help with paint
Old 05-24-2008 | 08:59 AM
Default help with paint
hey guys,i enjoy looking at all the finely detailed armor here,and i know it takes alot of hours to do.i was looking for a simple german camo pattern that would look good on my king tiger tank.i am currently in the procces of stripping this tank for the third time.i am using a badger a.b. (external mix)and compressor with reg. & moisture trap.,and tamiya acrylics.is this possible or should i upgrade my airbrush before i try again.any help here would be great.thanks
Old 05-24-2008 | 10:26 AM
wackywheelz's Avatar
Default RE: help with paint
Here is a link to a very large image of the many KT camo schemes, pick a few you like and we will endeavour to tell you about them
[link=http://members.iinet.net.au/~wackywheelz/ktcamo.jpg][/link]
(Click on the above image for full-size view)
Old 05-24-2008 | 10:38 AM
thanks wackywheelz,that's a nice poster.would different angles of these also be avaible,also i noticed that the tamiya red brown seems to not be red enough compared to others tanks& pictures.is there a way to correct this(add some red)or would you use something different altogether?thanks for the help.
shenlonco's Avatar
I tend to like the model master paints better than tamiya they flow better for me and dry dull as tamiya dries to glossy.... I use the water clean up model master series.
Old 05-24-2008 | 11:05 AM
are those enamel based,also what parts ratio do you mix those at for the psi your useing ,thanks.
Old 05-24-2008 | 11:46 AM
shenlonco's Avatar
Hi they are water base paints and a good rule of thumb on airbrushing your paints should be thinned to be as thin as a milk for a good start. .... you can thin it like milk or a little thinner and airbrush from 20PSI to 50PSI lower PSI = thinner paint for fine detail less over spray.
Old 05-24-2008 | 12:14 PM
thanks,do use a "blackwash"to bring out fine details,&if so what methods have left you with the best results?do you haze the entire model with you base color after completing the camo pattern to tone the colors down?i've read about this practice but have never tried it.thanks for taking tme to answer my questions.
Old 05-24-2008 | 12:23 PM
shenlonco's Avatar
Hi I use feild drab and mist it very lightly and heveier in certain arias to make it look dusty with dirt.....and hit the road wheels heavy with it...theres a lot you can do you just have to play around with it.
Old 05-24-2008 | 12:59 PM
thanks again,i think i may do some fine detailing work until i aquire the funds for a better airbrush.just one more question,if i use model putty to apply a zimmerit coating would this be hard to remove if i decide i don't like it later on(after it has dried)?thanks again for you time.
Old 05-24-2008 | 01:19 PM
shenlonco's Avatar
never used it but i think once you use that stuff it will be almost impossible to get it all off.
Old 05-24-2008 | 01:31 PM
yea that's what i thought to.thanks,i'm going to go study some paint jobs
Old 05-24-2008 | 04:32 PM
Leon01's Avatar
Hi Wacky or anybody that may know I was looking at the paint Schemes it shows a King Tiger in . Afrika Mustard or the yellow base color was there a real king Tiger that was that color any body know the number of it if it was in service where. It must be 507 but not sure is that it?
Old 05-24-2008 | 05:42 PM
swathdiver's Avatar
There was 1 KT with a Porsche turret that was in dunkelgelb (RAL 7028) only, that was the first one. All the rest were camouflaged in various patterns.
Old 05-24-2008 | 06:25 PM
uhu's Avatar
uhu
There were several units that had plain Dunkelgelb non-zimmerited production turret Kötis by the end of the war, Schwere Panzer Abteilungen 503, 507 and 509 had them, and there is a well known Panzer Lehr (Porsche turret) zimmerited Köti, turret number 02, that fought in France.
Regards
Jose
Old 05-24-2008 | 06:42 PM
I use mainly tamiya acrylics, for the reason that Tamiya provides the largest range of detail colors and the cheapest dollar per volume paint.
Of course, there are several good brands out there for your selection and experiment.
still has the tracks and some tools to paint up and the final weathering.
By the way, this KT is all hand painted......because I can't afford an airbrush
Old 05-24-2008 | 07:24 PM
Leon01's Avatar
Thanks guys thought I would like to have my King Tiger Dunkelgelb. I learn something ever day on here never knew Dunkelgelb was the base color. Mine is not a Porsche turret but still going make it into the 02 tank.
Elhhss nice looking King Tiger.
Old 05-24-2008 | 07:40 PM
very nice,very realistic.i don't think i would ever be able to match that.i was looking for a well cared for appearance.there are so many patterns to chose from!doe's anyone know where i can find more german camo info?thanks.
Old 05-24-2008 | 08:47 PM
swathdiver's Avatar
I didn't know there was more then 1 non-zimmerited or even un-camouflaged KTs, never seen pictures of them. Interesting, though most of my research has been confined to North Afrikan and Initial Production Tiger H1s.
Dunkelgelb was not the only base color. There are several websites that explain when Olive Green (RAL 6003) was to be used as the base and a time before that where the red oxide primer shown through as a replacement for RAL 8017. A quick google using these RAL numbers will light the way.
I do not agree that Tamiya has the best selection of acrylic military paints. I think Xtracrylix and Polly Scale do. I used Polly Scale, Tamiya and Model Master since I was a kid and when I re-entered the hobby. Now I prefer Xtracrylix and Polly Scale as they don't smell, thin great with distilled water and have a large selection of colors available. Another thing is that they're not Tamiya acrylics! Too many tanks look the same because they all use the same paint. They're not spot on matches either. You see a lot of mixing to match historic color swatches whereas some other brands are even closer.
Old 05-24-2008 | 09:18 PM
my local hobby shop stocks the tam. acrylics,and i've gotten somewhat used to air brushing them,so thats what i will use.has anyone added a little red(xf-7) to the red brown(xf-64) to make it look more accurate?if so what ratio gave the best results?also has anyone made scratch-built track hangers?thanks for the help guys.
Old 05-25-2008 | 12:05 AM
swathdiver's Avatar
http://www.ttfxmedia.com/vallejo/cgi...odelcolor&p3=1
Old 05-25-2008 | 02:13 AM
Do you have reference pics of those King Tigers that had no camo color near the end of the war? Even the first five King Tigers ever built (your color plate for instance) that were assigned to the Pz. Kop. 316 had some sort of crew-applied camouflage.
I don't there there ever was a non-camouflaged King Tiger. With constant air threats, camo is kind of a necessity.
Old 05-25-2008 | 05:30 AM
uhu's Avatar
uhu
Here you go:
Cheers
ID:	956176   Click image for larger version
ID:	956177   Click image for larger version
ID:	956178   Click image for larger version
Old 05-25-2008 | 07:57 AM
swathdiver's Avatar
Well, in my research I've learned not to exclusively rely on plates as many of them have been found to be innacurate. I couldn't find the above tank but my brain is a bit groggy and wracked by this never-ending flu!
Check out www.tiif.de
It's the online repository for all known photographs of Tiger tanks. I help moderate the Tiger sections of the 501st and 504th.
Old 05-25-2008 | 08:54 AM
uhu's Avatar
uhu
@Swathdiver
As far as I cannot access primary sources (can you?), I find very useful informations that appear on publications. My level is just "plain amateur"
Regards
Jose
Old 05-25-2008 | 09:57 PM
well so far not to bad i'm trying to get close to the tank that's got 111 on the turret.i 'll try to post pic's later.
