Reload this Page >
Hangar 9 20cc Tiger Moth Build
Old 08-09-2015, 10:48 AM
  #126
cloudniner
My Feedback: (87)
Got my second Tiger Moth finished and out into the sunshine. Flies just like the other one. Has a Saito 150 flies like a dream. The picture on the right is the real Tiger Moth in England that I used for the covering. The covering is Ultracote with the Insignia Blue being put on with the Windex method.
ID:	2113568   Click image for larger version
ID:	2113569   Click image for larger version
Old 08-09-2015, 04:33 PM
  #127
rafeeki
rafeeki's Avatar
I assume your engine is installed inverted. If so do u have any problems with engine flooding and hard starting???
I have the Saito FA180 in my moth which I am about to install a Perry pressure equilizer that I am told with make that issue go away.
Old 08-09-2015, 05:15 PM
  #128
cloudniner
My Feedback: (87)
We have four of these H9 Tiger Moths in the club and all have 150's with no problems starting. I guess I have a habit of running the prop thru three times before hitting the starter.
These thing have the tail up in four feet and are off the ground in fifteen with the 150's fly around at 1/3 throttle most of the time.
Enjoy yours.
Old 08-09-2015, 05:50 PM
  #129
rafeeki
rafeeki's Avatar
Will keep u posted, thanks
Old 08-10-2015, 08:22 AM
  #130
FlyerInOKC
FlyerInOKC's Avatar
Great looking Tiger Moth!
Old 08-25-2015, 07:34 AM
  #131
cloudniner
My Feedback: (87)
I was at the Ottawa Giant Scale meet this past weekend. Larry took a nice picture of the English Tiger Moth.
ID:	2116660   Click image for larger version
Old 09-23-2015, 08:56 PM
  #132
rafeeki
rafeeki's Avatar
Got the Saito tamed yesterday.
Maidend mine today with the Saito FA 180. Flies well. Big problem is it wants to climb all the time. Added a lot of down elevator to level off. That made for a scary landing.
I balanced it at 7 5/8 - 8 1/4" back from the front of the gas tank (middle section).
I am of the opinion it should be balanced by adding about 10oz wt giving it a steep nose down attitude.
Your opinions pl.
Rafeek
Old 09-24-2015, 07:46 AM
  #133
FlyerInOKC
FlyerInOKC's Avatar
Am I the only one the new ad scheme causes the browser to lock up on?
Old 10-04-2015, 02:21 PM
  #134
rafeeki
rafeeki's Avatar
Default Adjustments
Your opinions pl.
Rafeek
Did more adjustments, raised the front of stabilizer with two popsicle sticks, shined engine mount and added nose at total 11oz so far.
Tomorrow will tell.
Rafeek
Old 10-07-2015, 08:01 PM
  #135
rafeeki
rafeeki's Avatar
Now with the 11 oz of ballast attached, the engine shimed for some downthrust and the stab shimmed by 1/8" it flies well at 40% throttle. If I increase throttle it will climb. So I keep it at the 40% setting.
Found out the cross braces under the dummy tank pulled out of place and the end eyelets broke off. Have to revise that setup.
One other thing I did was replaced the lower member of the landing gear with a J-3 Cub "O" ring held strut that I had lying around. Now I have a springed landing gear.
Old 10-08-2015, 07:31 AM
  #136
FlyerInOKC
FlyerInOKC's Avatar
I havde the Robart landing gear on my SIG Cub I love it!
Old 05-20-2016, 11:13 PM
  #137
Tisoy909
My Feedback: (21)
Tisoy909's Avatar
Hey Cloudniner,
I dunno if you're still following along on this thread or not as I know its been some time since the last post here. However, I'm starting up assembly of my Tiger moth and noticed a detail on one of your pictures further back in here and it seems the upper fuel tank which aligns the top wings has a lower angle of attack than what I have noticed on others. Wanted to ask if you had adjusted this perhaps? I know the issue of the rear stab and a tendency of the model to climb pointed out by a few might have been a reason if you had adjusted your top wing angle or did you just leave straight out of the box as most have? I read that this model requires a carried down elevator trim for lifting tail surface to get proper flight. Would you have any input to share regarding that? thanks in advance Cloudniner.
Old 05-21-2016, 01:22 PM
  #138
hayman1
Hello Guys would any of you happen to know we're a fellow could pickup a Hangar 9 Tiger Moth? Been searching many sites without muck luck, live in Florida so east coast region would be appreciated but not limited.
Thanks, Dan
Old 05-21-2016, 07:16 PM
  #139
rafeeki
rafeeki's Avatar
I have a Saito FA 180 for a power plant, more than needed.
I swapped the front/rear struts holding up the "fuel tank" making the incidence angle of both wings the same. Had to adjust wing struts as well.
Added about 15oz to nose.
Added slight downthrust to engine.
Lifted the front of the stab by the thickness of two popsicle sticks.
Now it flies beautifully and i have better control during landing.
Old 05-26-2016, 05:49 AM
  #140
rafeeki
rafeeki's Avatar
Default Phoenix Model
Tower Hobbies stocks an identical model by Phoenix Models.
Old 05-26-2016, 08:43 AM
  #141
FlyerInOKC
FlyerInOKC's Avatar
Availability says late June. Ironic when you consider who owns Tower. I wonder if Phoenix is using the same overseas manufacturer Hanger 9 used and they carry the Phoenix so the can lower the inventory they keep on hand? From a business sense I can see why they would do it that way.
Old 12-10-2016, 06:07 PM
  #142
rafeeki
rafeeki's Avatar
I would like to install a scale aluminum prop hub not like the original one supplied with the plane. Any clues where to find one?
It is very shallow.
