CARF F4U-1 Corsair build thread
#3001
My Feedback: (221)
Hi Ram
Beutiful work all around, a few questions please. On the down and lock linear action servo do you need a control board for the proper start, stop , reverse movement ? I tried the idea with the robart drive mechanisum and ended having to go to a Fergelli linear servo. They work without the use of any special control boards.
Second question, have you considered making the corsair interior kits for small scale application like the ESM 75" Corsair ?
Lou
Lou
Corsair parts. I have been asked this before and I appreciate the request, but until I am able to retire from our construction business and turn it completely over to my sons, I just don't have the time. My partner builder my brother is 8 years younger than me, so he too will be working for a while.
What we do now keeps us both very busy. Sometimes too busy. But we have obligations in builds for others that we are committed to. Still, I am determined to do more flying this year. I have several major events I'd like to attend. Unfortunately, I will miss my invitation to Top Gun again this year due to some family obligations, but I'm looking forward to making some later events. Actually, the first one is before Top Gun and will be in just a couple weeks in East Bend N.C. A wonderful war bird event put on by a great bunch of guys. 1000' and just a terrific site. I attended last year and had a great time. Taking Zombie, our Meister P-47, and will also have a Balsa USA Stearman.
Hope to see some of you there.
#3002
Hi Gary,
Any word on the web site? Looking forward to seeing the neat things I can get Just got my gear and folding wing conversion back from Down and Locked, super quick turn around, took about 2 weeks WOO HOO. I am starting to cut out my gear doors and getting ready for the gear install. Do you have drawings on your hinges for the gear doors, they look awesome compared to stock.
Woody
Woody
#3003
My Feedback: (221)
Hi Gary,
Woody
Woody
PS. the gear door hinges on our Top Gun Corsair had door hinges from the Graeme Mears kit, at the present not in production. I have not had time to reproduce those yet. I am close on having available the inner door skins, and hinge fairings though. Other things in the works, in addition to our other items are, a scale resin antenna, a scale gap cover kit for the strut doors, resin scale break discs, and some other things as well. Some of the latter are closer than others, and I will post when we have any of these things perfected and ready to share.
thanks for your support,
Gary
#3004
My Feedback: (221)
Hi Gary,
Woody
Woody
pic#2 shows the shims. pic#3 shows the grinding to the housing if it is forward where it needs to be. pic # 4 shows how you can locate where to make the hole in the spar for the jack screw. pic#5 shows it all bolted in place with the wood screw. pic# 6 shows how close it will be to the spar.
#3006
Thanks for the great info. I appreciate the tips for getting the gear to fit. I am amazed at how awesome your gear bays look with all the detail. Glad you and your brother are offering such cool stuff to make this bird look realistic. I was bummed to find out the Mears kit was no longer in production.
I used the small 545 dremel to cut my first set of gear doors out and it worked great. I used the back side as of a hacksaw blade as a straigthedge and went over all the panel lines to be cut with a zona saw first making it deep enough to help the rotary tool track. The hacksaw blade is nice and flexible so it followed the curves nicely.
#3008
Hey Gary, how's it going?
I've been playing around with my new 3D printer, a Lulzbot Kittaz. Here's a test print of the bulkhead behind the pilot seat in 1/6 scale.
Cheers,
Scott
Cheers,
Scott
#3009
My Feedback: (221)
Hello Scott. I have been dreaming about the potential these will have for scale builders. I have not had the money or time to invest and play with one. Plus, I'm not that computer or CAD competent. Do you have a scanner for producing the programs? I would love to see what these could do for cockpit parts, scale hinges, tail hooks, tie down hooks, light bezels, and more. Really, I'm interested in what you can do with this technology.
#3010
I still need to improve my 3D CAD skills, but now that I have a printer, I've got a lot more motivation to learn. I've had my printer up and running for only a couple of weeks, and still very much in the learning and tweaking stage. I have a couple of upgrades ready to install on the printer too. I'm definitely looking forward to see what I can achieve.
Here's an early test of the Corsair wheel. It's still lacking all the webbing, and have some print related issues to resolve
Cheers,
Scott
Cheers,
Scott
#3011
My Feedback: (221)
Short video of the final look at the repaired Corsair of Johnny Z damaged at WOD last year.
https://www.youtube.com/watch?v=IHX9...ature=youtu.be
#3012
My Feedback: (221)
Cheers,
Scott
Cheers,
Scott
#3014
My Feedback: (221)
Thought I would show you guys this if you have purchased an older Moki.
Here are two cam followers. The one on the right is from an older engine. See the tiny ball pressed into the end. These have been know to come loose. You can just about imagine what that would do to the inside of a running engine. Not pretty. The one on the left is the new design eliminating the ball.
If you have the older followers, you would want to replace them before running your engine. To check, simply find a valve in the fully closed position, lift the push-rod out of the seats, and carefully pull the cam follower out of the housing. Replacement is just as easy, but you will want to adjust all the valves afterward.
#3015
My Feedback: (221)
BTW,,Yes, time is short,, the first "local" warbird event is July 25 at CRCC, we swaped out dates this year to not conflict with the Port Clinton event, spread teh word with your club, I know a lot of your guys show up, ooh and get busy, we want to see you guys there
#3017
My Feedback: (221)
We made a short video to further explain how we set up these folding wing electric conversions. We simply do not have problems with the ones we set up. Down and Locked has spent much time and research making it reliable and simple, but how well it operates still has a lot to do with what happens on the builder end. Here is the video.
https://www.youtube.com/watch?v=9VFg...ature=youtu.be
If you are still having problems, do this.
1. Take the drive motor and jack screw out of the arms
2. Clean any oil or grease off the front hinge and folding arm pivots
3. Make sure the hinge point on the arms are loose as in the video
4. install the outer panels as if you were going to fly (completely)
5. now, lift the wings and feel for any resistance or binding
6. if you feel any, and the arms are clearly loose, take the front hinge loose and check again. If it is now free, you know the problem is with the front hinge.
They must work with no binding or friction free from any lube, which can mask a binding unit. If when completely assembled they work free and clear, without lube, then the problem is elsewhere. It could be in the connections, the length of wiring to the battery and or control box (these must be kept as short as possible so we put all the components in the center section, not the fuselage), in possibly poor solder joints if you have soldered wiring together, the battery strength (we use 2-cell liPos at least 20c), weak switch connections, or in rare cases, the motor or jack screw itself. Don't assume it is the latter as you can see that a lot of other components can have an impact on operation.
#3020
Ok,this is not the same front hinge as on my corsair! With this one you do not need to cut out in the wing for the hinge?
I see carf do not list this hinge as a sparepart on their website! maybe i can order from Sierra?
Geir
Geir
#3024
My Feedback: (221)
Well, after some refit and updating to some of our latest designs, Big Hog, the original subject of this thread, is leaving the "factory" again. Dom is here to take her home and we thought we would make this little video to commemorate the occasion. We are always available to service what we build.
https://www.youtube.com/watch?v=cDYgSNErXp4&feature=youtu.be
#3025
My Feedback: (221)
All of our Corsair builds now receive reinforcement in the cockpit area. this is the weakest part of the fuselage. I prep the area, apply Z-poxy, lay in some CF ribbon, apply Z-poxy to a piece of 1/32 ply, lay that over the area, cover the whole thing with wax paper, and then weight it down with some of our Steel Powder in freezer bags.
