Thunder tiger ST-1
#3578
PA
RE: Thunder tiger ST-1
ok lol im afraid of walking up to the chasher and saying ok this is all i need and he looks at me like im a freking retard. lol.the only thing is that he only carried odonnels in quarts[:@] ohh well ill get like 3-4 quarts of it.
#3580
CT
sure its ok, i just add a little more oil to the fuel , the race fuel uses less oil because racers get faster speeds out of the motor for example less drag on the piston quicker rotation, with a higher oil content it needs more time to compress and turn the piston and it will have more drag but it will most likely give your engine more lubrication.
#3581
PA
so i have to do something to it? Ill see if they have any of the other one.
The closest one only carries topfuel 20% and 33%. The other one carries a bunch of stuff.
all my lhs carries is some no name brand with like 20% oil and top fuel...
sigh
sigh
#3582
Keith, I got suckered into the ofna box with 550s too! Seriously, with the 2x8.4v batteries it works great. The batteries are only $35 ($45 w/ smart charger). I got mine from ebay (with answers Mr. Slave's question)
http://cgi.ebay.com/Two-8-4V-NiMH-38...742.m153.l1262
#3583
CT
ORIGINAL: soccerlaw
lol i got suckerd into the twin 740's , biggest pos i ever spent for 100 bucks, i would of traded you for it. but yea the 12v isint powerfull enough you need atleast 16v to even turn over the motor more than 5 seconds.
#3584
OK
ORIGINAL: jombo
#3585
Is there a big advantage of either TT special smaller wing or a standard 1/8 extended wing? Why should I spend the extra money to use the 1/8, is it worth it?
#3587
ON, CANADA
It is nice and flexible yet holds its shape well. The TT truggy wings are cheaper then the other 1/8th scale wings. You need ONLY 1/8th scale truggy or buggy wings.
http://www.amainhobbies.com/index.php/cPath/1_24_212
Truggy wings IMO look best buggy wings are to big.
#3588
To mount the TTR one I dont need any kits right? I just ordered the RTR kit, does it come with the stock wing kit? I was reading something about having to buy more body posts?
#3589
ORIGINAL: ericem
#3590
CA
ORIGINAL: ItchyBum
Try an OS#8, this is a pretty standard plug for all .28's (except turbo head engines) They work well in the stock engine
#3591
PA
http://www.amainhobbies.com/product_...ducts_id/13530
thats the one I run and has taken 10x the beating of my himoto wing but still hasnt broken.
#3592
ON, CANADA
ORIGINAL: Pexeter
Sorry for sounding like a moron, I just want to be sure I buy what I need and nothing else. So my 2 options are: Buy the extended wing kit and a 1/8 truggy wing or just buy the $9 Thunder Tiger Wing and mount it to the stock kit that came with my RTR?
ORIGINAL: ericem
#3593
Just doing the steering mod now. With the longer 25mm screws the bolt rubs on the plastic attached to the chassis - is this normal? I remember you guys saying that you didn't need to chop or sand down anything. My new dremel arrived at the same time as the 25mm screws so I ended up just filing down the ends of the screws a little and smoothing out the plastic where the a-arm connects. Anyone else run into this issue?
#3595
WI
if you don't have the extended wing mount you can still use a wing, and yes, the body will still fit. i should have pics of mine in my gallery or my my models thing. if you dont get the extended wing mount, you get two more body posts and attach them to the rear shock tower and use the wing mount that's already on there for the wing.
#3596
ORIGINAL: redfox03
I was just a little confused because at Amain in the wing mount description it says you need to buy both the regular wing mount AND the extended wing mount for it to work. But alas, this wasnt the case for the RTR that already has the regular wing kit parts.
#3597
Hi Guys,
Could anyone tell me if this would fit the standard size servo?
http://cgi.ebay.co.uk/CNC-Single-alu...QQcmdZViewItem
I managed to strip the splines on mine at the weekend doing some cartwheels down a banking
Thanks in advance
Thanks in advance
#3599
ORIGINAL: mk3miniturbo
Hi Guys,
Thanks in advance
Hi Guys,
Thanks in advance
#3600
Maybe, maybe not. Your better off just taking the servo to a hobby shop and ask them for a servo horn to fit it on the spot
