Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 09-06-2014, 02:24 PM
  #3251
captainron
captainron's Avatar
OMG..........That is hilarious .......................We need a cool Logo. I'm on having some shirts made also. XXX for you Frank and XX1/2 for me.....lol.
Old 09-07-2014, 04:42 AM
  #3252
sparky4lawndart
My Feedback: (10)
sparky4lawndart's Avatar
I've already got your shirt Ron. You can pick, blue or white... I'll see you in Colorado!!!
Old 09-12-2014, 07:04 PM
  #3253
BearBow
I appreciate the answers about cockpits....I finally got the IFlyTallies cockpit...it is awesome....yes expensive, but nothing else like it out there....same with Sierra Rectracts....definitely worth the wait and aggravation.....they are phenomenal. And their wheels are the finest I've seen....heavy, yes, but not that heavy for a Warbird, and they work and will last.
But I REALLY need help on wing tip position lights. I can only the 3D style lite kits for night flying. Has anyone found a wingtip kit of red/green/white that could be used or modified for this Plane?
Also, anyone put in a bomb drop hookup in the belly? how and what did you use?
Thanks, Brad
Old 09-13-2014, 05:36 AM
  #3254
WWIIP38
My Feedback: (43)
RAM lights work well; http://www3.towerhobbies.com/cgi-bin...P?I=LXDZ90&P=8
Hobby King has a bomb release mechanism; http://www.hobbyking.com/hobbyking/s...ug_n_drop.html
Old 09-14-2014, 09:04 AM
  #3255
hpergm
hpergm's Avatar
Considering engine options for the bird - would appreciate some opinions.
I am between an FG84 R3 and an FG60 R3.
The advantages of the 60R3 are that it is... smaller, so it can also be retrofitted to a TF Zero (next bird in sight, slimmer cowl), it apparently has updated inlet geometry (much like the Ray English mod for the FG84) and costs 20-30% less.
Question is, would it be enough for a 11-12kg FW190 (25-26lbs) with a 22x10 @ 6500?
"Enough" does not mean 3D or anything, just able to pull you out of trouble in a messed-up approach and allow mid-to-large loops from level.
Old 09-15-2014, 08:57 AM
  #3256
BobH
A 50cc engine is enough for a 25 lb plane. So a 60cc is as good or better.
Old 09-15-2014, 05:45 PM
  #3257
BearBow
Default Fw190
Have to remember it's not a real 60cc....it's a 4stroke 60....not the same as a 2 cycle 60 at all....the 84cc 4 stroke is more closely related to a 60cc.....I'm building with the 84cc 4stroke R3 and glad I am. Plus you lose the nose weights.
Old 09-15-2014, 05:49 PM
  #3258
BearBow
Well; my friend Andy and myself have started in on the FW190. Using the Saito 84cc Radial, and Sierra retracts and wheels.....they are simply a thing of beauty....Andy made the mod to fit the Sierra's in one evening....here are some pictures.
ID:	2032241   Click image for larger version
ID:	2032242   Click image for larger version
ID:	2032243   Click image for larger version
ID:	2032244   Click image for larger version
ID:	2032245   Click image for larger version
ID:	2032246   Click image for larger version
ID:	2032247   Click image for larger version
Old 09-15-2014, 06:55 PM
  #3259
BobH
lol it is a real 60cc.. just a 4 stroke version.
Old 09-15-2014, 11:28 PM
  #3260
hpergm
hpergm's Avatar
Originally Posted by BearBow
Have to remember it's not a real 60cc....it's a 4stroke 60....not the same as a 2 cycle 60 at all....the 84cc 4 stroke is more closely related to a 60cc.....I'm building with the 60 and glad I am.
Plane looks good Bear! You mean you build with an 84 (not a 60..?).
Old 09-16-2014, 03:05 AM
  #3261
BearBow
Yes, I'm using the Saito Gas 84cc 4stroke, 3cyl radial. Its probably closer to a 70 2stroke in power but tons of torque. Swings a 23x12x3 Biela prop. We'll be able to completely remove the front nose weights, having replaced it with a heavier motor instead. Also installed the Kiela Ring muffler. Its a wicked sound and power with no additional overall weight.
Old 09-16-2014, 03:19 AM
  #3262
BearBow
Hi Bob,
It's Brad here. C'mon you know all 4 strokes lose 25%-30% of their power compared to the same cc sized 2 stroke. So yes it's a 60cc, but doesn't have near the same performance as a 60.
Glad to see you're following this thread. Hope to be ready for your excellent weathering process soon.
Old 09-16-2014, 06:01 AM
  #3263
BobH
Hey a brad well yes rpm wise the 4strokes can't compete with the 2 strokes. Torque wise they are much better. Is the difference now so great as before? I'm not convinced it is.
bring over the plane and I'll,teach you weathering!
Old 09-17-2014, 05:25 PM
  #3264
BearBow
Default Saito 84cc 3Cyl Radial Install / Motor Box mod
We've started in on the Motor Box....Installing a Saito 84cc 3cyl 4stroke Radial, and it requires either rounding the corners or moving the entire firewall back....we chose the latte to maintain all corners for strength. Plus we were to replace the cheap Chinese plywood that splits and delaminates with good US 1/2" aircraft grade plywood. Andy laid it all out in AutoCad to maintain all the angles and offsets for thrust, etc. Looks great and will not fit the Carb and Keleo Ring Muffler with no issues.
