Reload this Page >
CARF F4U-1 Corsair build thread
Old 02-17-2013, 02:57 PM
  #1826
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Default RE: CARF F4U-1 Corsair build thread
I got a call from a modeler building my cowl flap system, and he asked the length of the stand-offs for the plywood rings to the firewall. They are 23/32. Now keep in mind that this is using 3/16" thick ply for both rings. If you use 1/4" on them, then you need to make the corresponding adjustment in the depth of the stand-offs, so the cowl will fit nicely.
Old 02-17-2013, 03:04 PM
  #1827
ram3500-RCU
My Feedback: (221)
Also, note the additional holes I have drilled in the rings. The two large ones are for the exhaust pipes, the smaller ones are for additional air flow. This is so, with the Moki, you can close the flaps a few more degrees in flight. With these holes, and the baffling, you should be able to fly with the flaps set about where the stock cowl is molded to. On the ground, you will want them all the way open, which gives you much better air flow than the stock cowl.
I drill these holes with a forstner bit in my bench top drill press before the flaps are glued on.
Old 02-17-2013, 06:40 PM
  #1828
ram3500-RCU
My Feedback: (221)
Wing light progress. Just need to screw the tip lenses on. The bezels are made from aluminum foil. They just need the fasteners embossed into them.
ID:	1853312   Click image for larger version
ID:	1853313   Click image for larger version
ID:	1853314   Click image for larger version
ID:	1853315   Click image for larger version
ID:	1853316   Click image for larger version
ID:	1853317   Click image for larger version
Old 02-17-2013, 06:47 PM
  #1829
ram3500-RCU
My Feedback: (221)
With the power to them. They are set up so you can use any batteries you want from 4.8 to 7.4V.
ID:	1853321   Click image for larger version
ID:	1853322   Click image for larger version
Old 02-17-2013, 06:48 PM
  #1830
JSZ
My Feedback: (73)
JSZ's Avatar
Looks great, nice work!
Old 02-17-2013, 06:50 PM
  #1831
ram3500-RCU
My Feedback: (221)
Wing mount added to the outer panel of the plug-in wings.
Old 02-17-2013, 07:00 PM
  #1832
ram3500-RCU
My Feedback: (221)
This is rare in our experience with CARF. The right and left wings were not built the same. The ribs are off on the right wing. This made it necessary to enlarge the hole for the push rod to the flaps in the right panel.
ID:	1853325   Click image for larger version
Old 02-17-2013, 07:04 PM
  #1833
ram3500-RCU
My Feedback: (221)
The infamous aileron servos. Use the very best servos you can get your hands on, and aluminum servo arms with a compression lock for the spline. They need to have extreme holding power, and you don't want to have to take them out very often.
Old 02-17-2013, 07:08 PM
  #1834
ram3500-RCU
My Feedback: (221)
Another shot of the lights on the starboard wing.
Old 02-17-2013, 07:17 PM
  #1835
ram3500-RCU
My Feedback: (221)
We are in the process of making the molds for the gun fairings. We will be making these fairings available separately, and will include them in the complete gun kit. Amusingly, CARF does not even help you locate these ports.
ID:	1853342   Click image for larger version
ID:	1853343   Click image for larger version
Old 02-17-2013, 07:18 PM
  #1836
vfrank59
ORIGINAL: ram3500-RCU
WhooHooo. I am standing by for a set.
vern
Old 02-17-2013, 07:20 PM
  #1837
ram3500-RCU
My Feedback: (221)
ORIGINAL: vfrank59
vern
I still can't understand why CARF did not even mark them on the wings. A "museum scale" war bird?
Graeme had a beautiful set, but you can't get them. It is some work because you need a right and a left set, but it just needs to be done. We will do it. Once the plug is made, vac u-forming is easy. They will be molded out of styrene like cockpit parts.
Old 02-17-2013, 07:28 PM
  #1838
ram3500-RCU
My Feedback: (221)
ORIGINAL: JSZ
Thanks buddy.
Old 02-17-2013, 07:29 PM
  #1839
MRadu
MRadu's Avatar
Hello Gary,
I'm ready to order your lighting system. If not ready with guns. I'm ready for all wing lights minus the tips. I also need the blue fuselage on top light. Can you make a special order?
