Kill Rings
Old 01-28-2012 | 11:21 PM
Default Kill Rings
Im no expert with a paint brush and don't have a steady enough hand to paint kill rings on my tiger. Im wondering what you guys use if anything and what is the fastest and easiest way to make them. Im leaning towards simple masking tape and spraying it. Would like your thoughts.
Thanks.
Old 01-28-2012 | 11:30 PM
Airbrushler's Avatar
Default RE: Kill Rings
i did the painting on Stince's Tiger
i used a mask to do them and painted them with a brush
ID:	1720614   Click image for larger version
Old 01-29-2012 | 01:37 PM
streetsquid's Avatar
Panzerace,
I you want them to be clean, fast, simple and consistent, just use decal film. Most Hobby shops should have it in stock, and if not defintley easy enough to find on line. 1 sheet should be enough to do just about every tank you own or will own that you want to add kill rings too. Solid decal sheet ususally only runs a couple bucks a sheet, and is available in any color you would most likely use (white, yellow, red, or black).
Simple cut to width with a sharp x-acto and a straignt edge then cut to length and then wrap around the barrel, all you have to concern yourself with is consistent spacing, piece of cake!
Just my 2 cents!
Streetsquid
Old 01-29-2012 | 01:44 PM
Green Amphibian's Avatar
You can also use pin striping tape as a mask, or if it is thin enough, just leave it on.
Old 01-29-2012 | 02:00 PM
Panther F's Avatar
All of these suggestions are great, but if I were to do this I would use masking tape. Practise on a comparable size 'till you feel you got it down.
One tip though, once you've laid the tape down, spray it with a clear coat first to "seal" the tape so there's no bleed through of the white paint. You'll be glad you added this little insurance to the task.
~ Jeff
Old 01-29-2012 | 02:58 PM
I dont want to seem like a total DA (I will anyway) what are Kill Rings and what do they stand for? Im guessing the rings around the muzzel? Hey,Im new....
Old 01-29-2012 | 03:40 PM
YHR's Avatar
YHR
You can also chuck the bbl in a drill. Get it rotating and then paint them on with a steady hand.
Old 01-29-2012 | 04:18 PM
Buckeye36's Avatar
The represent tank kills, like the flags on fighter planes.
Old 01-29-2012 | 04:33 PM
Why does it always seen to be 3 rings?
Old 01-29-2012 | 04:39 PM
Buckeye36's Avatar
Maybe everybody uses the same decal....
Old 01-29-2012 | 04:46 PM
Buckeye36's Avatar
He had more then 3.....
Old 01-30-2012 | 12:44 AM
rivetcounter's Avatar
I was wondering when Wittmann would be brought up, the kill rings on this Tiger are purely for propaganda purposes no one would be mad enough to want to stand out on the battle field just think of a sniper in a high visibility jacket then you will get the idea, on other tanks and there are relatively few pictures showing kill rings they were mainly painted as thin as possible 10-20mm wide and more often painted black though you do see white and yellow, bright colours stand out also individual tanks with special or individual markings stand out this would encourage the enemy to target you first.
The interesting thing about kill rings is Wittmann never had them a few months after this picture was taken in Normandy and of all the other Aces there are only a small handful of pictures showing this tradition and none of the pictures are taken at the front always in a rear area during rest or repairs
Old 01-30-2012 | 01:25 AM
Panther F's Avatar
Even in light of this information, kill rings still look cool. As a matter of fact I just dug out my half finished 1/15 Bandai Tiger I and the decal sheet has them, so I think I'll have to splash them on anyway.
I mean after all, it's just a model.
~ Jeff
Old 01-30-2012 | 01:50 PM
Buckeye36's Avatar
ORIGINAL: Buckeye36
I guess I should have said this was a propaganda pic.
