ESM FW D-9
#2551
#2552
can anybody tell if Tysplanes cockpit is ok for that plane;
do you have any problems while fitting it inside the plane;should anyone have to make any reinforcements;
thanks
thanks
#2555
Good luck
dave
#2557
I'm onto my 15-20th liter of fuel thought it and I need to take the cowl off to lean it out a little more. it has gotten significantly stronger as it has bedded in. Would love to get another one to put into another model, but I'm busy playing with my next german project that doesn's spin a prop for power
dave
#2558
#2564
http://www.rcscalebuilder.com/forum/...TID=21256&PN=1
Good kit for sport scale but needs quite a bit of work. There is also a Youtube video for installation by Ty.
If you want something more scale then take a look at Iflytailies.com They offer great cockpit kits and details.
http://www.iflytailies.com/store/ins...uct-4774050365
Jason
#2565
Jason
#2567
My Feedback: (8)
Hey Ram here's my GeeBee vid...done with an iPad so the flight video was pretty much sky and engine noise.... landing was rhe best to watch. Definitely ready to get the 190 started http://youtu.be/JllSz4d9hjc
#2568
Dave, +1 to Ticketec. I built and installed the Tys cockpit. I did a build thread at RCSB.
Jason
Jason
has anybody ever tried to fit a cockpit kit from http://www.iflytailies.com/store/ins...uct-4774050365 into an ESM FW 190 D9; I am asking that because I used their kit in a Carf p-51 mustang and it required a little modification because i had the 1/4 scale version cockpit kit and carf p-51 isnt 1/4 scale, so i had to trim a little :
#2569
Chris, I think the XYZ would be the best solution but it is real close. Its a twin so it will vibrate less. I think it only fits because the molded cowl flaps are partially open. In retrospect, I think I would have did the XYZ. I put in the DLE 55 and the head sticks out the bottom by about 1.5 inches. Not too bad but still unsightly if you want to go for the clean look. Ticketec has tons of experience with it and I think he was the first to install one in this plane.
Jason
Jason
lots of informations there!
i am really impressed by the way you created in indents in your canopy by using the covering iron. at what temperature did you set the iron;
thanks, jim
#2570
Jim,
Thanks for the kind words. I'm not sure what the temp is. I have it turned up about 3/4. Take it slow and don't rush it. You don't want to push through. The cowl flaps were fun and work great. They really add to the realism.
For the iflytailies cockpit it says on the site that you may have to trim a little to get the correct fit.
Jason
Jason
#2571
Jim,
Jason
Jason
#2574
