Reload this Page >
TF FW190 GIANT ARF
TF FW190 GIANT ARF
Old 12-16-2016, 10:36 PM
  #4301
jagdpanther9
jagdpanther9's Avatar
yea, typical.........
Old 12-17-2016, 06:00 AM
  #4302
Spychalla Aircraft
My Feedback: (34)
Originally Posted by Chris Nicastro
Any close up pics of the FG84 installed in this FW cowl?
I have installed that engine in TF Corsair and had to use a H9 cowl to make it work. I've checked the FG84 against my SisT FW cowl and it's too big to fit without modifying it.
And, FYI, the FG84 will fit the H9 Corsair cowl without mods to the cowl if you install it with zero thrust angle compensation.
Will the FG84 fit the TF FW cowl without any mods?
Chris, Here are the close-up pictures you are looking for. Build a stack of plywood to mount it on. Cut the hole for the carb and all. A little dremel work on the corners of the square TF box will get you clear for the KELEO Muffler. Baffles are advised to get the cooling down. I got mine from Ray English in Nevada. It needs a big hole in the bottom of the cowl for cooling. I think mine is something like 4" wide and 6" long, better safe than sorry on an expensive engine like this. Also, don't miss the modifications on the side panels to get some air through that firewall, cut those panels back and fill in as needed. This is very helpfull for cooling. Leo Spychalla
ID:	2193701   Click image for larger version
ID:	2193702   Click image for larger version
Old 12-17-2016, 06:07 AM
  #4303
Spychalla Aircraft
My Feedback: (34)
Now for something trick on the Saito FG84. A way to choke that beast without pulling on the barrel of the carb. I built a servo hinged flapper with foam on it that closes when the ignition is turned off. It is just like putting your thumb over the carb. I run dual 7ch RX so you can actually get by with both ignition and choke on one channel plugged into separate RX. You never have either of them on at the same time. Works like a charm. Leo Spychalla
ID:	2193704   Click image for larger version
Old 12-19-2016, 12:08 PM
  #4304
badazzgti03
Ill be mounting an FG84 on mine as well. I heard you need to cut the fire wall back 1" and use some stand offs.
But i'm at the point of installing Robart electric retract tail gear and wondering how do you get it to slide in the fuse...The actuator seems to be in the way but can't be removed. How did you all get that to fit?
Old 12-19-2016, 01:33 PM
  #4305
n8622t
My Feedback: (8)
Maybe I'm wrong but by looking at this pic, it appears that the engine bolts to the original firewall with a spacer added????
Old 12-19-2016, 01:36 PM
  #4306
Chris Nicastro
Chris Nicastro's Avatar
Awesome!!
Old 12-20-2016, 06:46 AM
  #4307
badazzgti03
Leo,
Did you cut back the fire wall? Like n8622t said it looks like you added a plywood spacer? what's the depth on that spacer? With the throttle body is in the fire wall how do you go by tuning the engine to get to that needle valve? I'm trying to do this to mine without having to cut the fire wall back and risk screwing up the thrust angle on the fire wall.
Old 12-21-2016, 04:32 AM
  #4308
Spychalla Aircraft
My Feedback: (34)
No cutting of the firewall. You do need to cut hole in it to accept the carb. The thing to recognize is that this is a 4-Stroke engine and that they don't have the spit-back out of the carb like a 2-Stroke. So putting the carb intake right in the inside of the fuse is not an unreasonable way to go. Just build a stack of plywood to satisfy the engine position you desire.
Carb adjustment is done through 2 well placed guide tubes on the port side. Check the pictures for the white tubes. They guide a screwdriver from small holes in the cowl right to the carb. You can adjust easily while the engine is running.
Leo
Old 12-21-2016, 07:54 AM
  #4309
badazzgti03
Awesome i see how its set up. Instead of plywood I have a bunch of stand offs and spacers and will use those so I don't completely block airflow to the carb.
Old 12-21-2016, 10:22 AM
  #4310
n8622t
My Feedback: (8)
Leo
Good to know....thanks
Old 12-21-2016, 09:15 PM
  #4311
Chris Nicastro
I have a new set of Sierra gear for a SisT 190 I haven't built yet. I was considering getting a TF FW just to get flying but I'd like to avoid the issues of the Robart gear for this plane.
