Reload this Page >
CARF F4U-1 Corsair build thread
Old 12-21-2014, 07:39 PM
  #2876
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Formation and nav lights.
ID:	2056856   Click image for larger version
ID:	2056857   Click image for larger version
Old 12-22-2014, 07:50 AM
  #2877
Corsair2013
Corsair2013's Avatar
Looks Great Gary
Happy Holidays to you and your family and everyone on here!!!
Keith
Old 12-31-2014, 10:39 AM
  #2878
ram3500-RCU
My Feedback: (221)
Here is a look at the mod needed for the intake install. A before and after. The intake itself, when glued in with gorilla glue or epoxy replaces the webbing removed.
ID:	2059223   Click image for larger version
Old 12-31-2014, 10:40 AM
  #2879
ram3500-RCU
My Feedback: (221)
Originally Posted by Corsair2013
Looks Great Gary
Keith
Thanks Keith
Old 12-31-2014, 01:12 PM
  #2880
ram3500-RCU
My Feedback: (221)
Here are the guns fully installed. This is Bruce's wing, but Dennis, yours looks the same. Brian builds the 'barrels' with the orange lights installed, so you have them as well, even though you are not getting the guns at this point. Later, if you decide to go with them, it is an easy thing to add the batteries, speakers (we also install the mount for these at this point), and control box.
For those just doing the gun port fairings, this is how they should look when you are done.
ID:	2059265   Click image for larger version
ID:	2059266   Click image for larger version
Old 12-31-2014, 01:17 PM
  #2881
ram3500-RCU
My Feedback: (221)
Here are the lights fully installed in the outer panels. The aluminum is Aerofoil from Meister and is installed on aircraft that are going to be weathered as this one will be.
ID:	2059268   Click image for larger version
ID:	2059269   Click image for larger version
ID:	2059270   Click image for larger version
ID:	2059271   Click image for larger version
ID:	2059277   Click image for larger version
ID:	2059278   Click image for larger version
ID:	2059279   Click image for larger version
Old 01-10-2015, 06:51 PM
  #2882
ram3500-RCU
My Feedback: (221)
I finally was able to locate some grill material for the oil coolers in the scale intakes we make. The new perforated material is stainless steel, but the weight difference from the aluminum material is nominal. They are back in production and i have (6) sets being made for various projects around the world, plus our own builds. Thank you all for your patience.
here is a set ready to install.
Old 01-10-2015, 06:54 PM
  #2883
ram3500-RCU
My Feedback: (221)
Here is where we install the air tanks for the main gear doors. This is a (closed) system. We use no connections to the fuselage, so no disconnects. This is a handy area in the rear of the center section. Makes easy access from the front of the tanks to the area where we install the valve. The fill valve is located in the flip down panel in the bottom hatch.
ID:	2062849   Click image for larger version
Old 01-16-2015, 04:45 PM
  #2884
freddd
Gary,
in one of earlier posts you explained how you used aero foil in various parts to help with weathering (typically leading edge). I understood that aero foil or flight metal required a very good underneath surface. How did you deal with the fact that the surface has rivets detail. Did it come through the aero foil or did you "re-mark" rivets where they were coming through the aero foil. Or alternatively filled-in the rivets before applying Aero foil.
thanks
frederic
Old 01-16-2015, 05:06 PM
  #2885
ram3500-RCU
My Feedback: (221)
Good question. Aerofoil is so thin that any surface detail will translate threw it, including even dust. Rivet, panel lines, panel fasteners, and other molded detail can be brought out with a #8 artists blending stick, by rubbing (burnishing) the foil into these details. In addition to this, after the foil is applied, all these type details can be easily embossed into the foil. A #7 mechanical pencil works great for panel lines, and flush rivets can easily be made with a piece of brass tubing sharpened on the inside with an exacto knife. I solder a T handle on top to make it more comfortable.
Old 01-18-2015, 02:48 AM
  #2886
ram3500-RCU
My Feedback: (221)
The Down and Locked electric wing conversion on one of our latest builds.
https://www.youtube.com/watch?v=oEE7oN5Jkqo
2nd video after applying grease to the left wing.
https://www.youtube.com/watch?v=i60za8BO66g&feature=youtu.be
Old 01-18-2015, 05:52 AM
  #2887
ram3500-RCU
My Feedback: (221)
For those getting our bottom hatch kit, here is more explanation to help with parts ident and install. Each plane is different, so you will need to notch your ply to fit. If you are building the ARF, the first picture is how your plane will look after you cut your bottom hatch in. If you have the kit, those pieces will come in the kit and be installed by you first.
