Spitfire Brotherhood (All Spitfires Welcome)
#2401
My Feedback: (14)
RE: Spitfire Brotherhood (All Spitfires Welcome)
ORIGINAL: OldScaleGuy
A rude awakening this morning. The electric retracts are not going to work. Once the hole is cut out for the motor (where the air cylinder typically is located) and the slot for the strut there would be nothing left of the outer rib that the retract mounts to. That would a wing failure in the making. So,,,,, have to take a step back and order the Robart gear. The Robart cylinder can be set up so that the cylinder can be moved 180 degrees there fore not weakening the wing structure. I have studied changing the electric retract in the same manner but it doesn't appear possilbe. You fella's that have built the Top Flite Spitfire, if am missing something, please clue me in.
I'm surprised they wouldn't work. I used the same retracts in my Kyosho Spit and they pretty much dropped right in.
You can see how they work in this video: http://youtu.be/B0uR9yJv6gI
#2402
Hey Fella's. Caps are going to be $20 each shipped if i can fit them into a Small Flat Rate box. $14 for the cap, $6 for shipping. If you want more than one, we can adjust the price for the shipping accordingly. Outside the lower 48 will be actual shipping cost. Not doing this to make a profit, just need to cover the cost.
Once the order is placed it will take one to two weeks before they arrive. Then we will ship to you asap.
Are all of you ok with that?
I am okay with the price and shipping. Just send me a Pay Pal invoice and I will pay you.
Thank you for doing this for the brotherhood!!
Sonny
aka
jet22b
BTW: This is a order for one!! Thanks!!!
#2403
Thanks on the caps fella's. Next thing to do is come up with the correct number to order.
Radfordc, i will post a picture of the hole i added to the wing rib just to slide the body of the retract into. I think the main thing is the design of the wing is different.
#2404
WBG
#2405
Here are some pictures of both the HK retract and the Robarts. With the HK in place and having to remove the material for the strut you can see that rib 5 does not have a lot holding it together, just a thin portion at the top. One thing i did discover on the Robart gear is they are very tight in the housing. When taking them apart to reverse the cylinder i added Labelle 106 Teflon grease. That smoothed the action considerably and the "tight" feeling was greatly reduced. Labelle 106 is formulated for plastic so any of you out there using these plastic Robart gear may want to consider that.
#2406
Hi All,
Can I join the Brotherhood??
I have the H-9 Spity on my bench right now.
I think the Spitfire is the best looking plane ever built..(Well...exept from the Stearman, Please don't hate me for saying that all of you spitfire lovers out there...).
#2407
Steve;
I am like you and think that will be to much wood to be remove to install the HK retracts. I always try to come up with a way to make the landing gear mounts stronger. The Robart was a little tight fitting in the mount, but the hole in the rib was just the right spot for the retract cylinder on the gears!! It is too bad the HK cylinder is not like the one on the Robart gear. They look like they will work, but for me that is to much wood to remove to mount them.
A question to the Brotherhood!!
A was down at Home Deport in their paint department, looking for colors to paint my Top Flite Spirtfire and was wondering if any have painted a model RC planes with the paints that they sell?? My local hobby shop do not stock paints for airplane, but they do stock paints for cars!!
Any info will be a big help!!!
Thanks, brothers!!!
Sonny
aka
jet22b
Thanks, brothers!!!
Sonny
aka
jet22b
#2408
Welcome to the Brotherhood nirtza79, i am sure #1 will get you signed up soon.
Thanks for the input Sonny. I have been epoxying in the landing gear rails today and patching the hole that was ground in for the HK gear. If you are going to use gasoline, (i cannot recall right off what engine you are using) then the latex from Home Depot will work. I finished a 50% Smith Miniplane last year with Behr exterior latex. It worked ok. I think i will try Klass Kote on this Spitfire. If you are using a glow engine, then the latex paint is not a good idea unless you can come up with a fuel proof clear coat. I have tested several clear coats over latex and am yet to find something that i really like.
#2409
Steve;
Thanks for the info!! Yes I am going with a Magnum XL 91FS Blue Head four stroke engine. I will look on the net to find more info on the Klass Kote paints. Like I post before, I do miss the old hobby shop!!! You could walk in and find everything you need to paint a model plane!!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#2410
ORIGINAL: jet22b
Steve;
Thanks, brothers!!!
Sonny
aka
jet22b
Steve;
Thanks, brothers!!!
Sonny
aka
jet22b
On this link go down to "Articles" and there are two "Parts" on painting with latex house paint.
http://www.vaillyaviation.com/Intro.html
I painted both of these planes with HD exterior latex house paint.
#2411
Here are some pictures of both the HK retract and the Robarts. With the HK in place and having to remove the material for the strut you can see that rib 5 does not have a lot holding it together, just a thin portion at the top. One thing i did discover on the Robart gear is they are very tight in the housing. When taking them apart to reverse the cylinder i added Labelle 106 Teflon grease. That smoothed the action considerably and the ''tight'' feeling was greatly reduced. Labelle 106 is formulated for plastic so any of you out there using these plastic Robart gear may want to consider that.
