multi function fried out on king tiger HL >
Old 09-27-2014 | 11:06 AM
BludoTheSmelly's Avatar
Default multi function fried out on king tiger HL
So my question now is do i buy the dbc3 from that site? Do i need to get a new radio controller also or what do i do?
Old 09-27-2014 | 01:17 PM
Bagheera's Avatar
Talk to Dan at http://battlearmorrc.weebly.com for info a good tanker to deal with
John
Old 09-27-2014 | 01:50 PM
YHR's Avatar
YHR
I am away this weekend working off my Blackberry
Old 09-27-2014 | 01:52 PM
Yeah so the multi function i guess "servo" smoked on it. I saw a heng long 2.4 replacement but are the tamiyas better for that or is that one sufficient? What would you recommend?
Old 09-27-2014 | 02:16 PM
YHR's Avatar
YHR
There are no servo's on a hang long or Taigen tank.
MFU stands for multi function unit.
A Dbc3 only works with an RX 18
Old 09-27-2014 | 02:29 PM
This is what burned out. Should i get this as a replacement?
https://www.amazon.com/dp/B00G7GZTSE..._HNZjub0P3A251
Old 09-27-2014 | 02:40 PM
YHR's Avatar
YHR
Well that all depends. If you want to keep your tank the same, then yes.
Old 09-27-2014 | 02:43 PM
I thought about updating it for the danville tank event in November.
Old 09-27-2014 | 02:47 PM
I assume tamiya makes an mfu but it would need to be rewired?
Old 09-27-2014 | 03:40 PM
ausf's Avatar
Tamiya makes DMD and MFU pairs that are designed for different tanks, i.e., recorded engines, main guns and MGs. Buying them separately from a kit will run you around $400+ depending upon finding a deal. On top of that you'll need to buy a Battle Unit and IR emitter, probably around another $150 once they hit the shelves in October. Then you would still need a bunch of rewiring of connectors and a hobby grade Tx/Rx to get all of that to work in your tank.
With a HL, you'd be better off sticking with either another RX-18 and getting the DBC3 and battle unit or a Clark board. Those are 'Tamiya compatible' which means they'll send and receive Tamiya's IR code for battle.
If you really want Tamiya, which I'd recommend, you can get a M4 for around $500, much better deal than buying individual parts for your HL. The AAF Museum has King Tigers for $630 if you want to stick with Heavy German. Either option would still require a hobby grade Tx/Rx and battle unit.
Old 09-27-2014 | 04:02 PM
Gotcha, rx18 and dbc3 it is, ill check back soon. Thank you
Old 09-27-2014 | 09:55 PM
Are the tbus coming back into production then?
Old 09-28-2014 | 04:18 AM
Does the battle armor site sell the battle unit also? Does the dbc3 connect between the rx18 and the rest?
Old 09-28-2014 | 04:33 AM
ausf's Avatar
I got an email from the AAF Museum last week that said they'll be in stock by the first week of November.
Old 09-28-2014 | 06:22 AM
YHR's Avatar
YHR
Yes it is all plug and play, You will also need a hobby grade radio
Old 09-28-2014 | 06:43 AM
Pah co chu puk's Avatar
Bludo, you may only need this part.
http://www.amazon.com/Heng-RX-18-Mul.../dp/B00EO3TV8Q
If you are going to upgrade to Tamiya battle standard then you will need a DBC or Clark board. Both will require a new transmitter and receiver.
Dan at Battle Armor is the guy to talk to. He is honest and very helpful.
