GO .25 Breakin in (heat cycle) F-UP!
#51
CA
RE: GO .25 Breakin in (heat cycle) F-UP!
ORIGINAL: droidswarm
Tree1 + Windowlicker - Thanks for the good advice (and grown-up flame-free discussion) - I will definatley take your advice onboard once I have solved the goddam clutch!
Tree1 - Did you install the extra "break-in" shim or does it come already installed?
To be perfectly honest, I am not sure if the .25 engines come with the extra break-in shim. I know that Go Tech engines come shimmed for 30% nitro out of the box.
ORIGINAL: windowlicker
i saw a drop in temperatures on the second tank,from about 240 to 210,so i leaned it a little,still very rich though.after my race on sunday,it was running about 250,so i richened it again.i hope it will drop again like you say.it still is very tight and will not turn over by hand when cold (havnt tried when hot,too hot to touch!)
I didnt get a manual in the box with my engine (second hand but never used) so thanks for letting me know about that shim.are you sure it applies to my engine to as well as the .21s?
Like I stated above I am not sure if the .25 mills come with the break-in shim. The purpose of the extra shim is to reduce compression to make it easier to turn the engine over during the break-in procedure. I know they came with my .21s and I assumed they came with all the Go Tech mills since they are all super tight.
#52
My .25 came with one shim. How many did yours come with? And how do you know which is the break in shim?
#53
My 5port came with one in the box and three shims installed. I installed the extra break in shim and will remove around a gallon or so. You guys have any problems with your carb being loose? I shaved the pinch bolt down but it did not help?
#54
CA
Chedzter
My carb moves slightly but I use high speed/torque servos from Hitec. I also sealed my engines and my mills are holding their tune well. The carb seems to move slightly when I apply my brakes. Try adjusting your brake/throttle end points.
#55
MB, CANADA
the carb should NEVER move...even slightly.....and if so you are using WAY too much travel on the brake side...Or u have an Overly Stiff throttle spring....i dunno but none of the GO carbs ive worked on had any wiggle to them.
#56
CA
My carbs move so little maybe 1mm. I have tried to adjust my brake end points but I didn't feel like it was enough to stop by buggy and truggy. I will try to re-adjust and see how well my rigs stop and also see if I don't have any movement of the carb.
#57
I can wiggle my carb by hand which I know is not good. The carb on my SW .26 wont budge when tightened down. I emailed racefactor so we will see. I guess Im being picky but a loose carb could easily suck air causing tuning issues.
#58
MB, CANADA
ORIGINAL: Chedzter
a loose care can cause Nightmarish tuning issues....one's that haunt u in your sleep.
#59
VA
If any of you want to learn any thing about any of the GO motors, tuneing,
the loose carb fix, proper break-in, then please log on to RC Tech.com.
There is a thread of over a hundred pages on just GO motors. The thread
is in the "Off Road" threads. Do yourselves a favor and check it out, before
you ruin your new motors. I own four modded GO motors and some of the
things that you guys are doing are not good for your new motors. Brian
Carey of Pro Twister Mods also has a thread on there and he is a great GO
engine modder and would be more than happy to help you out.
#60
CA
ORIGINAL: INTEGRA
Rageworks is correct. There is a ton of information on the RCTech thread. Check it out
#61
www.rc-tech.com? Its down at the moment but i will check it out
#62
hmmm, regarding the shims i never had an extra shim in my box, i've not taken the head off yet to see how many are installed as im still a little short of the Gallon mark. I run 20% always, i should have 2 shims or one?
#63
one shim for 20%... well thats on the 5&7 port .21's.... i think the site is www.rctech.net not .com
#64
Thanks F-R, will prob leave it for another half a gallon then have a look how many is there and leave one if there is 2 or 3.
#65
On the new Gos there is a thick alum shim and two .1mm brass shims. In the box there is also a .2mm shim for break in. Install it for breakin then take out at around a gallon or so as soon as the pinch is gone.
#66
Finally got the ST moving under its own steam!! After taking the clutch apart and finding nothing wrong, I reset the needles as shown in Chedzters post and it worked fine - I had the engine so fat before the revs just werent getting high enough to engage the clutch!
Anyhow, for the first tank I had it off the ground, running at idle, with tinfoil round the the head and was getting 210-215deg. I tried dabbing the throttle and slightly leaning the HSN (maybe 3-4 hours) to get the temps up, but couldnt get past 220. For the second tank I was running round (speed as low as possible), and the temps were at 280, so I removed the tinfoil and they dropped to 260, but even when I returned the HSN to the flush position the temps didnt drop any more. Thats where i finished for the day.
Have I screwed it up by having the temps too cold/hot? How are you supposed to control the temps when adjusting the HSN didnt seem to make an impact?
#67
Adjust the LSN. I found that adjusting the HSN during break in did nearly nothing. Because during break in the engine is only revving around its low end, the LSN is the most effective needle. Its only during high RPM that the HSN will take effect. Try richening the LSN a little. As long as you didn't drive it too long with those temps, you should be ok I think. Anyway, its done now!
#69
Those temps are normal during break in, 260 -280 is fine.
Go engines like to be really hot during break in, as long as you have good smoke the engine is getting lubricated.
The high temps help to mate the piston to the sleve.
Once the metal pinch goes (after 4 - 5 litres) the temps will drop.
#70
I need some help. I'm trying to break in my GO .25 6 Port. I can't get the gas to the carb without taking the pressure tube off the header and blowing the fuel into the carb. When I'm trying to start it and squeeze the throttle the gas actually pushes out of the carb. I've sealed the backplate and the bottom of the carb with sealant. I got the black two needle carb. When I do get it started and can rev it, as soon as I remove the glow plug igniter it cuts off. I heat the head with a blow dryer and wrap the head with foil to get the temps up.
HALP!!
HALP!!
