TF FW190 GIANT ARF
#3426
The FS FW-190 has 5 degree wing dihedral; has anyone measured the wing dihedral for this TF FW-190? Looking at the video in post #3408 above, the wing dihedral loooks to be 2 or 3 degree only?
Roger
Roger
#3428
Roger
#3429
I totally agree with you. At the time I got the answer, it was just not worth debating the point since they were not going to change their kits. Instead I just build from Brian Taylor, Jerry Bates and Dave Platt plans. I have no argument with TF, lots of people fly their planes and love them. Even if the dihedral looks a little wonky and the landing gear is incorrect.
Since you are changing the dihedral on your FW, consider using Sierra retracts so that your gear angle will look right as well.
Cheers,
Andy
Cheers,
Andy
#3430
Cheers,
Andy
Cheers,
Andy
Roger
#3432
Yahoo; received my TF FW-190 ARF this evening. Checked the wing dihedral and confirmed it is only 2 degrees. I'll change that to the correct dihedral of 5 degrees when I begin assembly.
Roger
Roger
#3433
Yes they do, and as stand off scale models, they are pretty good. For all that are happy flying them and enjoying them for what they are, it's nice to have a company that provides them for us. I admit to building a couple of TF warbird kits and flying the heck out of them.
Cheers,
Cheers,
#3434
I tried my Robart electrics the other day and all seem to work fine except one of the mains...the actuator doesnt work properly when fitted in the retract as it seems that it stops due to some forces which seem to stop the actuator.
When pushing slightly the pin to help the retract it goes fine but obviously this is not an option and need to come up with a solution!
Has anybody had any problems with the electric retracts glitching ?
I will run a separate battery to give plenty of volts ( 7.4v 2s ) in case the actuator needs it.
#3435
Say Rev - you might be the bloke to ask.
Off-topic for this thread, but I'm trying to get some info re a prop extension shaft so I can set my Saito 180 further back in a CMP BF 109 to avoid having to hack the cowl too much.
If you or anyone else has any recommendations, would it be possible to PM me (so I don't clutter up this thread with O/T babble) ?
BJ
PS - the FG sounds BOSS man!
BJ
thanks, I really love the sound too!
Sorry, I overlooked the Extension question. I would als justengines.co.uk. They do one offs like this all the time. Just contact andrew for a quote.
rev
#3436
#3437
My Feedback: (10)
the pins on the trunion can bend easily on bad landings. particularly if the wheels are toe in at all. (toe them out one degree) On occasion I have to disassemble the retract and correct the angle of the pin that slides inside the plastic block. it's quite easy. leave the strut on the trunion and remove it from the retract. you will have to remove every screw. next use a cresent or adjustable wrench that is about the same length of the strut. size it for the pin to be corrected which is the pin closest to the strut. set the trunion down on a table or against any secure surface ( i use my leg!) and simply bend the pin back by putting opposite pressure between the strut and the wrench. youll feel it move slightly. next eye the alignment with the other pin and keep working it until you get it right. reassemble the retract and that should clear it up. i've had my electrics for 2 years and they work quite well. the trunion pins could be tougher but then I'd just be fixing the wing all the time. this method works on the pnuematics too
#3439
Been absent for a while due to other projects. Have run a couple 5 min tanks thru the 84 while taxiing and getting throws set up. No maiden yet due to Wx. Will add some pix with final graphics work. Its incredible. The pull from the 23x12x3 is simply monstrous.
I got the Hobbypax wing tote bag. But Not impressed. Fit is loose. In fact I'll sell it for $60 plus postage. Its brand new.
I went with a custom fitted wing bag from Revoc. WOW. Its a perfect fit and comes in many colors. I got dark Grey. Arrived in 2 weeks from Europe. Not cheap, but a bag actually worth it. You can add D-ring hooks for free to hang on the wall. http://www.revoc.eu
#3440
I got the Hobbypax wing tote bag. But Not impressed. Fit is loose. In fact I'll sell it for $50 plus postage. Its brand new.
I went with a custom fitted wing bag from Revox. WOW. Its a perfect fit and comes in many colors. I got dark Grey. Arrived in 2 weeks from Europe. Not cheap, but a bag actually worth it. You can add D-ring hooks for free to hang on the wall.
#3441
My Feedback: (10)
#3447
My Feedback: (7)
NC
My friend is having issues with his computer tonight so I will post for him. He is wondering what kind of work was needed to get sierra retracts into this plane. Anyone have pictures of them installed. Thanks
#3448
what specifically has to be done to the arf to get the sierras installed ? are they the up front trunion kind ? Or does more in depth work need to be done thanks
thanks nc, seems to be working now
