 looking for a twin motor control unit >
Old 11-04-2009 | 10:30 PM
Default looking for a twin motor control unit
I'm looking for a twin motor control unit that will fit in a 1/35 that will give me independent track control. I want to have it so left stick up and down is the left track forward and back, then the right stick up and down on a 4 chan is right up and down.</p>
Old 11-05-2009 | 03:07 AM
Koenigstiger's Avatar
Default RE: looking for a twin motor control unit
Hallo,
look here please
http://www.sgs-electronic.com/index....emart&Itemid=1
It is a little company in germany and a very good contact - you can look in english !
greetings
guenther [8D]
Old 11-05-2009 | 06:28 AM
the cheapest way i know is to use the boards from inside a servo. i have built a couple of 1/35 tanks and many boats with them.
Old 11-05-2009 | 12:56 PM
hmm,I've never thought about that. Are you using your normal large scale futaba servos for that or micro servos?
Old 11-05-2009 | 01:41 PM
the biggest cheapest servo you can get. i have ben using some old g plug ones. a heat sink helps if usung a bigger motor i have used them for esc in small ships and turit traverse to.
Old 11-05-2009 | 04:14 PM
I'll have to see if I have any old futaba servo's laying around. I will be using that diy tamiya twin motor gear box. The omtors look pretty small.
Old 11-05-2009 | 04:46 PM
Panther F's Avatar
Tamiya does sell little project kits that have the wired remote and gearbox as well. You would have to adapt the axles to fit.
- Jeff
Old 11-05-2009 | 09:05 PM
Perry S.'s Avatar
Hey Hunter,
Here is a link to a mod I did a couple years ago converting a micro servo to an ESC for turret traverse in my KT. Reference Darkith, White Wolf, and Armchair General for their contributions.
Perry
http://www.rcuniverse.com/forum/m_6144490/tm.htm
