Reload this Page >
CARF F4U-1 Corsair build thread
Old 08-24-2015, 07:37 PM
  #3076
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
Old 08-24-2015, 07:41 PM
  #3077
ram3500-RCU
My Feedback: (221)
Even with the redesigned front wing hinge, a small cutout is required in the outer panel. We do this with a cutout in the panel, and a matching half moon added to the center section. This eliminates the need for either a cut out, or a movable cover.
Old 08-24-2015, 07:44 PM
  #3078
ram3500-RCU
My Feedback: (221)
Gun barrels, ports, and lights going in. The barrels are left connected until they are fitted to insure proper spacing.
ID:	2116589   Click image for larger version
ID:	2116590   Click image for larger version
Old 08-29-2015, 09:37 PM
  #3079
ram3500-RCU
My Feedback: (221)
Latest gun installs.
Speaker mount
ID:	2117247   Click image for larger version
ID:	2117248   Click image for larger version
ID:	2117249   Click image for larger version
ID:	2117250   Click image for larger version
ID:	2117251   Click image for larger version
ID:	2117252   Click image for larger version
ID:	2117255   Click image for larger version
Old 08-29-2015, 09:48 PM
  #3080
ram3500-RCU
My Feedback: (221)
These support pieces CARF has added to the gear mounts in the ARF version. In the past we had to add these ourselves.
Old 08-29-2015, 09:51 PM
  #3081
ram3500-RCU
My Feedback: (221)
This is the best fit on these factory installed doors that we have seen. They even have added these stops.
Old 08-29-2015, 10:11 PM
  #3082
ram3500-RCU
My Feedback: (221)
This area has been changed as well. This component was formerly made of balsa. It is now made of a composite sandwich material. Very strong, very straight, very stable.
ID:	2117262   Click image for larger version
Old 08-29-2015, 10:14 PM
  #3083
ram3500-RCU
My Feedback: (221)
The air tanks for the main gear doors, the only thing we still use air for.
Old 10-07-2015, 03:25 AM
  #3084
skymaster68
hello, anyone running the moki 300 on the carf corsair?? I notice that the 300 is bigger than the 250 and wont fit, if anyone is running the 300 can advice how much work was installing it?
thxs in advance for the help
Old 10-07-2015, 04:17 AM
  #3085
Salte
Hello,
The Moki 300 fit in the carf corsair and Works Perfect! the 300 give deeper sound and wery good speed
The 300 is not more work to install then the 250.
https://www.youtube.com/watch?v=Y71lTPvZDfA
Brg Geir
Old 10-09-2015, 03:49 AM
  #3086
skymaster68
Thanks for the info I got info from carf that as the 300 is bigger than the 250 it wouldnt fit inside the cowl, can you confirm on that? Did you have to modify the cowl?
thxs
Old 10-09-2015, 04:02 AM
  #3087
Salte
The moki 300 fit in the Carf corsair with out modify enything! I have the arf folding wing and mounted all the Equipment and batterys in the front + i think it was ca150gr of lead!
I am wery happy with this combo and no regrets for using the 300
http://www.modellflynytt.no/showthre...t=carf+corsair
Geir
Old 10-09-2015, 06:35 AM
  #3088
ram3500-RCU
My Feedback: (221)
This is news to us. Good news, but I can not confirm. The 250 fits very tight as it is. The 257 - 7 cylinder fits for sure as it is actually a little smaller in diameter than the 250.
I will say that the 250 is way more than scale power for this plane. It will virtually leap into the air with this engine. Full throttle is not needed or recommended even with this combination as the air frame has limits not to be exceeded, which can be, even with 250 driving the less-than-optimally-efficieant 3-blade Solo Prop. Even the 215 pulls this aircraft with authority.
Just food for thought.
Old 10-09-2015, 06:49 AM
  #3089
ram3500-RCU
My Feedback: (221)
BTW, I am on a short vacation from h.......ll. We got to Orlando and one day later my mother in law (possibly on her last trip anywhere) fell in the room due to a small stroke she had while walking to the bathroom with her walker. My wife, an RN, saw it happen and was quick to get the squad coming. Turns out that if she had been at home unattended, that may have been the end right there due to the small brain bleed driven by really high blood pressure at the time. They were quick to get the blood pressure coming down. She has been in the hospital ever since, at times claiming they are trying to kill her and rigging the machines to give false readings to keep her there, and that we are going to leave her there to die. My wife calls it sundowners due to the brain bleed, and deals with this sort of thing all the time as she works in critical care. They don't get paid enough after seeing what they do, IMO .
