CD ScaleDesigns Albatros CI build
#1778
RE: CD ScaleDesigns Albatros CI build
Here's a key fact for the Benz dummy: The scale distance from the engine center line to the flat top of the cylinder is 95mm. So I need to superimpose that height over the kit plans and see how much stands above the engine mount beams (and ply flanges).
Or 30mm from the engine center line to the bottom of the cylinder flange.
#1779
I've put together a photo overlay that looks right. But, OF COURSE, the photo upload isn't working. I'm beginning to think this is a time-based problem.
#1780
Congrats Don for hanging in there and getting these done...yes, some of ths scale stuff ain't easy, it's tedious, and it does take the right frame of mind to "get er done"...This will all be of even greater use in the future...the lessons learned will be invaluable down the line.. Looking forward to seeing your engine come together.
#1781
The red overlay shows the scale position for the Benz and would involve cutting off about 5mm from the base of the cylinders. The blue shows a "fudged" position with the cylinders (uncut) on top of the engine bearer (separated by a 1/16" ply flange).
#1783
I'm tempted just to let those 5mm slide. It would be so much simpler if I didn't have to cut off the bottom (which I know is flat and level because of how the master was constructed).
But Flying Fox's great work on his crankcase inspired me to "fake it" with the illusion of looking down on the whole thing. I can use some shading to create the impression of depth. So I started looking at the top view to use as a template and base for the dummy. Unfortunately, the drawings I'm using (from the DF) are both degraded and partially suspect. For example, the side view doesn't like up perfectly with the top view and I had already determined that the cylinder details weren't quite right. Also the sides of the crankcase (for example the bolt holes) aren't exactly aligned. So I decided to use my old trick of copying half and mirroring it to create a symmetrical drawing.
And in doing that I noticed something VERY interesting! The cylinders are NOT centered on the engine center line! As a non-engineer that seems very bizarre to me. Is that normal? Or is this an error in the drawing?
#1785
For me it is an error of the drawing; the offset of the cylinders, my opinion, would be a nonsense for balancing of the forces toward the crankshaft
#1786
I know of an American 6cyl engine that while I believe the cyls are centered on the crankshaft, the piston pins (wrist pins-grudgeon pins) are not centered in the piston. The object being I believe to provide additional torque due to the angularity imposed on the connecting rod even at top dead center. May bear no relation to what you have found and Gian may be correct and its an error in the drawing.
Doc
Doc
#1787
I also don't see the need to cut off the 5mm from the cylinders..hardly noticable in the end effect, unless it causes problems with getting your exhaust system to line up to a relevant position?
I think the missaligned top view was just a hasty drawing blooper on somebody's part...doesn't make any sense to be offset.
#1788
#1789
#1790
If it's an error in the original drawing, it's an error that's repeated in both the top and rear views! It seems like such a ridiculous error to make...twice.
#1791
ON, CANADA
Don, your mold making process has been a fascinating tutorial for us all. I have no experience whatsoever with this method but from what you have shown us step by step it looks like it has great potential.
ORIGINAL: abufletcher
I guess this will do for my first attempt at silicone mold making/resin casting. In the end, I spent a lot of money on materials, spent two weeks or more making a master and preparing a mold, ended up with cylinders that I'll still have to clean up a bit and detail,
I understand you have to spend a lot of time perfecting the first master cylinder for the mold but then isn’t the bulk of the work done for the remaining castings – I’m thinking if you made each cylinder individually from wooden disks by hand you would still have to do all the major sanding, shaping, and finishing, six times over. With casting, most of this grunt work seems to be finished up front. Either way with resin casting or disk buildup method you still have the final touchup and finishing so this aspect cancels out with either method. Which method do you think is easier to do? Also you must consider replicating the six cylinders exactly. With the wooden disk method it is quite tedious and time consuming to get each cylinder just right.
I’m not sure but it would seem that putting in your time and due diligence on the first cylinder knowing that the six castings will turn out very nicely equates well with making each cylinder by hand out of wood and then sanding, shaping, filling, etc. I know you prefer wood over resin but now that you’ve had time to reflect, what do you think about this?
As for the resin cylinders, what king of adhesive will you use to glue the cylinders together? Would something like Gorilla glue (a glue anything to anything) work? Is the resin hard like fiberglass or soft like rubber? Does it sand easily or is it quite strong and difficult to sand and shape once cured? Sorry for all the questions but I am about to work up six cylinders for my Benz Bz IVu engine which is very similar to yours. I have built up construction approach that I will post when I get to it but your excellent work on casting the cylinders has me considering this option.
Cheers,
Brian
#1792
ON, CANADA
Don,
Be very careful with these simplified drafted "sketches" of the various engines... as you are discovering they often contain many, many errors. In drafting plans for my Benz Bz4u enging I noticed so many errors in the engine 3 views that I could not rely on them at all. I had to find better engine plans and rely on photos as well. In fact I basically abandoned them once a more detailed engine plan was found. It took many hours to sort out. For example, in drafting up the overhead view for my Benz Bz4 engine I noticed the main camshaft was centered in the front but offset to the right or left (can't remember which way) at the rear of the engine. At first I thought maybe it was built in right thrust but it was more than one degree. This did not make any sense because it is a straight shaft that drivers the propellor. Research revealed that the actual engine itself was offset a degree or so for thrust by the way it was mounted on the engine bearers in the airframe. Like yours, the offset was substantial, and it was/is an error in the sketches.
Check your photos and other documentation, and the the Vintage Aviator website provided by TFF. I think you will find that these drafted "sketches" as I like to call them are just that - they are fairly accurate sketches but can not be considered totally reliable for measurements, etc. Try to have confirmation from secondary sources, photos, engine manuals, etc. I might have a manual on your engine in PDF form. If so I will post it to you.
Good luck.
Cheers,
the Fox
Good luck.
Cheers,
the Fox
#1793
Now that cylinder offset is really bizzare...we better call in the experts on this one, this defintely needs to be clarified or I won't be able to sleep !![:@][&:]
#1794
ORIGINAL: Flying Fox
In spite of a few teething problems with the resin cast the cylinders look really great! The next time you try it you will know what to watch out for.
There's also the "aesthetics of cost." It just chaps my ass to think that I spent over $100 on this so far! That's not what WWI modeling is supposed to be about. That's not a "clean" modeling solution in my book.
#1795
#1796
#1797
Looking at this photo, I think I can pretty well throw out "the sketch" as a useful basis for anything. In this photo, the cylinders look centered to me. And the shape of the "base" is different.
Brian, if you have any more info on the Benz Bz III, I'd love to see it. If not, I guess I'll just draw up my own sketch for the base.
#1798
I think its possible they were offset but have no proof, I just dont think it's impossible may be a wiser way to state it. Things were done for a reason and it would be interesting to know more about it, if indeed there is an offset.
Doc
Doc
#1799
The only thing I can think is that offsetting the cylinders MAY have laterally balanced the engine. It appears that offset cylinders are a possibility (if I'm readying this correctly):
http://www.patentstorm.us/patents/60...scription.html
#1800
The only time I have seen offset cylinders is when the camshaft is in the block next to toe crankshaft, but it would be offset the other way I would think. One thing to remember is that technology was changing fast and in just 10 years the engines improved so much that those designs were just forgotten. If it was wrong no one cared. There is another reason to offset the cylinders which just came to mind; it can help with wear on the cylinder walls. Cars do it by offsetting the piston pin to the connecting rod; moving the whole thing over would do the same thing. The expense is a slight loss in power and actually the other way would give a slight increase but would wear faster, some race car engines do this.
