Toro vs Taigen
I am seriously looking to get a Taigen tiger 1 metal version. Someone offered me an upgraded toro metal version at a really good price. What if any are the differences between the two? Would I be loosing or gaining at all? Any feedback would be appreciated.
I'll second that. I know the factory laoban who also owns KY Models, supplier to Graupner, Proboat, PEBA & other RC boat brands .Torro's new 1/16 Schwimmwagen is due to launch soon from this source.
No idea but would expect the Schwimmwagen to be available soon. Certainly before Hooben's Cromwell or even their Hetzer that was to be released back in April.
So my next question is are the parts torro to Taigen and vice versa interchangeable? The reason I’m asking is because I’m getting a good deal on an upgraded ir metal torro tiger 1. Do I just change the turret (could it be just that easy?)to make it airsoft because there’s not a lot of people to battle with in Las Vegas. any input would be appreciated.
Just be careful switching from HL to Torro/Taigen/Mato. Sometimes suspension arms, idlers, sprockets, and tracks can have some compatibility issues. For instance you can't use some Taigen/Torro/Mato sprockets with HL tracks and vise versa. Some work, but some don't. For tracks you typically want to match the sprocket manufacturer to the track manufacturer unless specifically says it will work. Some sprockets have a different backspacing also like the HL sprocket bore is shallower than the Taigen sprocket bore on the KV-1 sprockets so you may need to match the sprockets to the gearbox type or swap the final output shaft to a different length shaft. There really is no hard and fast rule that everything from X will fit Y.
Throw a clark board in that thing and come to LA tank. Its worth the drive. Especially for the June Tankfest. Its only a 4 hr drive. I go to LA most months and its a 2.5 hr drive. Its alot of tanking fun you look forward to all month.
Then try to get some folks in Vegas interested and get a group together.
[QUOTE=RichJohnson;12572313]Throw a clark board in that thing and come to LA tank. Its worth the drive. Especially for the June Tankfest. Its only a 4 hr drive. I go to LA most months and its a 2.5 hr drive. Its alot of tanking fun you look forward to all month.
Then try to get some folks in Vegas interested and get a group together.[/QUO
It sounds easy but I wouldn’t even know wher to start. There are only 2 hobby stores in Vegas anymore and neither one have ever sold a tank. How often is there anything in the LA area? I live in Vegas but I work in Southern California.