Does anyone have some pics and info on the installation of Sierra gear? Any other problems or is it better to fix the Robart trunion block?
Old 12-22-2016, 04:51 AM
  #4312
Spychalla Aircraft
My Feedback: (34)
Chris, I have made a mounting design and have all the details, but it is based on increasing the dihederal of the wing to a scale configuration. I can send out a print-out of the templates in order to be helpful. I should put together an instruction sheet to go with the templates. The sequence is: Tear out the old mounts, prepare new plywood and maple mounts, epoxy mounts in, cut bottom of wing joiner .250" on bottom outer edges, add .250" block to the top, epoxy wing together, fill bottom gap with balsa, glass strip the seam, cover with a trim of monokote. Done with gear at correct angle. Leo Spychalla
If interested in the details on this send me a PM with your snail-mail address and I will send you what you need. I will put together a paper template / plan and some instructions over this Christmas Holiday weekend 12/25/16 and have it available, (no parts, just paper). I will be asking for a small donation via mail or PayPal to cover expenses. Leo Spychalla
ID:	2194063   Click image for larger version
ID:	2194064   Click image for larger version
ID:	2194065   Click image for larger version
ID:	2194066   Click image for larger version
ID:	2194067   Click image for larger version
ID:	2194068   Click image for larger version
ID:	2194069   Click image for larger version
ID:	2194071   Click image for larger version
ID:	2194072   Click image for larger version
Last edited by Spychalla Aircraft; 12-22-2016 at 01:37 PM. Reason: Adding information
Old 12-22-2016, 07:01 AM
  #4313
BobH
Leo,
that looks SO MUCH BETTER.
Old 12-22-2016, 09:04 AM
  #4314
AV8ATOR
AV8ATOR's Avatar
Nice work Leo, I for one am interested in the instruction sheet and templates.
Old 12-22-2016, 11:20 AM
  #4315
Spychalla Aircraft
My Feedback: (34)
OK. Send me a PM with your snail-mail address and I will send you what you need. I will put together a paper template / plan and some instructions over this Christmas Holiday weekend 12/25/16 and have it available, (no parts, just paper). I will be asking for a small donation via mail or PayPal to cover expenses. Leo Spychalla
Old 12-22-2016, 11:44 AM
  #4316
AV8ATOR
AV8ATOR's Avatar
Sent you a PM.
Old 12-22-2016, 12:01 PM
  #4317
n8622t
My Feedback: (8)
Nice explanation Spychalla A....I saved all of that Thanks
Old 12-22-2016, 09:02 PM
  #4318
Chris Nicastro
Thanks Leo, I'll be in touch, that not too bad of a mod to do. Funny it's a similar solution to the P-51. Adding the scale dihedral and using the 85 degree retracts makes the plane look right and it flies great.
Did you notice any difference flying with more dihedral in the FW?
Old 02-05-2017, 01:10 PM
  #4319
Tony Gag Jr.
My Feedback: (124)
Tony Gag Jr.'s Avatar
I want to separate my gear doors so there is a lower and upper gear door. I am using Robart retracts. Does anyone have pictures of how they mounted the lower portion of the gear door?
Tony
Old 02-05-2017, 01:45 PM
  #4320
Mpizpilot
My Feedback: (45)
Tony
Check this page of the thread. I'm doing the same. Just bought a new set of doors.
http://www.rcuniverse.com/forum/rc-w...l#post11479371
Old 02-06-2017, 12:07 PM
  #4321
Tony Gag Jr.
My Feedback: (124)
Perfect, thank you.
Old 02-12-2017, 03:44 AM
  #4322
bladebender
Spychalla can you set me up temples for Sierra gear just pm me a price
Old 02-14-2017, 06:52 AM
  #4323
rigofly
rigofly's Avatar
Hy guys, I'm going to finalize my FW190 and I have a question about COG and balance point. The 195mm suggested by the manual shall be measured from which part of the wings? Where there is located the first cannon (red arrow) or from firewall (green arrow) ? Thanks a lot for your support.
Regards
Riccardo
Name:	TF FW190 Balance point.JPG
Old 02-14-2017, 07:29 AM
  #4324
khoysagk
Red arrow
Old 02-14-2017, 07:35 AM
  #4325
ForcesR
Regards
Riccardo
The CG is as stated on page 30, from the wing break which is where the inner cannon is located and you have identified via red arrow.
