ESM Mitsubishi J2M3 Raiden build
#76
RE: ESM Mitsubishi J2M3 Raiden build
I got my replacement canopy and cowl today. The replacement canopy is actually way nicer than the one it came with; much cleaner paint lines.
The cowl my Raiden came with was not the correct shade of green, it was lighter. My replacement cowl is an exact match to the fuse. Nice.
I am waiting on Tomas to get back to me about the electric retracts. That is the one thing holding me back from gluing the wings together.
I am also doing lights on my Raiden. I will be cutting out/molding new tip and tail lenses.
http://www3.towerhobbies.com/cgi-bin...&I=LXDZ90&P=ML
The Raiden was a Navy aircraft and had no landing light. One less thing to worry about.
#77
ORIGINAL: fockewulf37
Slowly working along...
Ty
Ty
#78
I am going ahead with my lights. I have cut out the appropriate areas of the wing tips. The removed section will be cut further for the actual lens.
The wings are built perfectly for the lights as the tips are hollow fiberglass and there are plenty of holes to run wires through.
Lights are a RAM large scale kit.
#80
A note about touch-up paint. After spending like 30 bucks trying (and failing) to find Testors Model Masters that matched the Raiden I went to Home Depot. I gave them an aileron and they matched the upper and lower colors perfectly. They will match the paint and give you the small 8 ounce "sample" containers that are only 3 bucks each. You could probably paint the whole plane over for just 6 bucks! Don't waste your time buying tiny $7 model paints.
#81
I refined the chunks I cut out into frames extremely carefully with my Dremel. Now to fit the lenses into these and make the light mounts in the tips.
These RAM lights are incandescent so they do get hot. I'm not sure a styrene base will hold up to the heat. Maybe I'll use wood?
#82
Here's the lights base. 1/8 balsa whose grain I filled with this pine car brush on wood filler, which is the best stuff I have ever seen for filling wood. It took forever to find a close up of the tip lights on the Raiden so I could get the light in the correct location.
#85
Are you doing the radio box behind the seat Ty?
I finished my tip lights at 4:00am last night. Here is a daytime close-up. I really like how they came out. They will look even better after some detailing and weathering. I am working on the tail strobe now.
#89
Those lenses look great, I was in too much of a hurry to get mine airborne, but it will get similar treatment when time allows!! That cockpit is coming on great too!!
Ian.
Ian.
#91
ORIGINAL: n8622t
Looks good Sess...I may have to follow your lead I have always wanted a plane with lights and have never done it so you are giving me the incentive. Do you have any gear for the plane yet?
#92
ORIGINAL: Idigbo
Ian.
Ian.
#93
Tail strobe is done. I couldn't just make a plunge mold of the rear tip of the fuse because it is not the correct shape. It needs to be much pointier than how it comes. I had to make a new balsa tip and then mold that. I did it the same way I did the tip lenses, clear Styrene sheet and a heat gun. My iPhone pictures don't do the lights justice but I think they came out really well.
Anyone know how bright these lights would have been in the full scale? This RAM system is made to operate on 8.4 volts but they are super super bright at that voltage. They look more realistic on 4.8 in my opinion.
#94
ORIGINAL: Sessholvlaru
Awesome shot! Any reason why you have the gear doors off it?
No reason other than I didn't have time to make the proper doors for it. As you'll know already, the door is two piece, with the lower sliding over the upper section. Then there's the inners!!!! It will get them, I promise.
Looking forward to your next post, Ian.
Ian.
#96
ORIGINAL: Idigbo
Ian.
Ian.
Do you have any pics of how you hid your aileron control horns? I am trying to figure out how to best do this...
#99
Hey guys I am finally finished. I should have these out the first of next week...Hopefully
Ty
Ty