ID:	2033117   Click image for larger version
ID:	2033118   Click image for larger version
ID:	2033119   Click image for larger version
ID:	2033120   Click image for larger version
ID:	2033121   Click image for larger version
ID:	2033122   Click image for larger version
ID:	2033123   Click image for larger version
ID:	2033125   Click image for larger version
ID:	2033126   Click image for larger version
ID:	2033127   Click image for larger version
ID:	2033128   Click image for larger version
ID:	2033129   Click image for larger version
ID:	2033130   Click image for larger version
ID:	2033131   Click image for larger version
ID:	2033133   Click image for larger version
ID:	2033134   Click image for larger version
ID:	2033135   Click image for larger version
ID:	2033136   Click image for larger version
Old 09-17-2014, 10:53 PM
  #3265
hpergm
hpergm's Avatar
Bear - exactly how I am thinking of doing it! (salivating...).
I am curious to see how you will deal with the cooling issues. Opening some side vents on the fuz and hollowing out the exhaust stacks? Louvres on the cowl underside?
Also, what did the mod on the engine cost (you can PM me)? Does Ray need the whole engine or just some parts?
Hector.
Old 09-18-2014, 01:57 AM
  #3266
mirored
Andy here....
Cooling? Not sure we need it
Actually, it will be a challenge, but will come in time. More so than the discharge air, I am working on blocking and directing the intake across the heads. That will be a copy of a design from a previous plane. I will send pics to Brad as I progress. The immediate challenge is using the designed cowl mounts with the Keleo muffler in the way of a few of them. But, I will get it.
Old 09-18-2014, 04:14 AM
  #3267
hpergm
hpergm's Avatar
If you look ~50 pages back, there is a gentleman from Taiwan who did a pretty good install. He solved the cowl mount problem from behind (access via the gun hood). Have a look - its worth it.
Old 09-21-2014, 07:27 PM
  #3268
BearBow
Andy's got the Sierra tailwheel now in and the cowl done. They're awesome. I'll post some pix tomorrow as well and let Andy comment on the build techniques if he'd like.
Some years ago Andy took 4th in Stand Off Scale at the Nats with a midsize Corsair in civilian racing colors of Burgundy and Creme. Its gorgeous. I'm hoping he'll share some pix with you here of his ready to maiden recreation of that same plane using a rebuilt Hangar 9 Corsair and the same 84cc Saito radial. Its amazing and very different.
Old 09-22-2014, 03:17 AM
  #3269
mirored
The FW-190 is definitely coming out extremely well, especially with all of the modifications for landing gear and engine. Well worth the effort, though.
The Corsair is also coming out nice. It definitely takes me back to the 85 Nationals when I entered the same plane color scheme. I have included the original B/W photo of Cook Cleland's plane and the color photo of the current build I am finishing up. Brad and I should be ready about the same time to maiden each plane together.
ID:	2034103   Click image for larger version
Old 09-22-2014, 03:45 AM
  #3270
tp777fo
My Feedback: (28)
tp777fo's Avatar
Anyone have the cost to get the FG-84 modified?
Old 09-22-2014, 09:02 AM
  #3271
BearBow
It's not cheap, but well worth it....it's a different engine afterwards....Ray just recently went on Contract with Saito to work all their new R&D projects as well as do these mods on the radials....the cost was $499, plus the $175 Keleo exhaust....You really need to add that exhaust to get the full effect. You can have Ray just install it while he has your engine vice ordering separately and mailing the exhaust to him.....he has several on hand.
Old 09-22-2014, 09:07 AM
  #3272
BearBow
Here are the pix of the Cowl Mod that Andy did....two bolts in the front and two from behind....have to take the wing off, but it's a very clean install. Also pix of the cool Sierra Tailwheel install. A lot different look than the Robart generic tailwheel.
ID:	2034187   Click image for larger version
ID:	2034188   Click image for larger version
ID:	2034189   Click image for larger version
ID:	2034190   Click image for larger version
ID:	2034191   Click image for larger version
ID:	2034192   Click image for larger version
ID:	2034193   Click image for larger version
ID:	2034195   Click image for larger version
ID:	2034196   Click image for larger version
ID:	2034197   Click image for larger version
ID:	2034198   Click image for larger version
ID:	2034199   Click image for larger version
ID:	2034200   Click image for larger version
ID:	2034201   Click image for larger version
ID:	2034203   Click image for larger version
ID:	2034204   Click image for larger version
ID:	2034205   Click image for larger version
Old 09-22-2014, 09:52 AM
  #3273
Tony Gag Jr.
My Feedback: (124)
Tony Gag Jr.'s Avatar
Has anyone found a good paint match for the green monokote?
Tony
Old 09-22-2014, 10:06 AM
  #3274
dasintex
My Feedback: (10)
dasintex's Avatar
What is the top mount attached to, did you place a block up there to screw it to, or did you cut an access hole through the side of the rudder to bulld something for it to be attached too?
Old 09-22-2014, 10:48 AM
  #3275
Lifer
Lifer's Avatar
Tony,
Take a sample of the covering to a Home Depot and they can match it precisely in a water-based paint. The sample jars only cost about 3 dollars and will be plenty for most needs.