ID:	2064862   Click image for larger version
ID:	2064863   Click image for larger version
ID:	2064864   Click image for larger version
Old 01-18-2015, 06:37 AM
  #2888
ram3500-RCU
My Feedback: (221)
Here is a new video about our gun system for the Corsair. It explains its operation and installation.
https://www.youtube.com/watch?v=5Hn7...ature=youtu.be
Old 01-18-2015, 07:57 AM
  #2889
ram3500-RCU
My Feedback: (221)
This is a new video of our custom lighting system for the CARF Corsair. It provides an overview of the system, some installation instructions, and some cautions for safe use. Here are a couple pictures of the plywood housing, referred to in the video, that the builder needs to make for the tip lights.
https://www.youtube.com/watch?v=blHZ...ature=youtu.be
ID:	2065326   Click image for larger version
ID:	2065327   Click image for larger version
ID:	2065328   Click image for larger version
Old 01-18-2015, 02:42 PM
  #2890
ram3500-RCU
My Feedback: (221)
I fixed post #2886 so that both videos now play. Not sure what happened.
Old 01-18-2015, 02:53 PM
  #2891
freddd
Fyi, the first video is showing as private and cannot be opened.
frederic
Old 01-18-2015, 03:00 PM
  #2892
freddd
Thanks for the earlier explanation on Aero Foil. Looking at some of the earlier pictures, it seems that you were able after paint to reveal some of the fasteners. Was that done with general sanding (3m pad or similar) or targeting the fasteners (one by one !).
Would it had been a solution to create your rivets post paint an reveal possible the Aero Foil ?
Old 01-18-2015, 03:06 PM
  #2893
ram3500-RCU
My Feedback: (221)
frederic
Ok. I went back and checked and I must have not clicked 'publish'. It should work now. Sorry.
Old 01-18-2015, 03:12 PM
  #2894
ram3500-RCU
My Feedback: (221)
I do the fastener detail before the paint. I go back over random rivets and such after painting. Reason being that in full scale usually not all fasteners have the paint chipped off. Now as for Dzus fasteners, I do all of them as they were used frequently.
Remember, most of the Corsair was spot welded, so there is very little fastener detail aft of the cockpit, other than Dzus and screws.
Old 01-18-2015, 08:33 PM
  #2895
ram3500-RCU
My Feedback: (221)
Some examples of building done right, and.........not so much.
Flap hinges. Good.
Not so good.
ID:	2065311   Click image for larger version
Old 01-18-2015, 08:41 PM
  #2896
ram3500-RCU
My Feedback: (221)
Good job.
Not so much.
All this can be fixed, but could just as easily been done properly the first time. We should always do our homework, ask questions, use the correct materials, and in the case of the CARF products, at least on the first go around, read the manual front to back and understand it before beginning. They really have thought this through and do a good job helping the beginner.
ID:	2065316   Click image for larger version
Old 01-21-2015, 09:19 AM
  #2897
DrScoles
My Feedback: (18)
DrScoles's Avatar
Thought you would enjoy these Gary. I'm on a corsair FB group… some awesome pics for subjects and lots of restoration stuff.
Name:	Screen Shot 2015-01-21 at 9.14.47 AM.png
ID:	2065989   Click image for larger version
Name:	Screen Shot 2015-01-21 at 9.14.57 AM.png
Old 01-21-2015, 12:49 PM
  #2898
ram3500-RCU
My Feedback: (221)
Nice Mike. You never see pictures like that. Very helpful.
Old 01-21-2015, 08:23 PM
  #2899
saramos
saramos's Avatar
Gary (and everyone) You can check out 4 years of photos of a Brewster Corsair restoration at Ezell Aviation. I had the honor of spending some time working on a Goodyear Corsair there a few years back.
http://www.ezellaviation.com/project...-f3a/f3a-2011/
Scott
Old 01-21-2015, 09:01 PM
  #2900
ram3500-RCU
My Feedback: (221)
Scott
As always, thank you very much Scott.
BTW, Brian and I picked up an unbuilt plug-in version for our own fleet. It is the ARF, and we will be modeling a Goodyear Corsair (not sure which one yet). They were built just a few miles from my house.
Need to clear out the present projects first though. Spring is on the way.