I know this is off topic, but wanted to let you all know why the delayed responses on things. Hope to be back home next week but we can't leave till gramma is released.
As Arnold says, I'llll Be Baaaaaauuuuuck.
Old 10-09-2015, 09:23 AM
  #3090
Darkbird
My Feedback: (7)
Thoughts going out to you from one of the thread lurkers Gary. Take care of your family, and hope things get better for you.
Old 10-09-2015, 10:10 AM
  #3091
panhandler
Hope all is well Gary.
Dan
Old 10-09-2015, 12:55 PM
  #3092
ram3500-RCU
My Feedback: (221)
Thanks guys. Looks like we are in Florida a little longer. My wife is really stressed out. It doesn't end when we leave. Her mom and dad have been living in their home. He has Alzheimer and now she will not be able to take care of him. Big changes to confront in the next few days. My dad was killed in a plane crash at 38. Mom was alone when we had all this to deal with. She also passed from Alzheimer. Much easier then. This is going to be interesting for awhile. Today, she wanted my wife to put her in the dish washer.
Old 10-09-2015, 02:09 PM
  #3093
Salte
I had no problem to fit the 300 but it is absolutly max diameter for that airframe! it run wery smooth and with some trottlecontrol you can fly this one as smooth as the 250!(i have had some 250s) but wery Nice when opening the trottle I fly this corsair all season also With big speed and no problem!
I agree With you that the 215-250 is good for this airframe but for me big is better
I hope everything will turn for better With Your Family.
Brg Geir
Old 10-09-2015, 03:02 PM
  #3094
ram3500-RCU
My Feedback: (221)
Thank you for your post. I'm sure it will help many. Also thank you for your kind concern. We will figure this out.
Old 10-22-2015, 06:00 AM
  #3095
Tuggs
Tuggs's Avatar
Hello Corsair Pilots,
I have a question regarding the wing folding meachanism. I noticed that it takes longer and longer each time for the wings go up and down. In the beginning it took less than 20 seconds for the wings to fold and unfold. Now its takes more than a minute and sometimes i even need to manually speed up the process by pushing the wing down or up. I increased the pressure already on the system, but with no effect. The pump feels the same as before, judging by the noise it makes when the pump runs).
Maybe some has noticed that also and knows how to fix Thanks....
This is my corsair
Old 10-22-2015, 08:26 AM
  #3096
ram3500-RCU
My Feedback: (221)
This is my corsair
Good looking bird.
You may want to check the pressure in the accumulator. It may be loosing pressure somewhere. If that is ok,i would look into the pump itself. Like any pump, the inturnal seals can wear.
Please let us know what yo find. Might help others.
Old 10-24-2015, 06:00 PM
  #3097
saramos
saramos's Avatar
Learning 3D CAD has been more of a challenge than I thought it would be. It's taken me a long time to get to this point, but I am pretty happy with the results. I am also 4 hours into a 20 hour 3D printout of the front half of the wheel. I'll post a photo of the results tomorrow. Here's a rendering of the wheel and a photo of an earlier printout of the front half with out as much detail.
I printed it using a Lulzbot Kittaz that Iv'e upgraded to a TAZ 5. The print is done in ABS with a .08mm layer height and a .25mm nozzle.
Scott.
Name:	Corsair Wheel cutaway2.jpg
ID:	2127405   Click image for larger version
Old 10-24-2015, 06:33 PM
  #3098
ram3500-RCU
My Feedback: (221)
Very nice Scott. Thank you for the update. Looking forward to seeing more.
Old 10-24-2015, 06:49 PM
  #3099
ram3500-RCU
My Feedback: (221)
Thought I would update our situation.
The almost impossible happened in that my mother-in-law's insurance agreed to pay for the air ambulance to fly her home to Ohio from Orlando. This was done last Sunday. She has since been admitted to a local rehab facility. Still some tough decisions to make as right now they are recommending assisted living rather than returning to her home when she is released. Tough because my father in law is suffering from Alzheimer and can't be on his own either. Moving them in with us may not be possible. Still, we are all home and getting on with things. Although my work in the shop has taken a serious hit, i'm getting back at it.
Thanks for all your support.
Old 10-24-2015, 07:54 PM
  #3100
panhandler
Welcome back my friend.
Sounds like you have everything well in hand.
My best to your family.
Dan
