ESM FW D-9
#1177
My Feedback: (8)
RE: ESM FW D-9
ORIGINAL: GerKonig
I have a question since so many here were talking about Zenoahs. I used to have mine serviced by B&B, and had a Z26 ready to be sent out when mr Bennett passed away. Do you know any other place that services Zenoahs and have reasonable prices?
Thank you
Gerry
Thank you
Gerry
#1178
RE: ESM FW D-9
ORIGINAL: n8622t
GerKonig, I just sent 2 G26 to Horizon Hobby...they replaced the cranks, bearings, and repaired the carbs from crash damage. All this work on both for $200. Bob Bennett is definitely a loss to our hobby.[]
ORIGINAL: GerKonig
Thank you
Gerry
Thank you
Gerry
#1179
RE: ESM FW D-9
I got a little work done on the Dora over the weekend. I mounted the flaps and installed the links to the flying surfaces. Need to fine tune the flaps a bit, but that isa detail. I have (I guess needless to say) decided to drop the redplastic wheel wells. I haveglassed the wheel wellsand will paint them next.
Does anyone know what colourthe wellsare supposed to be?
I did a little bit of painting on the cockpit, too. Still a lot of details to be worked out, but one gets the idea. I probably have not been very accurate with the colours, butthe walkaround literature I have a my disposal shows all sorts of colour schemes in the cockpit.
As far as wheels are concerned, I think I will go with the Williams brothers 4 1/2". I did get a quote from Glennis. While their products are superb, the price made my stomach turn.
Next up is installing the engine (DLE55) and the retracts.
#1180
RE: ESM FW D-9
Williams brothers make a 5.1/4 wheel i tried the 4.1/2 (far to small i thought) in side the wheel well again you do need to open out the well slighty to fit the 5 1/4 for a really nice fit
#1181
RE: ESM FW D-9
ORIGINAL: STICK MODE
OK, thanks for the heads up.
#1183
RE: ESM FW D-9
ORIGINAL: Ramstein44
In previous post, I used the 5-1/4 Glennis wheels. Like mentioned, a little trimming did the trick! Have you considered the SIST wheels at $150???
I did, and contacted Stephan about it. Unfortunately, they are out of the wheels, as are Fighteraces. No reply from Sierra. Also, no cigar on the spinner. Sist had one with a diameter of 126 mm, which I deemed to large. The opening in the front of the cowling is 140mm. I was therefere thinking about a spinner more in the range 110-114mm.
Ram, what is the diameter of your spinner?
#1185
RE: ESM FW D-9
ORIGINAL: P47Pilot
I got a little work done on the Dora over the weekend. I mounted the flaps and installed the links to the flying surfaces. Need to fine tune the flaps a bit, but that is a detail. I have (I guess needless to say) decided to drop the red plastic wheel wells. I have glassed the wheel wells and will paint them next.
Does anyone know what colour the wells are supposed to be?
Looking good there mate with the cockpit. I'm off to do some more with mine right now!
dave
#1186
My Feedback: (8)
RE: ESM FW D-9
#1187
RE: ESM FW D-9
this is the model http://www3.towerhobbies.com/cgi-bin...&I=LXWAC7&P=SM
hope this helps
hope this helps
#1191
My Feedback: (157)
RE: ESM FW D-9
Unfortunately my friend, they're spoken for, my Holman Dora I've been working on for too long now is getting the last set i have. If I dump one of my doras, I'll give you an awesome deal on a set. I do have a very rare set of Glennis wheels that are under construction from Glennis in future works, the six holed Anton wheels in 5-1/4. I had planned to use them on my Dave platt FW but I'm using a set of SIST wheels on her due to version change.
#1192
RE: ESM FW D-9
Let me know if you want to part with the six holed Anton wheels if you have them there, because of my anal tendencies to be full out in scale ever time I would drop the gear with the Williams Bros wheels and don’t get me wrong there ok there would be this cringe from me lol think you know where im coming from cheers ps dont dump its not a good look and i know you have put a lot in to them [:-]
#1193
My Feedback: (157)
RE: ESM FW D-9
Yeah, I hear you. I only say dump due to the laws of physics. What goes up must come down and not always as you planned it[&o] I've lost several FW's like this. One after two years of building all to lose her on the maiden.[:@]I'll pm you on the wheels and send some pictures, they're still mounted on the Anton for now.
#1195
RE: ESM FW D-9
Physics dont you just hate it[&o] yes been there done that much tears later some days you got to ask your self as i have done why we put our selfs through this hobby [:@] only redeming factor is when it comes together nice on a good day the grin is worth it ( or so i keep kidding my self )
#1196
RE: ESM FW D-9
Hey stick mode, I'll have to meet you when my family comes there to visit her other family (aunts and so on) in Auckland, north shore, Birkenhead. Maybe you can throw a rock through their window before we get there..lol you can show me the flying fields.
#1198
RE: ESM FW D-9
Here is another update on the cockpit painting.
The white bits you see cut out are for the added details I'm putting on. The round item with the serations around the outside is for the artifical horizon. The Fw-190 had that very distictive look about them. What I did was to draw them up and them up on th computer and them sending them to my vinyl cutter. Seeing as my vinyl cutter handles the 0.005" plastic well, I just cut three of them, laminated them together and then attached them to the instrument. the other two items are for the cutout on the hood. The full size has two stiffening plates riveted to the cutouts.
As for the painting. I have done the base RLM66 paintwork, and Have done the first past at highlights. I'll paint the various details next, and then gloss clear coat them so I can do a bit more weathering on them, before finally clearing them with a flat.
dave
dave
#1200
RE: ESM FW D-9
ORIGINAL: ticketec
dave
dave
