Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 11-28-2014, 10:07 PM
  #3476
BJ64
BJ64's Avatar
What... a screw-driver and a FB hammer..??
LoL
BJ
Old 11-29-2014, 02:54 AM
  #3477
jagdpanther9
jagdpanther9's Avatar
I just purchased this model. this is my first post on this forum looks like a great thread. I have a lot of interest in the 84cc saito. is it really that bad of an engine?
Old 11-29-2014, 03:00 AM
  #3478
kwik
kwik's Avatar
The engine isnt bad at all. Its a fantastic engine.
Here is mine in use; ( It is in the Vailly Aviaton Fw 190 A4
https://www.youtube.com/watch?v=Cph9...cfjQKyisx5bArw
Thread about installing it; (As with all other engines, you have to get to know it. And read the manual)
http://www.rcscalebuilder.com/forum/...17&PN=1&TPN=11
Old 11-29-2014, 03:20 AM
  #3479
jagdpanther9
very nice FW and video! the engine sounds great.is yours stock out of the box?
I'm not a member @ rcsb so I couldn't view the thread. i will check into that.
Old 11-29-2014, 04:35 AM
  #3480
SrTelemaster150
SrTelemaster150's Avatar
Originally Posted by BJ64
Do they make helicoils down to that size?
BJ
An insert would be better. I had Clarence Lee do one in my FA-200Ti. The engine blew out the OEM brass insert for the extra glow plug.
Old 11-29-2014, 07:44 AM
  #3481
kwik
kwik's Avatar
Yes, it is stock out of the box. Just like my FG-57. And FG-33.
Wonderful engines.
You need to get to know an engine. It isnt just a question of starting it up and fly.
Old 11-29-2014, 11:08 AM
  #3482
hpergm
hpergm's Avatar
Plane's on its feet at last - temporary install of the pneumatics, pressurised @ ~100psi.
Sierra tailwheel install was straighforward after all the posted ideas in this thread (thanks). Used a lite 3" foam tailwheel, slightly bogs under the weight..
Stance on the ground looks scale - I am happy.
FG60 on the test stand ready for fire-up. More details on the FG60 R3 thread.
ID:	2050817   Click image for larger version
ID:	2050819   Click image for larger version
Old 11-29-2014, 11:27 AM
  #3483
hpergm
hpergm's Avatar
Some more detailing done on the plane until now:
Cockpit details (with Erich at the controls):
ID:	2050831   Click image for larger version
ID:	2050832   Click image for larger version
ID:	2050833   Click image for larger version
ID:	2050834   Click image for larger version
ID:	2050835   Click image for larger version
ID:	2050836   Click image for larger version
ID:	2050837   Click image for larger version
Old 11-29-2014, 04:39 PM
  #3484
BearBow
looks Great.
Old 11-29-2014, 10:17 PM
  #3485
hpergm
hpergm's Avatar
Hey, thanks Bear.
Some mods on the L/G legs: Done away with the stock clip-on gear cover mounts and used brazed K&S tubing. Looks much more scale and is completely adjustable - pics are self-explanatory.
Also used thick copper wire and material from an aluminium Coke can to make a fake brake line.
Finally, additional fake mounting bolts on the gear cover were installed - improves the scale looks considerably
ID:	2051091   Click image for larger version
ID:	2051092   Click image for larger version
ID:	2051093   Click image for larger version
ID:	2051094   Click image for larger version
ID:	2051095   Click image for larger version
ID:	2051096   Click image for larger version
ID:	2051097   Click image for larger version
ID:	2051099   Click image for larger version
ID:	2051100   Click image for larger version
Old 12-01-2014, 04:36 AM
  #3486
BJ64
BJ64's Avatar
I was just wondering... does anyone have any plans for a set of scale retracts of the TF FW190?
