Pershing Progress....so far
NY
While I detail my tank I've been working on my first village building...here is a pic of the progress on that.
Question about tread tightness...mine crackle as they turn are they too tight?
THanks in advance.
Dennis
THanks in advance.
Dennis
Did you use a primer before application of the olive drab paint? Also, have you used a dull coat or is what we're seeing just a paint and wash layer?
Great job on the tiedowns! I don't know why but they really add to the look of the tank.
Is this the paint you used?
-Harq
-Harq
NY
Yep...used testors primer-gray...on everything. Haven't used a dull coat...thinking about it. It is just paint and wash right now.
This is a picture of the paint I used.
Thanks...for the tiedowns I drilled holes at an angle on either side of the handles and passed a wire through then pulled the string through.
Later,
Dennis
Later,
Dennis
#31
Comments, comments... I know.
I know the turret has a noticeable seam dividing the top and bottom halves. Can this be filled with putty/epoxy or should it be left alone so one can disassemble the turret for maintenance issues, etc.?
Just striving for my own little version of a realistic Persh'.
-Harq
-Harq
#32
My Feedback: (9)
......just my opinion, though.
Jason
