---OFFICIAL CASTER RACING K8T TRUGGY THREAD---
#52
FL
RE: ---OFFICIAL CASTER RACING K8T TRUGGY THREAD---
I am running a spektrum DX3 and Hitec 5955 (333oz) servo for steering and Hitec 645 (140oz) for throttle.
#53
NJ
ORIGINAL: vnmsgt
Here are some pics of it with the jconcepts body.bkept it simple, did not feel like masking and doing different colors. Almost ready to hit the track now!
TB
#54
FL
ORIGINAL: Tweedybird
I'm likeing the blue wing and wheels, which ritt dye did you use? denim blue or the other one? I think they only have 2 blues.
TB
ORIGINAL: vnmsgt
TB
#55
Hi I have a new K8T Factory Team kit, which I have been building up for our first round for 08 season at my local track.
There is not much on set up information that I can find, I have asked Mikey from the factory for some setup hints and he gave me a bit of info for shock/diff oils, but any other help would be good!!!!!!!
I would like to dye my wheels before I fit new proline tyres, please tell me what sort of dye you use, is it clothing or hair? (lol)
Cheers Bryan
Cheers Bryan
#56
PA
sweet!
#57
ORIGINAL: rckiwi
Cheers Bryan
Cheers Bryan
just boil the water, add the dye, and soak your items for about 30 mins. less time for a lighter shade of that color or more for a deeper color. simple as that. good luck
#58
FL
ORIGINAL: rckiwi
Cheers Bryan
Cheers Bryan
#60
ORIGINAL: vnmsgt
Have you gone to [link]http://truggyracers.com[/link]? They have a thread there for the K8T that has alot of setup info. I just broke mine in today FINALLY and will run it this weekend. I have not done anything to it yet so I will find out how it runs on sunday.
ORIGINAL: rckiwi
Cheers Bryan
Cheers Bryan
My first outing is also this Sunday, so I will post my results after. I have just been down to our track, as it is only 5 mins drive from my house and just run it to check how it looked on the track. But racing will be different!
Let you know how I get on...
Cheers Bryan
#61
FL
ORIGINAL: TheKaiman
Did it come with stone guards? If not, do you think the Mugen stone guards would fit?
#62
I have tons of Losi stickers you can put on there...The losi co. does'nt scemp on anything not even stickers...
#63
FL
ORIGINAL: BIGAIRBEN
#66
CA
Here's a few Photos of my Modded Caster..The Shocks I'm going to be using are the Ofna Big Bores (Rears for the front and rear) Radio Gear is: Spektrum DX3R, JR Z9100T for steering, For throttle an Airtronics 94357, Motor: Novarossi Plus 21-7BT (should be enough).
#67
FL
Cool I see you found the thread I told you about. Its pretty new here and I do not have too much info from mine yet since I am running it for the first time tomorrow.
#69
Hi all,
Well first day of racing in K8T Factory Team Kit!
Weather was warm and fine, track is clay surface. But because we haven't had rain here for 8 weeks the surface was really loose and hard, so wasn't the best to really get a good idea of the cars capabilities.
First heat was just getting a feel for the car and what it would do, the track conditions made it a bit hard to predict the cars handling. But all in all not too bad.
Second & third heat, changed a couple of things on the car moved rear lower shock mount positions to outter hole on the rear and the same on the front. finished both heats about the middle of the pack and managed to start in the C main.
Now I must point out to you all now that I am not a seasoned racer! I am just out there for fun and this is only my second season as such racing 1/8 scale. (I normally run 1/5 cars on & off road)
C-Main Final. Well it came and went! I flamed out at the start and couldn't get it going again, first time my STS Team motor has fail me!
Oh well there is always next meeting on the 16th March
Couple of pic's I took of my K8T before racing!
#70
I got my k8t the other day and was setting up my servos. I cant seem to get all the steering to work when i turn left. when i turn right it turns all the way . when I turn left it doesnt turn all the way? can someone help me out, im just getting frustrated. thanks alot if you can help
#71
ORIGINAL: 808rc/car
Is it RTR kit?
If not RTR what radio & servos you running?
Any other information to help you solve your problem
Cheers Bryan
#72
FL
Well my day did not go as planned. My motor was still so tight my bump box would not start it so I could not run it till I go home. Finally got it started and ran a tank through and that Picco is a beast!! Only issues I had were the servo saver spring is WAY TOO SOFT. I have it turned all the way up and my wheels still go a little straight on acceleration. Guess I will be getting the mugen spring! Also after the next tank it stalled the my clutch bell was wobbling, thought my bearings went bad but when I removed the bell the bearings were fine. The clearance in the bell for the bearing is a little too big and wollowed the hole out some and wore it out. Put another bell on it and it was nice and tight. Still have to run it some more to loosen up the motor as even after 7 tanks I still have to heat it up. Seemed to handle really well and smooth from the time I have driven it
#74
ORIGINAL: 2DMaxLST!!
I would order knuckles, 6-12 lower front a-arms, a bunch of ring and pinions, several spurs and some brakes disks, based on what I've seen. They drive very well, I've driven them, they they are just not as stout as a Mugen MBX5-T Propec or even my Xray.
ORIGINAL: vnmsgt
I am quite sure they did not just break. You have to hit something to break it. I have seen alot of truggies break arms, and knuckles from just the lightest hits at the right position, it happens. I guess all of the guys on the forums I read that absolutely love the thing must be something like the ST-1 guys and never say a single bad thing about them no matter what happens... LOL!
What did they do to break them. Was there a reason or something. Just checking because I might be ordering some parts since I have a chance to get some at a very cheap price right now.
These were the latest versions. One did not even run because a diff went out. The others had broken a-arms, front knuckles, a rounded out brake disk etc.
#75
FL
I had to read that 5 times before I realized you were talking about the X-Ray in your reply! LOL
