Reload this Page >
Balsa USA 1/3 Scale Sopwith Pup
Old 08-07-2007, 10:46 AM
Prop Nut
Prop Nut's Avatar
Default RE: Balsa USA 1/3 Scale Sopwith Pup
Frank, what torque specs are your wing servos?
Old 08-21-2007, 06:49 PM
Zero
My Feedback: (42)
Zero's Avatar
Hello everyone. I have been busy with work. Some building has been ongoing however. The wings have been mounted and rigged. The tail feathers are also installed. The engine has been mounted and the cowl is in the process of being mounted. The cockpit is partly finished. I have been unable to find any concrete design for a scale landing gear. I have viewed many threads on several sites and this past weekend I built a landing gear mock up out of 3/16" wood dowels. I added some gussets just to hold it together. This seems to be a close set up. If anyone has any thoughts they would be appreciated.
Thanks to all with your help.
ID:	746634   Click image for larger version
ID:	746635   Click image for larger version
ID:	746636   Click image for larger version
ID:	746637   Click image for larger version
ID:	746638   Click image for larger version
ID:	746639   Click image for larger version
ID:	746640   Click image for larger version
Old 08-21-2007, 11:07 PM
abufletcher
abufletcher's Avatar
Doing the wooden mock-up was a very good idea. That'll make it much easier to get it right in metal. Here are some shots of the gear I came up with from my 1/6 scale Sopwith Snipe.
ID:	746852   Click image for larger version
ID:	746853   Click image for larger version
ID:	746854   Click image for larger version
ID:	746855   Click image for larger version
ID:	746856   Click image for larger version
ID:	746857   Click image for larger version
ID:	746858   Click image for larger version
Old 05-06-2018, 02:41 AM
CarreraGTSCS
CarreraGTSCS's Avatar
Great work on the landing gear Abu. What wheels are those?
Old 05-07-2018, 07:58 AM
mgnostic
mgnostic's Avatar
Hi Zero, I admire the jigs that you have set up. Amazing how useful those things are.
