Stug from Mato
Old 08-27-2008 | 08:13 PM
TXtanker's Avatar
Default Stug from Mato
Sooo I receive my Stug and open it to check the gears and low and behold plastic gears.... If I had known they were misrepresenting the tank as having metal gears I would have bought it from RCCommand... anyone else had this problem???
Old 08-27-2008 | 08:25 PM
wackywheelz's Avatar
Default RE: Stug from Mato
LOL double-gipped!!
Man, MATO are really trying to make some money on this one... everything you usually get free is now an "optional extra"
Old 08-27-2008 | 08:28 PM
smittyrob's Avatar
I just checked mine and mine are metal, I'd get a hold of them to get that straightened out.
Is it an S&S as well?
Old 08-27-2008 | 08:38 PM
Shameful way to do business.[]
Old 08-27-2008 | 08:47 PM
Dmon1996's Avatar
I just took a look at the Mato Stug webpage- it says straight out that it comes with metal engines and even has a pic. I'm sure that you inadvertently got a mis-shipped plastic gear Stug sent to Mato. Of course, the question arises as to how they could test the tank (as it says they do) without noticing the quiet gears. There is a drastic difference between even broken in steel gears and plastic gears in the sound....
I'm sure that if you let them know of the mixup they will send you a set of steel gears, then you'll have a spare plastic drivetrain!
Old 08-27-2008 | 08:55 PM
IF they have the new stug-type gearboxes as spares yet.
Old 08-27-2008 | 09:07 PM
TXtanker's Avatar
I have sent them an email I will let you know what happens.....
Old 08-27-2008 | 10:26 PM
YHR's Avatar
YHR
It is clearly advertised as metal. Mato usually makes things right, I wouldn't be too concerned. You will probably end up with an extra gearbox out of this. I am still waiting for mine. There better be metal gears in the tank, if not I guess i'll be getting a free set of gears as well!!!! Smittyrob got metal gears, so I hope I do as well.
Old 08-27-2008 | 10:27 PM
Anyone has a pic of the new stug type gear boxes that come with the stugs?
Old 08-27-2008 | 10:33 PM
YHR's Avatar
YHR
Old 08-27-2008 | 10:48 PM
Thanks YHR for teh pics. They look nice, do they fit into normail panzer IIIs?
Old 08-28-2008 | 12:35 AM
YHR's Avatar
YHR
I don't see why they wouldn't. There is nothing special about these , other then the placement of the drive motor. The gear ratio is the same as any Heng Long gear box.
Old 08-28-2008 | 10:48 AM
Any reason the metal gearboxes used in say, the Panzer III, won't fit? Are the ones pictured shorter than the PIII boxes or not?
Old 08-28-2008 | 10:57 AM
Wozwasnt's Avatar
The Stug Gear boxes are lower then the normal HL Gear boxes.
Old 08-28-2008 | 01:55 PM
nemesis4u's Avatar
My Feedback: (77)
CONGRATS LT DAN on your new STUG!
Looking forward to seeing it in Battle...[>:]
Going to use a DBU ?
Heard that for about $140-$150 with original transmitter you can have that up and battling Infrared Style!
All Tamiya IR compatible!
-CHEERS!
TOMAS
TX ARMOR
Old 08-28-2008 | 03:01 PM
I know the ones made by someone else were not as tall, but from what's been posted, other than engine placement these gear boxes appear no different than the earlier HL ones. Since the hull shouldn't be different, nor the back of the upper hull from the PIII, not sure why they would have changed them at all.
The "low profile" boxes built by whoever I believe were made to accomodate the airsoft.
Old 08-28-2008 | 03:18 PM
blitzkrieg65's Avatar
ORIGINAL: dyeager535
I aked Bill that same question and he said that the top Hull sits lower then the P-III so they had to lower the motor, and yes they just added a bracket so you can service it and moved the pinion point, same gear ratio!
The Blitz
PS I grew up in Washington hope to move back there in about 5 years!
Old 08-28-2008 | 03:35 PM
Interesting. Is that true to the actual StuG? I was under the impression for all intents and purposes the hull and rear upper were identical in significant structural aspects.
Old 08-28-2008 | 05:44 PM
TXtanker's Avatar
Well thats what I call customer service my opinion has been turned around!!!!!!!
(Dear Daniel
We are very sorry to hear that about your tank. Can you send us a picture for the plastic engine you received? We will send you the metal engine but you will have to install this yourself. Please let us know if that is ok with you?
Your reference number for this request is ...........
(Please mention this number as Subject for future reference)
We sincerely apologize for any inconvenience this may have caused.
Thank you for shopping at MATO TOYS.
Customer Service
Mato Toys International Inc.)
Old 08-28-2008 | 05:49 PM
It seems they made a mistake (or the factory did) and are happy to correct the problem.
I withdraw my previous comment.
Old 08-28-2008 | 06:22 PM
ostketten's Avatar
ORIGINAL: TXtanker
(Dear Daniel
Customer Service
I received a similar canned response, they wanted to send me a new receiver board because the tank I received simply did not work, (the lights didn't flash when it was turned on, and the tank wouldn't start at all) they told me the same thing, we send...you install... is that ok..?? Well, no it's not ok. They gave me an RMA and I sent it back and told them to repair/or replace the tank or refund my payment. I guess you'd have to decide if it's cheaper to send it back for a replacement, or spend the time to swap it out your self. I decided to send it back because even if I installed a new board, there's no guarantee it would fix the problem, whatever it is. They seem to stand behind their product, but they don't make it easy to get a defective unit replaced, I'll tell you that.
Old 08-28-2008 | 10:12 PM
YHR's Avatar
YHR
ORIGINAL: ostketten
ORIGINAL: TXtanker
(Dear Daniel
Customer Service
I always encourage people to fix the problem rather then send it back. Sooner or later you are going to be faced with a tank repair. I don't care what brand you own. You might as well roll up the sleeves and get right after it. None of these thing are RTR forever. Sooner or later something breaks.
Just for the record. THs problem you had was a while ago and not with the new Heng Long Stug, right???
Old 08-29-2008 | 12:20 AM
jom's Avatar
jom
ORIGINAL: blitzkrieg65
The Blitz
You still need the low profile gearboxes to make room for the gun "breech" recoil mechanism, or whatever, as the high mounted motor in the PIII gets in the way. There shouldn't be any difference in the hull top height.
Jo
Old 08-29-2008 | 06:47 AM
ostketten's Avatar
No, that's not right. As a matter of fact this is this first problem I've had with any brand new RC tank, HL or otherwise. For the record... I even asked Blitz for help since he's worked on quite a few of my tanks with upgrades/mods and the like, his response was that there are just too many things that could be causing that kind of problem, and he recommended I send it back to Mato, which I did. If Blitz wouldn't even recommend it, there's no way in the world I'm going to attempt it, but thanks for the encouragement, I do try to do as much on my own as possible, within my capabilities of course.
Old 08-29-2008 | 09:45 AM
YHR's Avatar
YHR
My Stug was DOA as well. Turned out the power plug to the electronics module need to be pushed in further. That is why I always suggest poking around a little. The whole return process is so cumbersome and time consuming. The new Heng long electonics are all plug and play, so changing out fried electronics has never been easier.
I only hope these new electronics are stocked as spares in the near future and Darkith can do somehting to make them IR Tamiya compatible
