has anyone used a setup like this? I must admit I just hate the idea of an old-fashioned half-meter long push-rod running through the middle of my model. But on my SE5a, a pull-pull system all the way to the elevator just won't work. For every good scale reasons the elevator is actually operated by an arm on the music wire joiner for the elevator halves. So what I'm thinking of doing is setting up a very short push-rod on a bellcrank set up at about the stab LE and then have the bellcrank operated by pull-pull cables. Actually because of servo location and space, there will also need to be a bellcrank on the other end.
Is this just silly of me?
Ive used the set up several times too. On small stuff, big stuff, WWI, WWII. On bigger stuff I try to use ball links on all internal links to give a very positive slop free set up. Don, I'm dissapointed you aint doing the closed loop elevators, shame on you!!!
My 1/4 scale Se5 uses the same set up for elevator drive, belcrank under the tailplane with a short 3mm rod and clevis.
Ian.
Ian.
ORIGINAL: abufletcher
A similar one (at least on one end):
http://www.mts.net/~mhultin/Camel/Ca...truction_4.htm
http://www.mts.net/~mhultin/Camel/Ca...truction_2.htm
Abu, I've used a cable push-rod and pull-pull "hybrid" setup on my current nieuport build, and it works well!
A good solution to get the servos far foward and bypass obstructions.
