Reload this Page >
CARF F4U-1 Corsair build thread
Old 05-23-2015, 05:21 PM
  #3051
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
With this all done, it was time to finally cut the thing apart. I was able to do this with my right angle dremmel and a diamond cutting wheel without cutting through the clear plastic (already cut apart in a previous step).
Now for the drive system.
ID:	2098102   Click image for larger version
ID:	2098103   Click image for larger version
Old 05-24-2015, 01:04 PM
  #3052
DrScoles
My Feedback: (18)
DrScoles's Avatar
Gary, what are you using to countersink the holes? The countersinks I have are pretty big, just wondering if you had a cooler tool ? ;-)
Old 05-24-2015, 01:53 PM
  #3053
ir3
My Feedback: (42)
Hi Gary,
I just signed up. The Corsair build is magnificent. A suggestion on counter sinks. Get a deburring tool from Aircraft Spruce or some other aircraft tool supplier. You can control the depth of the counter sink very accurately. I am not sure of the angle but I think it is correct for most common flat head screws.
Looking forward to the next update.
IR3
Old 05-26-2015, 09:00 PM
  #3054
ram3500-RCU
My Feedback: (221)
I have several counter sinks that I use. The one that fits these 2-56 machine screws very good is from a set I found at Harbor Freight. I'll post a picture, but it is part of a set of three that they sell.
Old 05-27-2015, 01:59 PM
  #3055
TonyBuilder
TonyBuilder's Avatar
Dremel at HD has some that work great, also any tap will have a counter sink on the end for the size you are using.
TB
Old 07-31-2015, 05:12 PM
  #3056
ram3500-RCU
My Feedback: (221)
Forest of Corsair gear, all converted to electric by Down and Locked.
ID:	2112100   Click image for larger version
Old 07-31-2015, 05:34 PM
  #3057
jchorak
My Feedback: (9)
[QUOTE=ram3500-RCU;12078246]Forest of Corsair gear, all converted to electric by Down and Locked.
[/QUOTEbebe
Beautiful forest......
Old 07-31-2015, 05:53 PM
  #3058
ram3500-RCU
My Feedback: (221)
Cranking this thread up. Need to catch up. :-)
Old 08-15-2015, 07:06 PM
  #3059
woody242
Hi Gary,
Any updates on new parts or your website? I am starting back up on my bird, got my gear doors and permanent covers cut out. Doing some final fitting and tweaks. Gear is in. Looks they just fit. The tabs for the cylinder mount touch the spar. I am wondering if it save to grind a bit off to gain a touch more clearance? Have yo done this. Another alternative would be to take a little off the inside of the gear doors.
I am interested if you are planning on offering more scale hinges for the doors?
Woody
Old 08-16-2015, 08:04 AM
  #3060
ram3500-RCU
My Feedback: (221)
Hello Woody. It's been a very busy year so far. Sorry for the lack of activity here. I'll do some posting this evening and address your questions. Gotta run for now.
Old 08-16-2015, 08:18 AM
  #3061
henderyckx bruno
Here some pics of my strut door solution,grtz Bruno
ID:	2114674   Click image for larger version
ID:	2114675   Click image for larger version
ID:	2114676   Click image for larger version
ID:	2114677   Click image for larger version
ID:	2114678   Click image for larger version
ID:	2114679   Click image for larger version
Old 08-16-2015, 04:42 PM
  #3062
ram3500-RCU
My Feedback: (221)
Nice solution to this part of the gear. CARF gives very little help in this area.
Old 08-17-2015, 02:58 PM
  #3063
samparfitt
My Feedback: (43)
I like it.
Old 08-18-2015, 11:29 AM
  #3064
ram3500-RCU
My Feedback: (221)
Just needs our 'leather' cover now.
Old 08-19-2015, 05:50 PM
  #3065
woody242
Hi Gary,
Update to my hinge question. What materials are the ones you have used made from. I am thinking making a set from aluminum as I have a small mill. They seem fairly simple. Aluminum may be overkill but I think that they are small enough that weight won't matter. Also if you have updated pricing I am interested in your leather covers.
Woody
Old 08-19-2015, 07:45 PM
  #3066
ram3500-RCU
My Feedback: (221)
Originally Posted by woody242
Hi Gary,
Woody
If you mean the parts holding the strut cover, Brian (my brother and 'wing'man) uses brass.
As for the gap covers, he was working on finding a material that would look like leather, but be thinner and more scale like yet flexible. He found it and it has far better elasticity than does actual leather as we used before. The result is that the strut cover can be fixed to the gear because this material stretches over the slightly larger gap. We are installing these on these currant builds and if it works as we think, they will be made available to you all.
Old 08-19-2015, 08:25 PM
  #3067
BobH
Why would the leather need to be elastic? The full scale leather hinge is bunched a bit when the gear is down..
Old 08-20-2015, 04:00 AM
  #3068
ram3500-RCU
My Feedback: (221)
Yes. But think about scaling down leather so it is pliable. The challenge in modeling. Some materials can't be scaled down. So we found a leather like material that is more to the scale thickness and thus pliable and stretches some so less bunching is necessary. This will be even more important if a modeler uses HB's method of hinging the cover to the leading edge. Not much room there for bunching anything.
Old 08-20-2015, 05:38 AM
  #3069
woody242
Hi Gary,
Thanks for the info, I am actually referring to the actual gear door hinges. I want to do something like the ones you got from Graham Mears offset hinges. I thought you were making something like that as well.
Woody
Old 08-20-2015, 05:49 AM
  #3070
ram3500-RCU
My Feedback: (221)
Hi Gary,
Woody
Ahh, not yet. A lot of work in the molds for those that I just don't have time for right now. I am salivating over these 3D printers and think they could be used for things like this. I want one that is designed for dummies like me that could not write the programs. I'm waiting for an affordable one that scans the object and then duplicates it. I know they exist now, but the price is way more than I can afford. What a tool that would be for scale builders!
Old 08-20-2015, 03:09 PM
  #3071
woody242
Well, I guess that means I have no excuses to not make it myself . I have a small tabletop cmc mill, not sure about cutting fiberglass on the mill so I will likely make them from aluminum.
Woody
Old 08-20-2015, 06:36 PM
  #3072
ram3500-RCU
My Feedback: (221)
Woody
I would like to have that equipment and skill set. Feel free to post pictures of them here. We would all love to see what you come up with. The Robart aluminum offset hinges would do the trick, but hardly look scale. The ARF version comes already hinged in an unscale fashion, but can easily be retrofitted.
Old 08-21-2015, 12:27 PM
  #3073
woody242
Will keep you posted on the development.
Old 08-24-2015, 10:00 AM
  #3074
ram3500-RCU
My Feedback: (221)
Yes, please do.
Old 08-24-2015, 07:31 PM
  #3075
ram3500-RCU
My Feedback: (221)
Wing work for Dennis.
ID:	2116581   Click image for larger version
ID:	2116582   Click image for larger version
ID:	2116583   Click image for larger version
ID:	2116584   Click image for larger version
ID:	2116585   Click image for larger version