Old 02-17-2013, 07:43 PM
  #1840
ram3500-RCU
My Feedback: (221)
For those who have purchased the wing tip set, here is what you will receive.
1. right and left LED assemblies with currant limiters to prevent over volt burnouts
2. screws for the tip lenses
3. (3) tip lenses (in case you miss cut one)
4. aluminum foil to line the inside of your plywood tip cut outs (made by the builder because each one mat be slightly different depending on the cut out)
Old 02-17-2013, 07:50 PM
  #1841
vfrank59
Gary,
I must have missed the info , on how to order the lighting set. Can you put that info out? I want to deck mine out also.
vErn
Old 02-17-2013, 07:51 PM
  #1842
ram3500-RCU
My Feedback: (221)
ORIGINAL: MRadu
Hello Gary,
Yes in deed. I'll put it together and PM you. Do you want the fuselage wire harness with the switch / battery devise, as well?
Old 02-17-2013, 07:55 PM
  #1843
ram3500-RCU
My Feedback: (221)
ORIGINAL: vfrank59
Gary,
vErn
I am going to post an ad in the classified section to make it easy, now that we have the lights all worked out. I'll do that this evening yet. I'll post a link in here when done.
Thanks for your support.
Old 02-17-2013, 07:57 PM
  #1844
MRadu
MRadu's Avatar
Yes please,
This is so great. They are show stoppers and the best I have seen. Great work to you both.
Thank you.
Old 02-17-2013, 08:12 PM
  #1845
vfrank59
ORIGINAL: MRadu
Hello Gary,
yep, wire harness with the switch / battery devise. The painless way for me.
thanks,
vern
Old 02-17-2013, 09:07 PM
  #1846
ram3500-RCU
My Feedback: (221)
ORIGINAL: vfrank59
Gary,
vErn
Here is a link to the ad I posted.
http://www.rcuniverse.com/market/ite...231&electric=0
Old 02-17-2013, 09:12 PM
  #1847
ram3500-RCU
My Feedback: (221)
ORIGINAL: MRadu
Yes please,
Thank you.
Thank you. The thing is, they are custom to the Corsair, and not just generic lighting. Some nav lights like the wing tip and tail lights will be very similar on other WWII fighters. We will do systems for other planes as we have time to do the research develop them.
Old 02-17-2013, 11:56 PM
  #1848
Chris Nicastro
Chris Nicastro's Avatar
I didnt catch this info but are you offering a scale wheel detail set for the brakes on the mains?
Old 02-18-2013, 12:26 AM
  #1849
ram3500-RCU
My Feedback: (221)
ORIGINAL: Chris Nicastro
That detail was made for us by a friend. We have no plans at this time to offer it ourselves.
Old 02-20-2013, 07:23 PM
  #1850
ram3500-RCU
My Feedback: (221)
I have a couple modelers in the process of adding the cowl flaps to their models. Some more info on the cowl flap rings.
Bruce, the front ring diameter will be 12 9/16". This will be ever so slightly large, so you can fine tune it to your cowl, after you have cut the cowl flaps off. It is easier to fit it after the cowl flaps are cut off, because you can easily see where it fits. The back of the cowl, less the flaps will be flush with the back of this ring. This forms a guide for the mounting of the cowl, and supports it nicely when screwed in place. This means that you can pour epoxy mixed with Steel Powder in the ring around the front of the cowl with complete confidence it will stay firmly in place with the extra ballast right where you want it, as far forward as you can get it.
The inside diameter of the front ring is 8 1/4".
Now, I think Bruce had what I think is a good idea. Before you cut the center out of the front ring, you have a great tool to help you locate the engine. Subtract 1" from the length of each stand-off (the distance that the front of the cowl ring is from the front of the firewall that the engine will be mounted to. Now use these shortened stand-offs (this will set the proper thrust angles) and place your engine on the cowl ring, with the cowl over it (you will need to have it on the edge of your work bench so the two fixed flaps can hang over the edge. Center your engine in the cowl orienting it for the exhaust ports, and mark it for the bolts. Now all you need to do is center this plywood plate on the firewall and mark the hols for the engine bolts.
