Go Back  RCU Forums > RC Boats > RC Scale Boating
 just an idea >
just an idea
RC Scale Boating Enjoy rc scale boating? Talk about it here.
just an idea
Old 08-02-2008 | 06:21 AM
Guest
Default just an idea
this side of the rc hobby aint my forte but i've tinkered around with lil electric boats, i found an old tirpitz model which had an optional motor kit for it, since it provided the gearbox-like thing and er.. the metal rods for shafts i guess it'd be great if i made it rc
the mopdel's hull is not so big and only a small cheap rc boat's system would fit in it. is it a nice idea ? i think it is, it's just gonna look great just by it's appearance not by it's performance i guess. the model kit that i have is the tamiya's begginer battleship model of the tirpits. forgot the scale though
Old 08-02-2008 | 11:50 AM
Umi_Ryuzuki's Avatar
Default RE: just an idea
Sounds like a good runner for a small pond.
[8D]
Old 08-03-2008 | 05:46 AM
If its the 1:350 version, the hull is plenty big enough. A bit of sense, care and thinking will allow for a coaming around the opening under the superstructure. The hull is perfectly capable of handling a considerable swell, but will be unhappy with a chop. The big problem is the camo scheme. It will tend to disappear in the right (wrong?) light conditions.
Old 08-13-2008 | 06:11 AM
Guest
lol yep, the farther it gets, you wont be able to tell. the scheme i might be using is the one the tirpitz used on sea trials. problem though, i need styrene rods for some of the masts and stuff... cuz when i first bought it, i was 7 yrs old and didn't know much about modeling
Old 08-13-2008 | 12:53 PM
If you don't have a good hobby shop where you are located, try cutting up and sanding down some
model sprues from any plastic model kit. Wood dowels will also work in a pinch.
[8D]
Old 08-13-2008 | 04:25 PM
Assuming 1:350, brass or copper wire is fine, and stronger than plastic. The mast strucures are not so big as to make top weight become a problem.
Old 08-16-2008 | 11:32 PM
Guest
thanks, some brass and maybe i can get photoetched crewmen, and uh... oh a dremel tool to cut the batter holder out of the inside of the hull
Old 08-17-2008 | 09:26 AM
http://www.geocities.com/patsmodels/musashi/ for a few ideas.
Old 08-18-2008 | 06:19 AM
Guest
Pat that's amazing, 350 eh? O_o wish i had enough cash to buy an esc and reciever for my rc, i might as well make use of what i got. an old rc car? might as well get the car's entire bunch of functions, "servo" it has ( some sort of object that functions as a servo for it but isnt ) and the motor with uh.... the speed controls it's got. that'll do right? i mean i planned this as an inexpensive home project of mine from the start when i first thought about it.
as mi read the paragraphs one by one, i noticed one common thing most of us share, inaccessible hardware