If you decide that's how you would do it, I can send you the material to do that with. No charge. I gots plenty of 2 oz cloth and cf tow.
Just let me know.
Jamie aka wbg
#2412
tevans55;
Thanks for the link!!! Lots of good info. Very nice painting job done on the two planes!!! I will still have to go by Lowes and talk to their paint department. On their TV adds they say they can match any color you bring in!!! I will down load a picture of a Spitfire that has the colors that I want to do my plane after and see if they can do that!!!
Thanks again for the link and the info!!!
Sonny
aka
jet22b
Sonny
aka
jet22b
#2413
My Feedback: (22)
ORIGINAL: nirtza79
Hi All,
Hi All,
183. nirtza79
#2414
My Feedback: (22)
Sonny,
I just painted a plane with the Exterior Latex paint from Lowes. (I chose flat colors)
It was my first experience with it, but I really like it.
I ironed the monokote colors I was going to be using to 2 pieces of balsa about 4 inch square. They matched to colors about as close as I have ever seen with other enamel paints.
It sprays great and dries faster than you would think. I also like the water clean-up and no fume environment.
1. Use Exterior paint
2. Mix in one pint cans
3. Use the cheap Auto Zone or Wal-Mart brand blue windshield washer fluid to thin it with at 25% thinner. The alcohol helps in the drying process and the light soap helps it flow out on the surface.
4. Add one spoon full of flotrol to assist in spraying and flowing.
5. Adjust gun for a light tack coat first, then heaver on the second coat. (If it gets a run, no problem, just wipe it with a damp lint free cloth and recoat. It will fill and flow nicely.)
6. I used a heat lamp from a distance to speed up the drying times, and it flattens out nicely.
7. I use a HVLP touch up gun at 30 - 40 PSI at the gun. But use whatever pressures work for you and your gun.
8. The clean up was the best, just water. In the past I spent as much for thinner for cleaning as I spent on everything for the paint job. Now I can afford to hose out my gun between each coat and color to reuse the risk of clogs. I was also able to spray it with my air brush with some additional cleaning. (Next time I plan to thin my material at 50% for the air brush.
Check out the P-40:
Check out the P-40:
#2415
My Feedback: (22)
Brotherhood Update, we now have 183 in our squadron.
Welcome to the Spitfire Brotherhood #:
183. nirtza79
Start Date: 12-28-2011
Current Date: 3-29-2013
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
64.mad web tv scientist
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. Old Navy Flyer
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
129. Seamus OLeprosy
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
138. Scratchbuilder46
139. jchtr3a/John Harrigal
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
146. Michel Gravelle
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
If you would like to join the Spitfire Brotherhood please send me a PM or e-mail right here from RCU, or just make your request on this thread. I will track and assign you a number.
Never can tell when you may run into another Spitfire Brother somewhere, so join now.