I wouldn't mind trying to make a set on the lathe/milling machine
BJ
Old 12-01-2014, 05:06 AM
  #3487
jagdpanther9
if I may add, what are the opinions on available retracts for this model? robart. sierra, air or electric. I think I would like to "get to know" a saito 84cc for my engine =D
Old 12-01-2014, 08:00 AM
  #3488
Loco3D
Loco3D's Avatar
I just got my Biela 22x12 3 blade spinner for my Saito.
Does anybody know where to get a FW190 3 blade spinner for it ?
Top flite one seems to be out of stock everywhere and I am wondering if there are any other companies that do this spinner for a 1/5 scale FW190 3 blade ???
Old 12-01-2014, 08:14 AM
  #3489
AV8ATOR
AV8ATOR's Avatar
Tower Hobbies : Top Flite Giant Focke-Wulf Fw 190 Gas ARF 50-55cc,85"
(Parts List)
Old 12-01-2014, 08:16 AM
  #3490
AV8ATOR
AV8ATOR's Avatar
[h=1]Edit Post deleted same:[/h]
Old 12-02-2014, 06:55 AM
  #3491
hpergm
hpergm's Avatar
BJ
You mean something like this..? Better talk to fwjeff over in RCSB.
Old 12-02-2014, 07:06 AM
  #3492
Reverend
Reverend's Avatar
www.spp-modellbau.de
Rev
Old 12-02-2014, 11:28 AM
  #3493
miklos
My Feedback: (38)
miklos's Avatar
You could try Troybuilt.
http://www.troybuiltmodels.com/items...9-83SPB-3.html
Old 12-02-2014, 11:46 AM
  #3494
Loco3D
Loco3D's Avatar
Originally Posted by hpergm
Hey, thanks Bear.
That looks great!
I was thinking doing the same thing when I get to that point though...
Get some scale stickers for retracts and proper weathering and will look much better ;-)
Old 12-02-2014, 03:51 PM
  #3495
CCFPILOT
When I check with Tower they have it in stock.
http://www3.towerhobbies.com/cgi-bin...&I=LXCLES&P=ML
Old 12-02-2014, 09:30 PM
  #3496
jagdpanther9
are the electric robart retracts from topflite reliable? are any of you guys using them? any input would be great.
Old 12-03-2014, 12:12 AM
  #3497
hpergm
hpergm's Avatar
That looks great!
Thanks Loco. Already on it; I plan to use the Testors inkjet paper for water transfers to print the black oleo plates on, apply some clear on top to seal them, then transfer them on aluminum tape (duct tape) which will then be cut to the proper outer shape and stuck on the oleos themselves. Result should be a realistic "black anodised" aluminum data plate as per original.
Old 12-04-2014, 08:07 AM
  #3498
BearBow
There are all kinds of blogs and issues with the Robart....they have real issues, but are half the price of Sierra's.....there is zero comparison in quality and performance.....so it depends on your wallet....You can get the Robart and send them to Down and Locked and they do a few small mods to make them far more reliable than stock....but if you're putting an expensive Saito in the plane, and a lot of custom work and time, Robarts is not the way to go, IMHO only.
Old 12-04-2014, 08:26 AM
  #3499
slembones
Bear
I must respectfully disagree. I have a saito 57t in mine and the electric retracts. the retracts have worked without problem for 2 years.
Old 12-04-2014, 08:34 AM
  #3500
MX240
MX240's Avatar
I have twenty seven flights on my FW 190 with air Robarts with no problems with the gears.
When I built the plane I beefed up the gear mounts...but only a little more hard wood epoxied under the others with larger and longer wood screws going into both. Yes, you have to drill out the mounting holes in the Robarts. I left the center ones over the air cylinder.
I have never removed the sheeting as others have done.
No heavier (under 29 lbs) and I have found Robarts are fine.
I do have a set of Sierra's in a forty pound plane which is good.
So far I haven't broke the plastic blocks out like I have done to my TF-51. More careful with this one.
Put in a much stronger gear....tear up or replace your wing....your choice.
Plus I can get quick repairs which I can't get from the other.
