Triggering a Sound Card
Old 02-12-2011 | 01:41 PM
Fireman Tim's Avatar
Default Triggering a Sound Card
I bought a USB recording module for my Bergepanzer and I want to be able to trigger the sound using the up left stick on the controller. It currently comes with STSP normally open push button switch.
I know how to power it using the 4.5v on the DBC, but I need a way to trigger the sound card using the RX18. Any ideas?
Old 02-12-2011 | 02:51 PM
borealis's Avatar
Default RE: Triggering a Sound Card
Use a small 6V relay connected to the gun channel
Old 02-12-2011 | 03:16 PM
What kind? STSP NO 6V Relay?
Like this one: [link]http://cgi.ebay.ca/1-x-6V-DC-Sugar-cube-sized-PCB-relay-SPST-5A-/130368749383?pt=UK_BOI_Electrical_Components_Suppl ies_ET&hash=item1e5a953f47[/link]
Old 02-12-2011 | 03:52 PM
YHR's Avatar
YHR
What exactly are you doing with the sound. Is a momentary thing or a what?. I use the exact same card, and use it for cannon sounds or Hit and death sounds triggered by the DBC. You could just run a wire and tie it in to the airsoft fire wire(Blue??) The negative trigger wire must be a shared circuit with the soundd card though. This would mean you would have to have the RX18 and the sound card on the same circuit.
Old 02-12-2011 | 04:20 PM
Dan,
I am using this card to simulate repair sounds for my Bergepanzer. I wanted it to trigger when I used the left stick up, but.... perhaps I should tie it in with the DBC. I hadn't thought of that.
Old 02-12-2011 | 05:45 PM
Apparently I have an early DBC without any connections to add a sound card.
I have a 50 sec clip recorded on the card. I want it to play when I hit the left stick up on the controller.
Dan, if you could draw me up a simple wiring diagram of what you are talking about it would really help.
Old 02-12-2011 | 05:47 PM
YHR's Avatar
YHR
If you wired up to the DBC, you could have it play instead of the cannon sound when you press the K button. This card will record 50 seconds of sound, and if you choose the loop feature it will play it continously until you hit the button again.
Old 02-13-2011 | 01:16 AM
borealis's Avatar
Anyway, that relay should work. Connect the coil to yellow and brown wires on the turret connector (wires 4 and 5) and the NO contacts to the pushbutton terminals.