183. nirtza79
Roster
1.Warbirdrcer
1.5 Talimena Kidd
2.tfarmer96
3.KP
4.Helijet
5.Brad3301
6.MajorTomski
7.Daddysam
8.FireBee
9.denoferth
10.Landeck
11.jcpenney
12.jet22b
13.funfly-RCU
14.flyingpiggy
15.glazier808
16.Super Chief
17.verbails
18.jetjockey 3
19.triumphman49
20.Trent Smith
21.rtigg
22.saito18
23.warbirdguy
24.stephanmk1
25.Rotten40851
26.kenair
27.aerofalcon
28.DGUY
29.dasintex
30.Chad Veich
31.Asanders
32.hy flyr
33.dgiokas
34.Capt Easy
35.Meschmidt
36.Cal Branton
37.Pitts532M
38.dennymo
39.lovehydro
40.YellowAircraft
41.flyingchef
42.thrawn150
43.j-d
44.tevans55
45.H. Dale
46.bonemadderek
47.flyntruk
48.discusmike
49.HAM639
50.redtail
51.barron
52.Saramos
53.discusmike
54.tclocs
55.Vasek
56.Saburo Sakai
57.Nordicz
58.Orvis
59.Tony Iannucelli
60.Lifer
61.Crash Bandicoute
62.CRJDriver
63.fytrjok
65.David Bathe
66.77chickenhawk
67.stimul8tor
68.hockeypilot
69.JoeSpitfire
70.Flakbait
71.SIX GUNS
72.spadsriver09
73.ForcesR
74.rogera
75.Hairy46
76.markhamregular
77.JL636
78.wpdunn3
79.Warbird 1
80.Moparmaniac
81.moto-x
82.baldeagle
83.2001az
84.schulze rocks
85.Skopik
86.Syd Byrne
87.albsurfer
88.KiwiKid
89.shanksow
90.JORDY200
91.mistermnkim
92.SuchIsLife
93.RCdude13
94.wphilb
95.hal_bert
96.prgonzalez
97.bogeyp38
98.TwinTurboZ
99.Jimmy Skids
100. SafetyWrench
101. Peter OZ
102. Old Navy Flyer
103. tahfiet
104. Pakcikjo
105. marquisvns
106. TheEdge
107. ahgoodman
108. F4u5
109. rcnats
110. John Taylor
111. Larry Kruse
112. Jim Reynolds
113. skysnake
114. Spitfire7856
115. Eds Trek
116. P51Tom
117. Wayne
118. Jimm
119. SteveD-RCU
120. jln1320
121. Moggy
122. 108buzz
123. Tobbe
124. blkangus
125. Mark Franke
126. Phat Reliant
127. flygono
128. Ford34tom
130. facia
131. catboater
132. Chucksolo69
133. Hooton Park
134. perttime
135. spura
136. oo7fly4fun
137. RPRCBuilder
140. DLap
141. Klap
142. Capstan
143. N1EDM
144. OldScaleGuy
145. C.O.
147. TTRotary
148. ARUP
149. rebranger
150. davidhand
151. InboundLZ
152. Prekin
153. A6TEXAN
154. oh44007
155. DougB1
156. sailormc
157. ccostant
158. Dweed7944
159. maddog 71
160. Jaoa68
160.5 Agent E
161. Bumble.bee78
162. ddemarco
163. dshorrock
164. Emil The Swede
165. smkrcflyer
166. f16man
167. peterduplessis
168. Morgax
169. goph
170. TimJ
171. paladin
172. Motoman326
173. Quikturn
174. kahloq
175. dinodigger II
176. eagledancer
177. tom sandiego
178. raaf
179. Spitfire 1a
180. mogman
181. salisbug
182. dcwwcp
183. nirtza79
#2417
ORIGINAL: WARBIRDRCER
Sonny,
oldscaleguy is correct. Glow fuel and house paints do not blend well.
I will take some flat clear Monokote spray and test some on the paint I have and report back to you soon.
Sonny,
Let it cure for at least a week. Then it will be as close to fuel proof as any of the others.
WBG
#2418
#1;
Thanks for the info. I know that the paints that Lowe's and Home Deport sell do stand up to the weather, but, like you said, they will not stand up to the fuel we are using. I was in my local hobby shop yesterday and I was talking to the owner and I ask why he don't stock airplane paints supplies?? The answer was there is not a high demand for airplane paint, not like back in the days. I look at him and said, there are people who still like to build and paint their model. But the bottom line is to make money and you don't want to stock things that don't sell fast!! He also said that in the 5 years that he open the shop, he told me you can count on one hand the number of people coming in to buy paint, but covering he can not keep in-stock!!!
Thanks, again for the info and I will wait for the info on your test!!!
Sonny
aka
jet22b
BTW: Happy Easter to the Brotherhood!!!
Sonny
aka
jet22b
#2419
One of the best paint sealers is Klass Kote epoxy. Get their Clear part A and part B also the flatner that they sell. You can then mix the degree
of sheen you want using their flatner. Anything from satin to dead flat,a little of this stuff goes a long way. If you mist it on on two or three coats, letting it dry between coats, it will stand up to 25% nitro with no problem. The key is to mist it on, as putting it on heavy will cause a reaction with almostall other types of paint. It also protects decals very well.
Klass Kote is essentially thesame stuff as the old K &B Superpoxy.
Cheers,
Cheers,
#2420
Hi all, I know, that you deal some other topic, but I have one question. Which one Spitfire Mk IX looks better? With the round or spiky rudder?
I would like to start new priject- BT Spitfire Mk VIII/ IX 83" wingspan. I can´t decide which one I should choose. Round or spiky rudder Mk IX? And some good paint scheme?
Thank for your opinions, you can wrtite here or send me a PM.
#2421
My Feedback: (14)
Flew the Kyosho Spit this morning and everything went very well. The RCG 20 runs good and has more power than needed. The electric HK retracts worked well. Plane flew nice and smooth...it does drop the left wing when stalled. Landing was slow and smooth.
#2422
My Feedback: (14)
ORIGINAL: Prekin
I would like to start new priject- BT Spitfire Mk VIII/ IX 83'' wingspan. I can´t decide which one I should choose. Round or spiky rudder Mk IX? And some good paint scheme?
#2423
Prekin,
I have the same kit, It's a beautiful kit for sure! I personally like the "spiky" tail, as you call it. One thing to keep in mind is that the "spiky" tail version had a retractable tailwheel where the round tail version had a fixed tailwheel. That is the MkVIII(spiky vs. MkIX Round)
As far as paint schemes go, I prefer the desert schemes myself.
Casey
Casey
#2424
I know, what are you mean. I like both of them, but maybe you know about some good paint scheme for the Mk IX with the spiky or round rudder. So maybe the paint scheme decides which one I would choose.
By the way I like brunette.
Casey, you are right, Mk VIII has retractable tailwheel, but there are some Mk IX with the "spiky" (what is the right calling?) rudder without it. Here are some pictures.
